Welcome to the North American Subaru Impreza Owners Club Thursday August 17, 2017
Old 03-10-2013, 10:17 PM   #1701
J_Maher_WRX
Member#: 290307
Originally Posted by jordanc15 View Post
I agree. I want a set. There like a sexy spin off of the work cr kai wheels. Excellent choice. I might have to get some down the line.
You know they are Rays right? Or am I misunderstanding what you mean by 'spin off' haha
J_Maher_WRX is offline   Reply With Quote
Old 03-10-2013, 10:59 PM   #1702
jordanc15
Member#: 276118
2011 WRX
I meant its a similar design to the cr kai but I think these are way better looking. They just look super crisp or something.
jordanc15 is offline   Reply With Quote
Old 03-10-2013, 11:27 PM   #1703
NWsoobie
Member#: 289516
2012 WRX
ISM
Yah I see that. I want a set in black chrome.
NWsoobie is offline   Reply With Quote
Old 03-11-2013, 09:32 AM   #1704
AHK
Member#: 237243
No roll.. I had an appointment to roll the day after I put them on but cancelled it because I am not seeing how they could possibly rub. I'll be keeping a VERY close eye and ear on things in the rear but no plans of rolling at the moment.
AHK is offline   Reply With Quote
Old 03-11-2013, 01:55 PM   #1705
leopard print
Member#: 313228
2012 WRX
18x9.5 +38. 255/35 Federal tires. Lowered on GTWorx/Bilstein and RCE Yellow combo. I rub slightly on bumps and hard turns so I'll need a slight roll.l
leopard print is offline   Reply With Quote
Old 03-12-2013, 02:07 AM   #1706
bluegill
Member#: 349656
Hello everyone,
I wanted to double check but I should be good to go on 17x9 +45 wheel along with 255/40/17 tire? Car is 2013 WRX hatch with stock suspension.
bluegill is offline   Reply With Quote
Old 03-12-2013, 03:30 AM   #1707
Deadserial
Member#: 344075
2013 Wrx
Satin white pearl
I'm putting 18x9.5 +35 with a 235-40-18 on tomorrow. Lowered on eibach pro kit. I have an appointment in the afternoon for rolling my rears so hopefully it's not too bumpy of a ride after I mount them up!
Deadserial is offline   Reply With Quote
Old 03-12-2013, 09:57 AM   #1708
chickeneye
Member#: 314909
2012 WRX hatch
Lightning Red
Just double checking..
18x8.75 +33 with 245/40's, stock suspension.
I assume a slight roll in the rear?
chickeneye is offline   Reply With Quote
Old 03-12-2013, 01:16 PM   #1709
NWsoobie
Member#: 289516
2012 WRX
ISM
Yes a slight roll will be needed in the rear.
Old 03-12-2013, 05:39 PM   #1710
johnmkv
Member#: 300848
2012 WRX
LR
Originally Posted by bluegill View Post
Hello everyone,
What wheels are you looking at the new enkei tanjins???
johnmkv is offline   Reply With Quote
Old 03-12-2013, 05:57 PM   #1711
Deadserial
Member#: 344075
2013 Wrx
Satin white pearl
18x9.5 +35 with a 235/40/18
Old 03-12-2013, 07:40 PM   #1712
bluegill
Member#: 349656
I'm thinking of the RPF1 in 17x9 +45 255/40/17 or if thats not going to work, I'm just going to go with Weds SA-55M in 18x8 +45 with 235/40/18
Old 03-12-2013, 10:14 PM   #1713
Duffie112
Member#: 331086
2012 wrx premium
satin white pearl
Is this stock suspension? Any rubbing?
Duffie112 is offline   Reply With Quote
Old 03-13-2013, 12:25 AM   #1714
Deadserial
Member#: 344075
2013 Wrx
Satin white pearl
Lowered just on eibach springs. Slight roll in the rear just to be safe.
Old 03-14-2013, 10:37 PM   #1715
kirch
Member#: 163875
Hey offset experts, I just sold my gd v7 and got a 2013 wrx. I'm now looking for my summer setup since I'll be using stockers for winter. By calling tirerack earlier today I was told that they have OZ Ultraleggera in ET35 in both 17*8 and 18*8. Since I have the stock rubbers I thought I would stay in 17 for now. I'm not looking to run anything too crazy, just something safe and reliable since I have a newborn now.
Before asking this question I sure did use the search this thread option and have read quite a bit of the thread... So, by running a 17*8 ET35, the wheel will stick out of 18mm and also have 18mm inner clearance more compared to the stockers based on 1010tires offset calculator. How will the wheel bearings do with the wheels sticking out more without having a wider wheel? Some friends of mine got their front right wheel bearing changed on waranty while running stock wheels so I assume there is some sort of weakness there.
Pretty sure 17*8 ET35 wouldn't rub and wouldn't need any fender rolling nor pulling. Just want to tripple check before making a move and order some wheels.
Big thanks
kirch is offline   Reply With Quote
Old 03-15-2013, 01:38 PM   #1716
kirch
Member#: 163875
Any comments or piece of advice on my last comment?
Like I said, just don't want to get into wheel bearing issues on the long term just to have a better "stance look" by having et35 wheels instead of 48.
Old 03-15-2013, 01:55 PM   #1717
Girion47
Member#: 240113
2010 WRB WRX 5dr
2013 DGM WRX 4dr
May be a dumb question, but could I use these on a 2013 WRX 4DR without any issues?(aside from the paint job)
http://forums.nasioc.com/forums/show....php?t=2475627
Girion47 is offline   Reply With Quote
Old 03-15-2013, 02:36 PM   #1718
NWsoobie
Member#: 289516
2012 WRX
ISM
Big thanks
You won't rub as long as your not running a crazy amount of meat. That wheel will be just shy of being flush with the fender. Your ok. Just run same size tire as factory.
Old 03-15-2013, 02:38 PM   #1719
NWsoobie
Member#: 289516
2012 WRX
ISM
17x8 35 won't have any wheel bearing issues. Need more width and a lower offset to start worrying about your wheel bearings.
Old 03-15-2013, 02:41 PM   #1720
NWsoobie
Member#: 289516
2012 WRX
ISM
Pretty sure your ok.
Old 03-15-2013, 02:42 PM   #1721
NWsoobie
Member#: 289516
2012 WRX
ISM
Sorry. Don't know how to combine all the quotes into one post on the iPhone app.
Old 03-15-2013, 04:03 PM   #1722
kirch
Member#: 163875
Thanks for the input NWsoobie, no worries about the multiple quotes in one post
Old 03-15-2013, 04:36 PM   #1723
sc00by4life
Member#: 97135
It's the opposite...narrow wheels and low offsets will flex the bearings more than wide wheels with low offsets. Also, as you move up in wheel width you'll inherently need a lower offset.
However, there has been no real world proof that wide/narrow wheels and low offsets will cause premature failure.
Old 03-15-2013, 05:16 PM   #1724
NWsoobie
Member#: 289516
2012 WRX
ISM
Interesting.
Old 03-15-2013, 07:38 PM   #1725
sc00by4life
Member#: 97135
Interesting.
its all about load distribution.
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
