Welcome to the North American Subaru Impreza Owners Club Saturday November 18, 2017
Old 02-20-2001, 10:41 PM   #1
SUV-ETR
Member#: 1310
2000 Impreza 2.5RS
BRP
Post G-Stock Solo-II exhaust & brakes?
I don't want to steal the thunder from the other two auto-x threads going on right now, but I am looking for very specific recommendations for a GS auto-x'er. I'm already planning on some KYB AGX struts, a K&N filter, and a better alignment. However, I really don't know what to do about a cat-back exhaust or brake pads.
Exhaust: Everyone seems to talk about exhausts in relation to aftermarket intakes. Since I can't do anything with the intake, what is the best exhaust when combined with the stock intake? Unlike all the other threads in the other i-club forums, I'm more interested in even better mid-range torque and flexibility than a peak HP increase near redline.
Brake Pads: What are the best brake pads for the stock system? I really love the Ferodos I use on my VW, but I haven't heard of any RS owners using them...if they're even available. The idea is to get pads that grip well when cold and come up to operating temp very quickly, unlike road race pads.
Thanks in advance!
Neal
SUV-ETR is offline   Reply With Quote
Old 02-20-2001, 10:48 PM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Exhaust-- use a 2.25" midpipe and any straight-through 2.25" muffler. I have a Borla turbo muffler, but I have no illusions that something even cheaper or conversly more expensive (and better looking) would make a dramatic difference.
If you can get something light, bonus. For that reason I'd avoid the Scoobysport, nevermind the >$500 pricetag.
ColinL is offline   Reply With Quote
Old 02-21-2001, 05:41 AM   #3
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
Post
I doubt that you will find much better braking for Autox than the stock pads. Some may tell you otherwise, but I don't know a single person who ever experienced brake fade in a autox run. Having said that, I have ebc greens. They're ok, I guess.
---Roy
LUME is offline   Reply With Quote
Old 02-21-2001, 06:27 AM   #4
JayP
Member#: 3125
2001 Mustang Bullitt
Post
Usually the trade off for performance pads is the operating temps. The stock pads are designed to work cold.
I wouldn't bother upgrading to any performance pads until the stock pads are toast.
JayP is offline   Reply With Quote
Old 02-21-2001, 08:57 AM   #5
autorex
Member#: 3677
Post
I know alot of people run SuperTrapps for exhausts. Two reasons, they're light, and you can tune the discs or just run without them.
autorex is offline   Reply With Quote
Old 02-21-2001, 09:09 AM   #6
subrew2
Member#: 2883
2004 STi
Silver/Gold
Post
I've been running in the Oregon Region SCCA for a couple years, in g-stock.
Exhaust:
I built a cat-back 2.25" exhaust using a cheap dynomax universal muffler. I was after mid range bump, as opposed to top end only.
Brake pads:
I'm still running the stock pads. I have found that even with 225/50-16 Kumhos on smooth tracks, i get quite a bit of ABS action, or if the fuse is pulled (generally keeps abs active) I can too easilly lock the fronts. Have never experienced fade.
hope this helps,
Chris Hartman www.subrew.com
subrew2 is offline   Reply With Quote
Old 02-21-2001, 11:43 AM   #7
10th Warrior
Member#: 2230
2000 2.5RS
Silverthorn, PGT #671
Post
having driven STiShawn's car with the mintex pads, they definetly provide better bite than the stockers. sure, fade isn't a problem with either, but the better initial bite would help a little, though nothing that significant since the braking zones are so short anyway.
10th Warrior is offline   Reply With Quote
Old 02-21-2001, 12:22 PM   #8
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
& 08 Triumph Speed Triple
Post
I think you can modify the stock intake , but you have to leave the air box in. I believe a k&n filter charger and a ganz flow intake are legal as they leave the stock box in place. That was the impression i got form a guy with Equipe Rapide, they use SCCA rules for classes.
Josh
scoobiejosh is offline   Reply With Quote
Old 02-21-2001, 03:58 PM   #9
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
Post
Yup. The resonator MUST stay. You can change the tires, the struts (as long as they don't alter ride height), the plugs, the lubes, the filters, the plug wires, the exhaust (cat back only).... uh, what else... oh, you can remove the spare, jack, and trunk floor. Um, thats it. Even if we had adjustable timing (spark, that is), it still has to be within factory specs....
--Roy
PS. At my last autox, my 00 RS took 1st in Gstock with only A032s on Locos.... Unfortunately, I wasn't driving.
Old 02-21-2001, 06:42 PM   #10
Chris F
Member#: 494
2008 EVO X
Post
Well here's my 2c. I ran in GS last year at Nationals, fastest stock class Subaru. Finnishing 25th. may not sound like much, but concider the pax v. other subaru finnishers and it was a good run. I use the Stromung dual tip because it gives the best midrange and good high end power. For brakes I used some of Cobb Tuning's special pads. They are great, I tried the Ferodo's and they worked well but I did not think they manipulated well. The stock pads can fade on Nationals style courses (fast). Just my 2c. Good Luck, I am off to run SM this year.
Chris
Chris F is offline   Reply With Quote
Old 02-21-2001, 08:59 PM   #11
SUV-ETR
Member#: 1310
2000 Impreza 2.5RS
BRP
Post
Thanks for all the replies!
It seems like a 2.25" aluminized-steel cat-back exhaust may be the trick. I really like the sound of the Stromung, but if it is just as fast, I might go for something less expensive, like an UltraFlo.
Anyone know where I can get just a 2.25" mandrel-bent mid-pipe to go along with a generic muffler?
No, I haven't experienced fade often in an autocross, but it has happend on several occasions. I definitely felt some at the ProSolo last weekend, since you do back-to-back runs frequently. In addition, it's a two-driver car. Opie (Will) somehow even managed to boil his brake fluid...though I'm guessing he may have been over-braking.
Neal
[This message has been edited by SUV-ETR (edited February 21, 2001).]
Old 02-22-2001, 01:19 AM   #12
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
Josh, that's not allowed in stock. No intake modifications beyond swapping out the air filter element for something of a different material is allowed in stock.
Strepto is offline   Reply With Quote
Old 02-22-2001, 01:48 AM   #13
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
Post
ic, by those rules you cant even remove the resonator?
Josh
02 WRX stock cat-back exhaust & intake stuff. make offer resideinva MAIC Private Classifieds 2 06-06-2008 04:49 PM
02 WRX Stock Axle Back Exhaust & Stock Struts w/ Whiteline Springs epicurux Private 'For Sale' Classifieds 0 01-09-2006 09:22 PM
03 stock WRX Turboback exhaust & uppipe WRX469 Private 'For Sale' Classifieds 53 11-18-2004 04:40 PM
A-Stock Solo II Tire choices Watkinsm3 Motorsports 27 01-05-2004 12:23 PM
Optimum WRX setup for D stock Solo II? Shankster Motorsports 18 06-08-2002 09:08 AM
