Welcome to the North American Subaru Impreza Owners Club Wednesday April 24, 2024
Old 01-10-2011, 01:20 PM   #1
MSMStannyl
Member#: 267225
2011 WRX Limited 4DR
Satin White Pearl
Default Air/Oil Seperator
So I'll admit, I'm brand new to the Subaru cars. Just bought my first one, a 2011 WRX. I've heard/read about this issue previously but, for some reason, was under the impression that this wasn't really a problem with the newer vehicles and am hoping someone can explain this a little better.
What I'm wondering about is whether an Air/Oil seperator is required on a what is a stock WRX at the moment. I will, however, have a Cobb AP running by the end of the week (not sure if this changes anything but figured I would point it out). Also, in the next few months, I may have an AEM Intake installed but am not positive yet. In any case, I'm wondering at what point, if any, do I need to start worrying about oil getting into the intake as explained in the article (link below). Yes, the article is based on a 2011 STI but I would imagine similar issues would come to a WRX as well, right?
http://www.importtuner.com/powerpage...sti/index.html
Anyway, why does this happen? Is it bad for the car? Is it a known issue with Subaru's and if so, why don't they do something about it? Lastly, does this only become an issue when you upgrade something specific?
Thanks for help and sorry for being a newbie!
MSMStannyl is offline   Reply With Quote
Old 01-10-2011, 02:38 PM   #2
SeeeeeYa
Member#: 129681
2024 Crosstrek Ltd
Ice Silver Metallic
Do not worry. No AOS is necessary until waaay down the mod road, and by then you will be posting answers instead of questions.
SeeeeeYa is offline   Reply With Quote
Old 01-10-2011, 02:54 PM   #3
MSMStannyl
Member#: 267225
Satin White Pearl
Hahaha, well said. That's the answer I was hoping for!
Thanks!
Old 01-10-2011, 03:12 PM   #4
zeppy
Member#: 246627
2005 STI
to answer your question....
Is the Air/Oil Separator suitable for a stock/daily driver?-
Yes... You can pull the intercooler off your new car with only 500 miles on it and find oil inside of it. The purpose of the AOS is to remove this oil from the intake system to lessen the possibility of detonation which is the main cause of broken ring lands on the stock pistons. As you increase your HP, the amount of blow by passing through your breather system increases as well. This scenario also increases the need for our AOS.
^this is from Crawford performance.
zeppy is offline   Reply With Quote
Old 01-10-2011, 03:36 PM   #5
Jarzar06
Member#: 268928
2020 WRX/STI
well im in the same boat im waiting for my 11 wrx to arrive, wouldnt the perrin catch can do the same thing but instead of putting it back into the motor just to fill up the can? plus cheaper
Jarzar06 is offline   Reply With Quote
Old 01-10-2011, 03:41 PM   #6
Dave_zok
Member#: 225034
2006 STI
Yes, but then you have to maintain it and always empty it. The cool part of an AOS is that the oil stays in your system and you dont have to worry about any low oil issues.
Dave_zok is offline   Reply With Quote
Old 01-10-2011, 03:50 PM   #7
Jarzar06
Member#: 268928
2020 WRX/STI
alright ill prob. just go with the crawford AOS and be done with it thanks
jw whats the thought on the grimmspeed ones?
Old 01-10-2011, 04:29 PM   #8
04STI305
Member#: 264160
2004 STI
blue
just installed a grimmspeed in mine works great so far easy to install
04STI305 is offline   Reply With Quote
Old 01-10-2011, 09:33 PM   #9
mister_skinny
Member#: 117537
04 STI
WRB! & Silver 02 WRX
I just bought a 2010 Impreza Outback Sport Saturday. Air/Oil Separator is the first thing on my list to do to the car. It only has 7900 Miles on it, but my 02 WRX has 92,000 with a LOT of oil in the intake system. I have had a Cusco oil catch can on the WRX since around 50,000, but it has never really caught anything. My friend with another WRX with the Perrin catch can hasn't caught anything either. I like products from both of these brands, but the catch cans don't work unless you are at WOT (Wide Open Throttle).
