04-26-2011, 08:00 PM | #1 |
Member#: 205698
Electrical Distro Box for Guages
Im going to pre-face this by saying this is not going to be for a Subaru but I can see applications for it being that way
I have an idea about making an electrical distro box for gauge and minimal power use accessories to make it easier for installs. Basically it has a power and ground input on the sides or back, but on the actual face itself, it will have "Outlets" to plug gauges into. Heres a VERY rough sketch on what its going to look like: --------------------------------| Neg (-) | 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0| | | | | Pos (+) | 0 0 0 0 0 0 0 0 0 00 0 0 0 0 0 | -------------------------------- (post formatting might not make it look like a box, but it has one line of pos one line of ground terminals) Basically the Pos is coming from a 12v accessory line and the Neg is just grounded. All terminals are wired in parallel and they will have screw like connectors (think as in the back of a receiver for speaker connections). Does this at all seem logical or am I over engineering something? I just HATE using vampire clips to tap into a 12v line when I have a free connection.
04-26-2011, 08:05 PM | #2 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
there are ALL SORTS of 'free" connections if you look for one.....and the NEG is as simple as finding a chassis bolt
04-26-2011, 08:13 PM | #3 |
Member#: 205698
I understand. The car I'm working on for a friend has a basically "free" connector to where I can hook my 12v to. All its there for is to be tapped with a female spade connector. I already have a ground point with a 12ga cable so it would be strong enough for multiple things. I'm just looking to do a clean install where additional components can be added with minimal work. I am 100% against vampire clips.
04-27-2011, 01:24 AM | #4 |
Member#: 16200
then get power from the bloody fuse box and be done with it
04-27-2011, 11:57 AM | #5 |
Member#: 16495
South East
Vehicle:2017 Impreza Sport Blue |
Similar setup I used on my STI, with the exception of adding a 30A relay and dedicated + % - lines to the battery. I was able to keep the cig lighter hot all the time and clean power for stereo, gauges, and under seat subs (using the relay and acc on). Radio Shack has all the parts including project boxes to mount the contact bars.
04-27-2011, 05:08 PM | #6 |
Member#: 205698
The car Im working on is a S2000 so the options are going to be a little different then a Subaru. The main goal of this is to have the "Box" be hot when the car is on, not from the battery.
Distro box/ignition switched question | Krems | Electrical & Lighting | 1 | 07-02-2009 07:47 PM |
Autometer electric EGT and BOOST guage | soobieWRX06 | Interior/Dressup/Audio & Security | 1 | 04-06-2007 12:41 AM |
Want electrical boost/oil pressure guage, dual a-pillar pod | ursmother | Private 'Wanted' Classifieds | 3 | 03-09-2005 08:22 AM |
FS: 12" MTX 8000 sub in box and box for 2 12s | dman918 | Mid West Subaru Owners Club Forum -- MWSOC | 1 | 01-15-2004 04:47 PM |
Electrical vs. Mechanical Boost Guage | desertwagon | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 03-05-2002 02:41 PM |
