Welcome to the North American Subaru Impreza Owners Club Saturday November 18, 2017
Old 03-07-2012, 01:41 PM   #26
Bighec
Member#: 250626
2011 STi
Has anyone tried mounting the relay in the fuse box and getting power from somewhere other than + battery terminal?
Bighec is offline   Reply With Quote
Old 03-07-2012, 02:05 PM   #27
SubyLoverNJ
Member#: 312775
I have mine running to a relay, but the relay isnt in the fuse box
SubyLoverNJ is offline   Reply With Quote
Old 03-07-2012, 02:30 PM   #28
FL4TFTW
Member#: 256953
2014 Built DGM BRZ
2016 Fiesta ST WP Tricoat
Same.
FL4TFTW is offline   Reply With Quote
Old 03-07-2012, 08:23 PM   #29
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
same here, to put it in the fuse box you'd have to get underneath the panel and rewire the socket (if theres a free one)
aerosaaber is offline   Reply With Quote
Old 09-11-2012, 05:25 PM   #30
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
trying to decide to use the relay or not? I am puzzled what that difference really is. Plug existing wireing into horn, ground horns, done. Why use the relay at all?
medamullet is offline   Reply With Quote
Old 09-11-2012, 08:19 PM   #31
Dmochowski
Member#: 306478
2016 Focus RS
stock
so why do people require wiring to do this mod? i installed them on my 2012 and just used the factory horn wire and ran a wire splitting to two going to the horns and the ground going to the bolt that held that oem horn in place.
Dmochowski is offline   Reply With Quote
Old 09-11-2012, 10:04 PM   #32
cpc691
Member#: 195739
2002 wrx wagon
I believe it makes them a bit louder than without them
cpc691 is offline   Reply With Quote
Old 09-12-2012, 09:01 AM   #33
Dmochowski
Member#: 306478
2016 Focus RS
stock
mine are loud ass hell now without the relay i dont have any sound measuring devices but i tested them in my garage and they were deafening...
Old 09-13-2012, 06:25 PM   #34
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
did you tell your GF to stick her head under the hood before you did that?
Old 09-15-2012, 07:55 PM   #35
401sti
Member#: 321326
04 sti
^^^classic!
i just installed mine today as well without the relay and they are load! thanks for this little write up helped a ton
401sti is offline   Reply With Quote
Old 09-16-2012, 04:32 AM   #36
djtypewhazn
Member#: 292747
2011 WRX
just installed mine on my 2011 wrx. i now have 2 stock plus my supertones..... im not a violent person, but when i get cut off 2ce in one day i had to get some. ill eventually wire in a switch to just use my stock horns.
djtypewhazn is offline   Reply With Quote
Old 09-16-2012, 09:23 PM   #37
97_Leggy_GT
Member#: 314376
That's funny, I bought some for the same reason. I really DON'T want to put the car back into the body shop for a third time this year. For some reason I only had one stock horn, so I could barely hear it inside the car.
Got two Panthers and kept the single stock horn. Now it's LOUD. I will say though, that the "wiring diagram" on the box is a bit vague and hard to decipher, so I'm glad this thread was here...
Pic: Link
97_Leggy_GT is offline   Reply With Quote
Old 09-17-2012, 01:13 AM   #38
HonduhPowa
Member#: 269076
2012 Wrx
Hey guys, i've got a question about the supertones on my car.
I've got a 2004 Wrx that came with two red hella supertones in the front grill, when i hit the horn they do not work, but i do hear a relay (sounds to be in the engine bay) click when the horn is pressed. Any ideas where to start looking? I have no idea how the previous owner wired them. I tried to trace the wires FROM the super tones, and they lead into some wire loom towards the drivers headlight.
HonduhPowa is offline   Reply With Quote
Old 09-17-2012, 01:15 AM   #39
FL4TFTW
Member#: 256953
2014 Built DGM BRZ
Well did you look at the wiring? Probably a good place to start. Is a relay being used?
Old 09-17-2012, 08:53 PM   #40
97_Leggy_GT
Member#: 314376
You CAN wire them to the stock horn wires, which join a wire bundle shared by the headlamps - at least on my BD Leggy. That's probably what you're seeing. If there's a relay, then there SHOULD be a wire tapping power from the battery's positive lead as well. Might start by trying to find that wire and trace from there.
