Welcome to the North American Subaru Impreza Owners Club Wednesday November 22, 2017
Old 10-10-2011, 09:48 PM   #1
Scubaru23
Member#: 255582
Default Reverse Only
I have a 1999 Subaru Impreza - Outback edition. I have an automatic transmission and I can't go into anything besides reverse. This has happened before and I just waited for about 15 minutes and then it worked. It happened earlier this day and it still won't go in. I have no clue what to do or even where to start. Any help/ideas would be great!
Scubaru23 is offline   Reply With Quote
Old 10-11-2011, 03:20 PM   #2
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Just to be clear: you're pulling the gear selection lever back and it only goes back 1 notch to R? What about one more notch to Neutral? Also with the key in ACC possition and the engine off do you hear the shifter locking solenoid when you tap on the brake pedal? If not its likely that the solenoid isnt activating and your unable to use other gears for good reason.
TommyAtomic is offline   Reply With Quote
Old 10-13-2011, 04:43 PM   #3
sense of nature
Member#: 112759
2004 Stock OEM AsFu*
FoZZY SexyRP
If it will physically go into drive 1 2 or 3 then its a Stuck accumulator , there is a trans conditioner from Subaru ( MOC)that helps fix it, sometimes takes 2 or 3 treatments
If your unable to physically select the drive gears then your linkage is prolly binding ( cable rusted)
sense of nature is offline   Reply With Quote
rear wheel grinding in reverse only Jamesdak Brakes, Steering & Suspension 4 07-22-2009 02:30 PM
Mechanical help needed.. 96 Outback in reverse only peterdaniel Service & Maintenance 1 04-22-2008 11:37 AM
Reverse only noise sperry7 Brakes, Steering & Suspension 4 04-26-2007 11:09 PM
No Forward, Reverse Only sgarcia Transmission (AT/MT) & Driveline 5 07-02-2006 01:07 PM
