Tire & Wheel Forum sponsored by The Tire Rack |
02-19-2011, 11:41 AM | #1 |
Member#: 253836
Vehicle:2008 AW e90 M3 2011 WRX 350/365- sold :( |
235/40/18 vs 265/35/18 on 18x9 wheel
I'm looking to pick up 18x9 drag dr-31's for my 2011 wrx in the future. I am currently running stock suspension, but will be lower in the future. The reason I picked these two tires is so my speedo isn't off too much. These two are only .3% and .1% off respectively. I know 235 is considered a strech for a 9" wide wheel, but I feel like 265 is just too beefy and too much tire for me at the moment, I'm only stage 2 and the car is a daily, so it's not like I *need* all that tire for grip, I'm also afraid that I will have to deal with fender mods etc. even before I'm lowered (which will only create more problems) But I'm also scared that 235 is too much strech/ too little tire in terms of grip. I want the car to handle and look good without sacrificing the speedometer reading. Right now sways are going on soon and in the future, a drop by means of, so where should I go in terms of tire size? My ultimate goal is to make the car just an awesome DD, no tracking what-so-ever.
02-23-2011, 11:07 AM | #2 |
Member#: 253836
Anyone?
02-23-2011, 11:39 AM | #3 |
Member#: 97135
NWIC
what offset.
02-23-2011, 12:37 PM | #4 |
Member#: 266521
SCIC
Vehicle:08 Impreza WRX WR Blue |
have you looked at a 255/35/18?
02-23-2011, 12:40 PM | #5 |
Member#: 152220
Vehicle:2006 STI WRB |
gow ith 235/40/18 Pick the right tire and you will have plenty of grip.
02-23-2011, 12:44 PM | #6 |
Member#: 97135
NWIC
depending on the tire, a 235 has minimal to 0 stretch on a 9" wheel.
Again, what FITS will depend on the wheels OFFSET! |
02-23-2011, 01:34 PM | #7 |
Member#: 253836
Wheel offset is +38. So I think a 265 would either need a slight roll or just barely make it. But in terms of 235 (which is probably the size I'm going to pick) what brand should I look for? I hear good things about star specs.
02-23-2011, 01:38 PM | #8 |
Member#: 97135
NWIC
a 235 might require a slight roll in the rear, and moderate to aggressive camber settings. Federals and star spec's run about 1 size large, so keep that in mind when ordering.
a 265 will require a slight pull. |
02-23-2011, 02:12 PM | #9 |
Member#: 253836
Really? I guess I don't know much about wheel fitment after all. I though the widebodies can fit like 9.5's and bigger tires? Why would a smaller width and smaller tire need more work? Not trying to be sarcastic by the way, I legitametly am trying to learn.
02-23-2011, 02:57 PM | #10 | |
Member#: 97135
NWIC
02-23-2011, 03:21 PM | #11 |
Member#: 253836
Yeah, I new pull>roll in terms of work, but I was hoping 18x9 +38 w/ 235's meant no work x_x
I saw someone running a +37 18x9.5 w/ 265's slammed on coilovers and he said there was no fender work done. I don't mind doing a slight roll, but was really hoping to avoid camber work. |
02-23-2011, 03:24 PM | #12 |
Member#: 97135
NWIC
yea...that guy was lying about his fender work, or lied about his fitment. MachV Motorsports runs a 18x9.5 +40 with 265s, and they needed to roll....
Like I said though, the 235 *might* require a roll in the rear, but its possible you wont need to do anything. |
02-23-2011, 05:55 PM | #13 |
Member#: 224372
Vehicle:2004 WRX JBP |
IMO.....again IMO, if you have a 11' wrx/sti unless your running a low offset and or 18x10 wheels you shouldn't run a 235 tire. Not because performance, handling, blah blah blah But sunken wheels+semi stretched tires just doesn't look right
02-23-2011, 06:21 PM | #14 |
Member#: 163700
SCIC
Vehicle:2013 Impurzer wFc #270 |
235 isn't even stretched at all on a 9. Get a 245/40 otherwise.
02-23-2011, 07:30 PM | #15 |
Member#: 224372
235 does have a little stretch to it on a 9"....unless its federals or another similar tire i suppose. I'd say 255/35 if it were my car......again its just my opinion.
02-23-2011, 09:10 PM | #16 |
Member#: 257250
Vehicle:2006 Legacy Regal Blue |
Sorry to butt in, but on a 06 legacy, I'm putting 18x9.5s on the it and what size should I go, it's not lowered. I was thinking 235/40 but dont want them super stretched. Any insight?
02-23-2011, 11:16 PM | #17 |
Member#: 97135
NWIC
02-23-2011, 11:40 PM | #18 | |
Member#: 163700
SCIC
Really? Do some research first. If you actually read the previous 3 or so posts you would already know that 235/40 is not stretched at all. I run that size on my 9.5. hardly any stretch. And if you're not lowered or have extra camber adjustment then you're not gonna fit them. Legacy fenders aren't wide enough and you'll probably rub struts to. GL. |
02-24-2011, 11:19 AM | #19 |
Member#: 140163
Vehicle:03 STi hellaflunctional |
depends on the tire. jdmboy has 235 ad07s on his 18x9 g-forces and the sidewalls are not square like the 235 s.drives/federals on sc00by's 17x9s. i don't understand why because ad07s run wide.
got pics of your hardly-any-stretch 235s on 18x9.5s? |
02-24-2011, 11:37 AM | #20 | |
Member#: 163700
SCIC
I really don't think it's bad at all...and I hate super stretch. |
02-24-2011, 12:30 PM | #21 |
Member#: 97135
NWIC
my feds are 245's (more like 255's). The 235/40 s.drives were great, very subtle stretch. a 235 fed would probably have very minimal stretch on a 9.5 since they sit so square on a 9" wheel (all the pics I posted of 235/40 federals were from Grippy Monkeys car).
02-24-2011, 02:34 PM | #22 |
Member#: 10197
02-24-2011, 02:38 PM | #23 |
Member#: 97135
NWIC
it depends on the tire. some tires (like yours) obviously aren't a 235mm tire as advertised, but probably closer to 225. Where other tires (like federals or star specs) run much wider than advertised, closer to 245.
02-24-2011, 04:01 PM | #24 | |
Member#: 257250
02-24-2011, 04:04 PM | #25 |
Member#: 140163
fairly flush? you'll want a 255/35/18. good luck fitting that under your fenders without rubbing
FS/FT : 18x9.5 XXR 522 wheels W/ 265/35-18 | Always Broke | Wheels/Tires | 5 | 03-13-2011 10:10 PM |
255/35/18 vs 265/35/18 | rmarchigiani | Tire & Wheel | 11 | 04-18-2010 04:45 PM |
wtb: new or used 255/35/18 or 265/35/18 | thisisthenewsic | Private 'Wanted' Classifieds | 0 | 02-26-2009 06:25 PM |
Yokohama AVS Sport 2 225/40/18.....2 265/35/18 | 01G_WRX_02 | Wheels/Tires | 0 | 06-08-2008 05:38 PM |
Yokohama AVS Sport 2 225/40/18.....2 265/35/18 | 01G_WRX_02 | NESIC Private Classifieds | 0 | 06-08-2008 05:36 PM |
