Welcome to the North American Subaru Impreza Owners Club Sunday May 27, 2018
Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 02-15-2011, 08:43 PM   #1
SubieEngineer
Member Sales Rating: (53)
Member#: 208152
2004 350Zed Base
Sold: 07 STI LTD #576
Default ***SOLD*** RCE V2 Front Lowering Camber Plates
I have for sale a pair of Racecomp Engineering Lowering Camber Plates. They are the V2 with the beefier bearing, and will lower the car by 3/8" without losing suspension travel. I'm asking $200 plus shipping, or best offer. There are a few minor scratches on one plate from where I had to drill out a stubborn stud that was stripped. That's the good news, now the bad...
About 3-4 months ago, I had the studs in one plate replaced due to the body shop stripping one (that plate developed a clunk when I hit road imperfections). They were replaced with Grade 10 hardware for extra strength, and I scratched the plate lightly in the process of removing the stripped stud (had to drill it to pieces, literally). A few weeks later, a clunking developed on the other plate that turned out to be failing studs (same noise as the first plate). I had these replaced with the same hardware as the first plate. Also, I had the plates oriented for camber/caster gains, so the R plate was on the driver's side and vice-versa. About a month ago, the bearing in the R plate developed some play and started clunking over imperfections (just about anything, really), so it needs to be replaced. I've talked to Myles at RCE and a replacement bearing is $125 plus shipping.
This past Sunday I removed the plates from the car, and I discovered that the bolts that hold the bearings to the plates were overtightened, so they'll need to be replaced. This is a cheap and easy fix, especially if you have access to someone at a machine shop.
Cliffs: Cheap RCE Lowering Plates with all 6 studs replaced and 1 bearing shot ($125 plus shipping to replace), and both bearings have stripped studs from being overtightened. $200 plus shipping OBO!
***SOLD***
SubieEngineer is offline   Reply With Quote
Old 02-16-2011, 10:49 PM   #2
SubieEngineer
Member#: 208152
2004 350Zed Base
Upwards.
Old 02-19-2011, 08:18 PM   #3
SubieEngineer
Member#: 208152
2004 350Zed Base
And again.
Old 02-20-2011, 06:20 PM   #4
SubieEngineer
Member#: 208152
2004 350Zed Base
Sunday bump.
Old 02-21-2011, 10:42 PM   #5
SubieEngineer
Member#: 208152
2004 350Zed Base
Skyward.
Old 02-22-2011, 10:22 PM   #6
SubieEngineer
Member#: 208152
2004 350Zed Base
News bump.
Old 02-24-2011, 09:34 PM   #7
SubieEngineer
Member#: 208152
2004 350Zed Base
Royal Pains bump.
Old 02-25-2011, 11:00 PM   #8
SubieEngineer
Member#: 208152
2004 350Zed Base
Upwards.
Old 02-27-2011, 07:38 PM   #9
SubieEngineer
Member#: 208152
2004 350Zed Base
Sunday bump.
Old 02-28-2011, 11:27 PM   #10
SubieEngineer
Member#: 208152
2004 350Zed Base
Upwards.
Old 03-01-2011, 07:26 PM   #11
SubieEngineer
Member#: 208152
2004 350Zed Base
Bump.
Old 03-02-2011, 10:29 PM   #12
SubieEngineer
Member#: 208152
2004 350Zed Base
Again.
Old 03-04-2011, 03:35 AM   #13
SubieEngineer
Member#: 208152
2004 350Zed Base
Late night bump.
Old 03-04-2011, 02:45 PM   #14
WRC-boxer
Member Sales Rating: (9)
Member#: 147186
How are the bolts that hold the bearings to the plate attached to the bearing holder? Press fit? Or do the allen heads on the underside allow them to be screwed in/out? Are they a specific/special/hard to find?
With the new bearing, does it come with a new holder and then new bolts? Or is it just the bearing itself that gets pressed in/out and the bolts would still need to be changed?
Are the new studs held in with the nut on the other side? Or have they been pressed in.
How many miles are on them/what is the condition of the left (non-clunking) bearing?
Thank-you for your time, sorry for all of the questions.
cheers
-Evan
WRC-boxer is offline   Reply With Quote
Old 03-05-2011, 12:41 AM   #15
SubieEngineer
Member#: 208152
2004 350Zed Base
cheers
-Evan
No worries.
I'm assuming the new bearing comes with a holder, 2 bolts and all. It's a spherical bearing, so I don't see why they would just send that portion as a replacement, as there doesn't seem to be a way to press it in or anything.
If the allen heads for the bearing studs are like the 3 heads on the bolts that hold the plate to the body of the car, you can unscrew them. When I had the 3 studs replaced, the guy that did it used replacement bolts that screw in. However, I didn't ask how he removed the old studs.
The new studs are just screwed in.
I purchased the plates used about this time last year. I installed them on my car in July and have run them for just over 8k miles. I removed them a few weeks ago (Feb 18).
Old 03-05-2011, 12:53 AM   #16
WRC-boxer
Member#: 147186
You just made this very tempting, just waiting to hear back from RCE, confirming about the bearing portion/studs.
Also curious as to the benefit of swapping which side the plates are on, castor gain? These will be on a GC chassis, so they will be canted for camber/castor increases.
cheers
-Evan
Old 03-06-2011, 08:11 PM   #17
SubieEngineer
Member#: 208152
2004 350Zed Base
cheers
-Evan
Sorry, man, but I sold them today.
I don't know the max camber you can get on a GC with these plates, but I had them swapped for camber/caster gains. I maxed out at about -2* neg camber, ~-3.6* caster (damn 07 lower control arms).
WTB: RCE Front Lowering Camber Plates kyle sti Private 'Wanted' Classifieds 1 05-06-2010 02:16 PM
RCE front lowering camber plates in stock and ready to ship Fine Line Imports Engine/Power/Exhaust 0 04-08-2009 02:33 PM
RCE black /w lower camber plate vs RCE yellows chanmanWRX Brakes, Steering & Suspension 6 03-30-2009 12:01 AM
FS-Hou,TX: RCE Bronze springs, RCE front lowering camber plates STi_0497 Suspension/Brakes/Handling 3 09-05-2008 12:44 PM
WTB: RCE front lowering camber plates lancelucas Private 'Wanted' Classifieds 1 11-10-2006 05:46 PM
