Welcome to the North American Subaru Impreza Owners Club Friday October 20, 2017
Old 03-19-2013, 06:26 AM   #2151
Antiharper
Member#: 350489
09 Impreza 2.5i
Originally Posted by fedex23 View Post
I've seen this before also & he is correct.
Crazy! I didn't know that. Why would the waste the tooling cost to make a die to stamp if they weren't multi fit? Ah well time to shop again. Thx guys!
Antiharper is offline   Reply With Quote
Old 03-19-2013, 09:55 AM   #2152
wrx2630
Member#: 290232
2011 STI Sedan
year:2011
model:STI (sedan)
wheel model: Forgestar F14
wheel size/offset:18x9 in a +40 offset or 18x8.5 offset between +40 - +50
tire size:245/40/18
suspension : stock
fender mods: not willing to role
spacers: dont want to get spacers
Would both sizes fit and not have to do any extra mods? Whats the lowest offset i could without modding fenders and or without spacers?
wrx2630 is offline   Reply With Quote
Old 03-19-2013, 01:44 PM   #2153
sc00by4life
Member#: 97135
Originally Posted by wrx2630 View Post
year:2011
model:STI (sedan)
tire size:245/40/18
suspension : stock
first - if you do NOT want to do fender mods, dont worry about "whats the lowest offset/widest i can go". stop even THINKING about that.
both would fit, the 18x8.5 would fit BETTER and let you run close to same tire options as a 9" wheel.
Old 03-19-2013, 03:51 PM   #2154
gamma1232
Member#: 249493
2005 STi
Year: 2005
Model: STi Sedan
Tire Size: 255/40/R18
Suspension: Stock
Fender Mods: don't want to roll
Spaces: don't want spacers
What kind of wheel width and offset do I need to fit a 255 tire without causing the centers of the tire to bulge or have rub within the wells or struts? I was looking at the offset thread but it didn't have offset ranges for anything above 8".
gamma1232 is offline   Reply With Quote
Old 03-19-2013, 04:14 PM   #2155
gunghoman414
Member#: 336427
Year: 2012
Model: WRX Limited
Suspension: Stock
Fenders: Huge Roll in rear fenders
Spacers: None
Wheels:Rota g-Forces 18x9e35 (Flat Black)
Tires: Federal 595s (255/35/18)
gunghoman414 is offline   Reply With Quote
Old 03-19-2013, 05:02 PM   #2156
littlewhitewagon
Member#: 103068
11 STI sedan
Originally Posted by gunghoman414 View Post
Year: 2012
Model: WRX Limited
Suspension: Stock
Spacers: None
No roll detected in pictures.
littlewhitewagon is offline   Reply With Quote
Old 03-19-2013, 05:03 PM   #2157
littlewhitewagon
Member#: 103068
11 STI sedan
Originally Posted by gamma1232 View Post
Year: 2005
Model: STi Sedan
Suspension: Stock
That tire size isn't going to work for you. 255/35R18 is about where you want to be. All comes down to your budget as certain wheels come in certain sizes. 18x9 around the +40 range is what will fit within your requirements.
Old 03-19-2013, 05:37 PM   #2158
wrx2630
Member#: 290232
2011 STI Sedan
thanks, im not thinking of getting a low offset at all, I was just told that +40 offset would not need any mods wanted to make sure it was true
so I have a 245/40/18 tire I take the 18x8.5 size what would be the best offset to get for a stock height/fenders etc, the options are +40 up to +50?
I assume +50 since its closest to stock but what would look the best or there wouldnt really be a difference?
Thanks again in advance
Old 03-19-2013, 05:49 PM   #2159
gamma1232
Member#: 249493
2005 STi
Ok cool, if I stuck with a 17x9 wheel could I maintain a 40 or 45mm sidewall? I would rather have beefier sidewall than a larger diameter rim. With a 35 I'm concerned ill have a rougher ride and be more prone to damaging the wheels on the ****ty NJ roads I drive on.
Old 03-19-2013, 06:22 PM   #2160
sc00by4life
Member#: 97135
sidewalls aren't measured in millimeters.
understand how tire sizing works, and this all starts to become much clearer.
Old 03-19-2013, 06:44 PM   #2161
gamma1232
Member#: 249493
2005 STi
I see, let's try this again.
Assuming I stay with a 17" wheel I've gained 24ish mm of space for the sidewall which should allow me to fit a 255 tire with an aspect ratio of up to 45 and still maintain an overall tire/wheel diameter similar to the 255/35/18 tire that littlewhitewagon proposed. Is my reasoning correct?