This is the ideal wiring setup for the horns. If all else fails, you might just rip out the wiring you've got already and start over. Total cost to you should be about $15-20 for wires and a relay at an auto parts store.
Old 09-25-2012, 03:30 AM   #41
HonduhPowa
Member#: 269076
2012 Wrx
Great, thanks for the tip and diagram! If the wires are ran right into the factory horn wires, wouldn't that provide the power? Which means there wouldn't be a wire running to the battery nor' an "aftermarket" horn relay, as its running off the factory relay/wires?
The relay I'm hearing click is the factory one in the under-hood fuse box (or im assuming) but no sound out of the horns. I haven't had time to look at it much, or test the horns for power. I hate electrical -.-
Old 10-01-2012, 10:27 PM   #42
Joshubaru
Member#: 313858
2000 Impreza 2.5rs
If anybody needs some instruction on installation of these on older model impreza, I should be able to help. I installed these on my 2000 2.5rs, so if you need pics let's me know.
Joshubaru is offline   Reply With Quote
Old 10-01-2012, 10:32 PM   #43
JavaBot
Member#: 156723
17 2.5i foz dgm
rip wrx/rs/2.5i/foz1
need pics of installed... did the oem connections reach the normal mounting areas?
JavaBot is offline   Reply With Quote
Old 10-02-2012, 10:47 PM   #44
Joshubaru
Member#: 313858
2000 Impreza 2.5rs
I'll try to get the pics within the next couple of days. And repost. Also no the OEM connections did not meet, I had to extend them to my mounting points.
Old 08-21-2013, 01:45 AM   #45
MrLebreen
Member#: 344816
2012 Impreza 2.0i
can some one link me to where you actually buy the Hellatones from preferably the 118db ones
cheers
MrLebreen is offline   Reply With Quote
Old 08-21-2013, 08:38 AM   #46
CCSubaru
Member#: 203376
2014 BRZ Premium
cheers
You can get them from all sorts of places just google search "hella supertones"
Most popular place to buy from is Subimods and they have optional bracket/wiring harness you can get as well
CCSubaru is offline   Reply With Quote
Old 08-21-2013, 09:32 AM   #47
vision.dynamix
Member#: 139955
2015 Subaru STI
17Forester / 18Crosstrek
cheers
If you call them the right name, theres about a bazillion places you can find via Google.
Old 08-21-2013, 10:04 AM   #48
FL4TFTW
Member#: 256953
2014 Built DGM BRZ
Amazon has them for under $49 shipped for prime members.
Old 08-21-2013, 01:16 PM   #49
Teedub21
Member#: 333099
2013 WRX STi
ISM
Just ordered mine last night from Subimods with bracket and harness. Will be my first mod! A little leery about pulling the bumper on my brand new car, but I had the bumper off my 2011 5.0 twice, so it shouldn't be much different.
Teedub21 is offline   Reply With Quote
Old 08-22-2013, 03:43 PM   #50
jordan1989
Member#: 341580
2003 wrx wagon
It does make them louder. Without a relay, picture the sound of a horn from a older beetle, really high pitched and annoying. The relay tones this down alot and balances each horn (Low/High). If i am correct. This is the basic reason. Also the relay protects the circuit and power from the horns and prevents possible issues if a wire shorts that is not relay protected.
Correct me if i am wrong
jordan1989 is offline   Reply With Quote
Hella Supertones with custom (RPF1) machined grilles quadtard Exterior/Styling 9 10-17-2009 01:33 AM
The Official Hella Supertones Thread Ryanpm939 Member's Car Gallery 0 11-14-2008 02:47 AM
* HELP Hella Supertones Rubbing on my STi Grille ultraspdWRX Interior & Exterior Modification 13 10-14-2007 11:14 PM
What is the two red things behind the grill on some subys?? BBBsti LTD Member's Car Gallery 16 12-28-2005 09:34 PM
('93-'01) What the heck is this thing behind the wheels? Andrew Impreza Forum 18 07-08-2001 11:58 AM
