Welcome to the North American Subaru Impreza Owners Club Thursday March 30, 2023
Old 02-01-2011, 03:19 PM   #1
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Default 2011 WRX right signal light flashing too fast. Help!
Alright so today I was driving along on the freeway and signaled right to change lanes and noticed that the blinker was flashing way too fast. I thought maybe the light had burned out which was highly unlikely since the car is less than 3 months old. After I parked I checked my lights and they were all working but the right blinker was still flashing twice as fast as the left one. When the hazard button is pressed all the lights flash at the same speed.
I did hit a pretty big bump today but I've hit worse. Could that have caused my lights to go crazy?
PS: I do have hella supertone horns installed but they've been on for about a month and never had any problems with them. I also have a kartboy shortshifter which I have no idea how it could have affected my lights, but I'm worried the Subaru guys might use that as an excuse to fix my light.
Anyways if you guys know a quick fix please let me know.
xabre1200 is offline   Reply With Quote
Old 02-01-2011, 03:21 PM   #2
dsmtweaker
Member#: 265405
2013 Audi
This is a known issue on the 2011 models. Sometimes it goes away on its own, sometimes it doesn't.
Either way, take it to the dealer, and they will fix it. Thats what warranties are for.
dsmtweaker is offline   Reply With Quote
Old 02-01-2011, 03:21 PM   #3
dsmtweaker
Member#: 265405
2013 Audi
Old 02-01-2011, 03:23 PM   #4
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Yeah I'll take it to the dealer. Should I remove my hella supertone horns first though?
Old 02-01-2011, 03:24 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
no....
****...you could likely figure it out yourself and save the going to the dealer hassle
I would...try anyway
Old 02-01-2011, 03:36 PM   #6
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Originally Posted by Uncle Scotty View Post
no....
Any advice on how to do this?
Old 02-01-2011, 03:49 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
search and find and READ all the OTHER threads on just this issue
and do what they did
Old 02-01-2011, 03:50 PM   #8
djoye
Member#: 50072
2017 STI
Sometimes if the blinker is blinking fast then there's an electrical issue with the lights. Some vehicles' get fast blinker if there's a burned-out bulb along the line. For a newer vehicle I'd assume something is loose with the bulb connections.
djoye is offline   Reply With Quote
Old 02-01-2011, 03:52 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
stop assuming
THIS IS A KNOWN ISSUE ALREADY AND THE FIX IS ALREADY KNOWN
Old 02-01-2011, 03:54 PM   #10
FlyingMoose
Member#: 255274
13 WRX
Had this same problem on my 2010. Fixed itself within a week.
FlyingMoose is offline   Reply With Quote
Old 02-01-2011, 03:55 PM   #11
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
stop assuming
Will you please link us to the fix
Old 02-01-2011, 04:04 PM   #12
Wrencher86
Member#: 250463
2010 Impreza 2.5i
Reposition the wiring harness going to the bulb. This happened on my 2010. When you go to change the bulb you will notice that the harness is at an awkward angle. Just straighten it out a little. I believe that is what the TSB tells you to do. But like Scotty said, there are a lot of other threads on this that likely have the official TSB repair listed. Do a search. Should pop right up.
Wrencher86 is offline   Reply With Quote
Old 02-01-2011, 04:52 PM   #13
F3nris
Member#: 262657
2016 WRX Prem
Lapis Blue Pearl
My 2011 does the same thing, I have the same mods, but the issue started before i had them.
I just get out, and tap the light housing, and its all better. If you get out and look while its doing it, the bulb will be flashing weakly in the front.
F3nris is offline   Reply With Quote
Old 02-01-2011, 04:54 PM   #14
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Maybe I'm searching wrong but I still cannot find any other threads with people posting fixes for the problem.
Haha, I don't want to keep tapping the housing. Scared it might break if I do it too often.
Old 02-01-2011, 05:55 PM   #15
scotheocelot
Member#: 254768
2011 STi Sedan
Thats also what I have noticed too. I gonig to check all my bulb connections but I havent done anything at this point. Strange.