Old 03-19-2013, 06:47 PM   #2162
sc00by4life
Member#: 97135
No. a 255/45/17 is an inch taller than a 255/35/18. a 255/40 would be right on the money though (both being ~25.03").
with a 255/40/17 vs a 255/35/18 you'll gain roughly a half inch of sidewall.
Old 03-19-2013, 06:53 PM   #2163
gamma1232
Member#: 249493
2005 STi
Oh right, forgot to double the increase in sidewall. Was only thing about a gain for half the tire...derp. thanks for the info...much appreciated!
Old 03-20-2013, 12:55 AM   #2164
gunghoman414
Member#: 336427
these pictures were taken the day of installation.. the roll happened 2 days following installation.
Old 03-20-2013, 01:55 AM   #2165
eastcoastimprezz
Member#: 336922
2005 Impreza OBS
Silver/ Charcoal
year: 2005
model: Impreza Outback Sport
wheel model: xxr 526 hundred dollar deeps
wheel size/offset: front- 17x9/35 rear-17x10/20
tire brand/model: nexen n7000
tire size: 255/40/17
suspension: rokkor tuning coilovers (I'm aware it's cheap, but it's in the budget)
alignment: stock
fender mods: willing to roll, no pull.
spacers: no idea if I'll need them! This is my main question!
other details: I want a meaty look. I just want to make sure that everything listed will fit together nicely with little to no complications. Any help would be wonderful! Thanks in advance!
eastcoastimprezz is offline   Reply With Quote
Old 03-20-2013, 02:48 AM   #2166
sc00by4life
Member#: 97135
Originally Posted by eastcoastimprezz View Post
year: 2005
alignment: stock
first things first.
Search.
Staggered fitments are a HORRIBLE idea.
Secondly...you are stacking **** parts upon **** parts upon **** parts. Stop. Save. Do things properly. ESPECIALLY if you are on a mcdonalds budget.
Read. Keep reading. Both of those stupid sizes are far from "little to no complications".
Stop looking at parts. Start reading, and learning. And save up.
Old 03-20-2013, 08:48 AM   #2167
Antiharper
Member#: 350489
09 Impreza 2.5i
first things first.
Search.
I second this. Staggered are a bad idea. If everything isn't perfect you may unintentionally burn out center dif. You will also suffer performance and handling wise. If that's the case why not just buy a camero cheaper more muscle and goes in a straight line.
Old 03-20-2013, 01:49 PM   #2168
wrx2630
Member#: 290232
2011 STI Sedan
on a 245/40/18 tire, STock sti 2011 what would the best offset be to look/fit the best
18x8.5 size option for offset are anywhere from +40 to +50
Old 03-20-2013, 06:55 PM   #2169
patburns101
Member#: 316797
Could a WRX awd system handle a tire size difference?
For instance wheel size 18x8
tire size 235/40/18
Can I run 215/35/18 with some stretch on the fronts and leave the 235/40/18 rears? Or will this throw off my awd system?
patburns101 is offline   Reply With Quote
Old 03-20-2013, 07:02 PM   #2170
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
It will destroy your center differential. Probably quickly.
Counterfit is online now   Reply With Quote
Old 03-20-2013, 07:13 PM   #2171
patburns101
Member#: 316797
It's that sensitive...WOW. I guess a staggered set up is definitely out of the question haha
Old 03-20-2013, 08:30 PM   #2172
Counterfit
Member#: 124254
"The Scoobinator"
Those sizes give you a ≈50 revolution difference per mile.
Old 03-20-2013, 08:58 PM   #2173
eastcoastimprezz
Member#: 336922
2005 Impreza OBS
Silver/ Charcoal
first things first.
Search.
I appreciate the help, not so much the hostility.
My budget has increased since I started working full time. I bring in 2k a week, so no need for harsh words.
I got what I could afford at the time being.
I know the rims are cheap. I never said they were not. But they fit the style I'm looking for.
Instead of bashing, why not give me some alternatives? I came here to read and learn and get some advice from people with similar issues.
Old 03-20-2013, 09:02 PM   #2174
sc00by4life
Member#: 97135
2k a week yet you also say "Rokkor coils" are the only thing in your budget.
Cheap wheels. Cheap coils. Cheap tires. You aren't ballin. You don't have to lie, in fact it's better to honest with yourself.
You bought the wrong wheels. Sell them and find something else. Read this thread, the offset thread, and the several fitment threads in members car gallery top to bottom.
Old 03-20-2013, 09:39 PM   #2175
bboylocob
Member#: 151809
2007 WRX
So u bring in almost 100,000 a year and went that cheap. Wow.
I'm on paramedic pay which for what I do the pay sucks. And I don't even go cheap. Yea I have xxr's but they are my dd wheels to bash up on the roads here. Track is differ set up.
bboylocob is offline   Reply With Quote
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
