06-07-2011, 04:40 PM | #1 |
Member#: 246246
Stuck at inital IAM!
2006 STi is always stuck at whatever initial IAM value is! No matter what I do mild pulls, hard pulls, it won't budge!
I set initial IAM to 1 & flashed the ecu, but IAM showed up as .5 Anybody experienced something similar?
06-07-2011, 04:49 PM | #2 |
Member#: 144147
South East
The IAM is a learned value the ECU sets the IAM at .5 and goes up after that. How long are you waiting between the times you are checking it? You might want to try the trick in one of the stickies How to gain 10 HP in 2 min. Good luck.
06-07-2011, 06:14 PM | #3 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
did you undo the green connectors after flashing?
j/w |
06-08-2011, 04:40 AM | #4 |
Member#: 246246
Yes I tried every trick in the book to no avail, it's been stuck at .5 for weeks now & I can't force it to be 1. The green connectors are always undone after flashing. I noticed that after some reflashes, IAM shows up as 0 even though initial is set to .5 & it also sticks at 0 & never go up.
I had a similar case some time ago with a 16bit ecu with IAM also sticking at the initial value of 8 |
06-08-2011, 05:48 AM | #5 | |
Member#: 212154
South East
Vehicle:02 billet crank pauter rods, pt5857, E85 |
06-08-2011, 05:47 PM | #6 |
Member#: 246246
IAM is always stuck at 8!! | leforce | Open Source Reflashes | 12 | 04-26-2011 02:28 PM |
I need a drives haft Sti or at wrx! ASAP STUCK AT E TOWN!! | Chandy69 | Tri-State Area Private Classifieds | 4 | 06-08-2009 09:54 PM |
Stuck at work bringing up a server at 5 am... | HellWagon | Texas Impreza Club Forum -- TXIC | 2 | 04-15-2004 07:44 AM |
cv joint just broke iam stuck at work!! | grndc2gsr | Southern California Impreza Club Forum -- SCIC | 26 | 12-05-2003 06:36 PM |
cv joint just broke iam stuck at work!! | stephenmeade | Off-Topic | 0 | 12-04-2003 07:27 PM |