I think it may be in the relay or the switch itself. If the switch doesnt make pure contact then it will act almost as a short. Has anyone paid attention to how you pull down on the turn signal stalk?
scotheocelot is offline   Reply With Quote
Old 02-01-2011, 10:08 PM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
will YOU please find it and READ it???
ya want charmin or white cloud
Old 02-01-2011, 10:58 PM   #17
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
What the hell... I already said I did a search and could not find it. Stop being such an ass and help out.
Old 02-01-2011, 11:15 PM   #18
Gr33nway
Member#: 263546
I've noticed this on my 2011 WRX, no mods, hatchback. It seems after a few seconds it goes away and I can't reproduce it, then it comes back. Maybe someone will link some documentarion, or just keep being arse holes and claim you haven't searched :-/
Gr33nway is offline   Reply With Quote
Old 02-01-2011, 11:23 PM   #19
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
"Before replacing a head-lamp assembly for a Customer concern of a turn
signal that blinks too fast, check the wiring as it enters the turn signal bulb
socket. There may be too much tension on the wires that could be causing a
poor connection. Slightly re-routing the wire harness to alleviate the tension should remedy the condition. "
Old 02-01-2011, 11:36 PM   #20
Wrencher86
Member#: 250463
2010 Impreza 2.5i
I believe I said that earlier.
Also:
http://forums.nasioc.com/forums/show...ht=turn+signal
http://forums.nasioc.com/forums/show...rn+signal+fast
It took me about 3 minutes to find these. And I suck balls at searching.
Old 02-01-2011, 11:38 PM   #21
narstune
Member#: 267405
'11 WRX Hatch SWP
I just got this fixed today. It's just the connection on the harness that's loose. Re-seat the bulb and that should fix the problem.
narstune is offline   Reply With Quote
Old 02-01-2011, 11:59 PM   #22
spintheground
Member#: 239638
2007 WRX TR UGM
Search:
http://www.google.com/search?hl=en&rls=com.microsoft%3A*&q=2011+wrx+blinker+issue+fix&aq=f&aqi=&aql=&oq=
First result:
http://www.clubwrx.net/forums/genera...-signal-2.html
Read that two page thread; try what other people tried; see what works for you. Use your problem solving skills to work out a solution with the given information.
If you were hungry and found an orange, would you post a thread asking how to peel it?
spintheground is offline   Reply With Quote
Old 02-02-2011, 10:10 AM   #23
WRrexu
Member#: 217061
2009 Wrx
WRrexu is offline   Reply With Quote
Old 02-02-2011, 10:29 AM   #24
PlasticFoamMan
Member#: 197764
2002 Nissan Frontier
buh bye WRX :(
Scotty and anyone else here are NOT here to spoon-feed you because of laziness so don't act entitled.
All I had to to was search "2011 blinker issue" on Google and guess what? STi fast blinker was the FIRST result in Google. I didn't even search specifically, I bet you could find an answer in five seconds with a thought out couple of words.
PlasticFoamMan is offline   Reply With Quote
Old 02-02-2011, 10:51 AM   #25
imprezed2011wrx
Member#: 267998
2011 Impreza Wrx
Same thing happen to my mine took it to the dealer and they fixed for free. Its kinda like a recall when you take it in tell the tech to look in the january tech notes it will be on there. They had to take my bumper off they said to re-route some wires. All I know now it is fixed and has done it again yet.
imprezed2011wrx is offline   Reply With Quote
xluben's 2011 WRX: Spec B 6 Speed and Rotated PTE 6266 xluben Member's Car Gallery 5716 08-29-2014 02:26 AM
2011 WRX Vs. 2008 WRX STI Tetegra General Community 36 04-26-2013 08:28 AM
Dumb to buy a used 2008 WRX vs. a 2009 WRX right now? 02BlueSuperRoo General Community 96 02-13-2012 07:18 PM
WTT : 2011 Wrx stocks rims chris2.0t Tri-State Area Private Classifieds 8 02-11-2011 04:50 AM
2011 wrx automatically blips throttle on upshift? honestabe Newbies & FAQs 17 02-02-2011 12:01 AM