I plan to get the Grimmspeed and use clear hoses to see if it is actually working. On my WRX the hoses coming in and out are clear, and both are coated in burnt oil. Cusco says that their race car's can has to be emptied all of the time, but daily driving I'm getting nothing. And I DO run the car hard fairly often.
mister_skinny is offline   Reply With Quote
Old 01-11-2011, 09:32 AM   #10
Dave_zok
Member#: 225034
2006 STI
Does anyone have any opinoin on which AOS is better the crawford or the Grimmspeed. It seems like the Grimmspeed has a much easier install and uses differnt hoses to tie into. Are they any benifits to either, besids the price.
Old 01-11-2011, 09:33 AM   #11
Dave_zok
Member#: 225034
2006 STI
these are the videos i used to install referance
Crawford AOS Install
http://www.vipstand.net/en/online-vi...-Subie-TV.html
Grimmspeed AOS install
http://www.grimmspeed.com/catalog/pr...roducts_id=191
Old 01-11-2011, 09:56 AM   #12
SAMSNEED
Member#: 54600
2006 STI
CGM
while grimmspeed and crawford are reputable companies, there are other aos systems that works the same and less expensive. Check out sg motorsports over at import image racing. This is what I have. I removed my intercooler yesterday and their was not one drop off oil where as before it had alot. And before the aos my car was not even modified.
And when I remove the oil cap you will see all the condensation left in the filler neck. My aos works great and in the gb I got it for half the cost off GS or Crawford. You cant go wrong with any of those brand, but shop smart do yor research.
SAMSNEED is offline   Reply With Quote
Old 01-11-2011, 02:46 PM   #13
Dave_zok
Member#: 225034
2006 STI
After doing some searches it seems that the crawford AOS uses coolant to heat it the oil and reduce any water build up. That is not an option for the Grimmspeed so will they have the same issue that crawford has with there V1 AOS
Old 01-11-2011, 07:03 PM   #14
Team Scream
Member#: 121532
06 FXSTi, 06 FXTAT
06 STi Wide Body Wagon
That is an after thought or actually a response to a problem all Crawford AOS had where the oil would coagulate and clog the lines rendering itself useless.
They now use coolant to heat the canister to keep the oils from coagulating and supposedly they actually work now.
The SG motorsports unit is a very nicely made piece and I also got in on the group buy.
Another very good option that works really very good is the Ixiz Concepts AOS.
I also have an Ixiz on my STi and it is flawless.
The Ixiz are not as nice looking, but they certainly work well (speaking from 400+ HP meth/pump experience).
I have yet to install the SGM unit on my Forester, but will before the week is out.
I would be cautious about paying $375.00 for a Crawford AOS. WAYYYYYYYYY too expensive for what you get in my "opinion".
Team Scream is offline   Reply With Quote
Old 01-11-2011, 08:18 PM   #15
e-zee
Member#: 150212
2006 STI
I have an ixiz unit and the other day I cut one of the lines because it was in my way, and quite a bit of water poured out of the line. Should I be concerned? I've been meaning to call ixiz about it.
e-zee is offline   Reply With Quote
Old 01-11-2011, 08:34 PM   #16
SeeeeeYa
Member#: 129681
2024 Crosstrek Ltd
Ice Silver Metallic
Interestingly, I've NEVER had any of these problems.
But then, I've never had an AOS either. In fact, regardless of use and level of mod, in two turboed Subarus over the last six years, I've never had a problem related even remotely to the stock PCV system.
I may not get one for the new WRX... but I'll think about it. I still have a little box of parts I've gathered. I just haven't thought I needed one yet.
Seems like a nasty thing to deal with to me. Nothing to deal with with the stock stuff. Probably why I'm still thinking about it.
Old 01-12-2011, 01:07 PM   #17
MSMStannyl
Member#: 267225
Satin White Pearl
Wow, I'm surprised. I really thought this wouldn't of been an issue until way down the mod road. I'm surprised Subaru puts out stock engines that have these kinds of issues. Other than low oil levels due to oil all over the intercooler,intake, etc., could there be any other problems? I mean in terms of where this oil is going?
So if I understand these posts correctly, most of you are recommending getting an AOS even on a brand new 2011 stock WRX? I wonder if this would have any warranty impacts with the dealership even tho you're technically fixing a problem for them.
Lastly, is there any quick an easy way to check to see if I'm getting oil outside of where it needs to be? I read, above, about the intercooler but is that something more involved (I have no idea since this is my first Subie)? Is there an easy and quick "at a glance" kinda thing I can do to see if this is happening?
Old 01-12-2011, 01:21 PM   #18
Unabomber
Big Ron
Super Moderator
Member#: 18062
on car parts so PM
me b4 j00 buy
I have a Subaru with 140,000 miles on the ticker. I have never used any form of catch can or AOS. I don't look into my intercooler or intake plumbing for oil or mice as there's no need. I start my car and whip the crap out of it whilst performing maintenance IAW the maintenance schedules. I only have 140,000 miles on my car and burn zero oil and use whatever oil is on sale or is closest to my hand at whatever store I am in at the time. Can you guess what my opinion is of these products that I don't use and am standing at 140,000 miles?
Old 01-12-2011, 04:12 PM   #19
MSMStannyl
Member#: 267225
Satin White Pearl
So if I understand what you're trying to say, you're saying that getting an AOS is an absolute MUST and that you wouldn't drive a single mile without one, right?
Haha. Just kidding. Yes, I got what you're saying. That's pretty much in line with what I was assuming, I just don't have the experience with Subaru that others do.
That's good to know tho, thanks!
Old 01-12-2011, 09:55 PM   #20
SAMSNEED
Member#: 54600
2006 STI
CGM
Look, I don't know about anyone else's car except mine. All i know is with stock and then stage 2 I always had oil in the hose and intercooler after the turbo. When I replaced the turbo inlet their was oil sludge in the old one. Now I have full mods, atp3071 and everything to go with it, and when I took my intercooler off to do some maintenece, what do you know no oil anywhere. I don't know how it affects the performance but all I know is their is no oil in my intercooler anymore. So does my AOS works, hell yeah. Do you need one? Thats up to you.
Old 01-13-2011, 01:03 AM   #21
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
How much power does that motor make? (on the dyno of your choice)
Old 01-13-2011, 06:54 AM   #22
MSMStannyl
Member#: 267225
Satin White Pearl
Has anyone had warranty issues with a dealership after installing an AOS? I know that technically you're fixing a legitimate issue that Subaru seems to not have addressed but you know how some dealerships can be...
By the way, is there any reason to think the oil in the piping issue may have been fixed by Subaru in the later years (like 2011)? Why is there no recall? I would imagine this could hurt the lifespan of the engine as well as cause other parts to fail if enough sludge gets in...
Old 01-13-2011, 10:34 AM   #23
Unabomber
Big Ron
Super Moderator
Member#: 18062
on car parts so PM
me b4 j00 buy
Last dyno run for me was 292WHP....stock was 165WHP, been going up and up slowly over 7-8 years.
This is and never will be a recall. Read my post above. Having oil in the piping is an aesthetics issue. If you believe otherwise, my engine longevity would like to have a talk with you.
Old 01-13-2011, 01:31 PM   #24
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
What about the ppl with 400whp?
FYI, had a lot of oil blow by and after installing the crawford A/O there was non after.
BlackFighter is offline   Reply With Quote
Old 01-13-2011, 02:33 PM   #25
Unabomber
Big Ron
Super Moderator
Member#: 18062
on car parts so PM
me b4 j00 buy
Don't think it's an issue even at 1000HP. While they are popular and inexpensive and I have no hate for the various solutions per se, it's just not warranted. I have seen zero posts here that said, "My engine assploded and I am to blame because I don't have a catch can or other oil reclaimation device." I think it's mucho ado about nothing, but that's my crappy opinion and ya'll are free to do as you like.
Air/oil seperator installed,Still burning oil AWDREX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 85 10-29-2014 11:41 PM
wtb: oil catch can/air-oil seperator 04works Private 'Wanted' Classifieds 9 03-22-2010 09:46 PM
air oil seperator and oil catch can pros and cons wrx068727 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 63 10-04-2009 09:56 PM
oil catch can or air oil seperator??? jaytech Newbies & FAQs 11 09-21-2009 12:03 AM
air-oil seperator routing moorebl Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 02-18-2007 04:08 PM
