10-18-2011, 09:16 AM | #1 |
Member#: 257434
NESIC
Vehicle:2011 BMW 328xi LeMans Blue |
Oil Temps...Too High?
So, i have taken a look at some other threads relating to oil temperature but none has satisfied exactly what I want to ask. I have an '05 wrx custom tuned to 19 psi on stock TD04, motor built (CP pistons, sti rods, acl bearings....etc etc). When hitting stop and go traffic especially my oil temps go up quite a bit. I would have to say my normal operating range once warmed up is between 180-200 DF but sometimes it will climb to 220-260. Is this getting too hot or just on the warmer side of operating temps??
**would also like to add my oil temp probe is below the alternator on the top galley plug
10-18-2011, 12:52 PM | #2 |
Member#: 80649
South East
Vehicle:2000 2.5 Auto-X RSTi Sparkly |
180 to 200 is normal, and even up to 210 in traffic. I never saw more than 230 at an autox/PDX day though so your 260 reading seems high. I'd check and see if the oil cooler is in place and plumbed correctly.
Alternatively get an aftermarket cooler. |
10-18-2011, 03:24 PM | #3 | |
Member#: 81633
Vehicle:'98 RS-T Blue |
10-18-2011, 03:37 PM | #4 | |
Member#: 250152
Vehicle:2006 WRX Limited OBP |
10-18-2011, 09:42 PM | #5 |
Member#: 184505
E. Canada
Vehicle:2003 WRX Sonic yellow |
What weight of oil are you using?
10-20-2011, 09:45 AM | #6 |
Member#: 257434
NESIC
I think 5-w30 but i would have to check when i got home to be absolutely sure
Oil loss - Is my oil pressure TOO high? | Ryan314 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 24 | 11-13-2014 11:27 PM |
oil temp too low? | bako | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 12 | 10-18-2010 01:44 PM |
Liquid cooling installed. mobo temp too high? | StealthfishWRX | Off-Topic | 10 | 09-08-2005 10:22 PM |
Water Temp Too High ... HELP ! | alfcanada | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 01-08-2005 01:19 PM |
CE Light with EGT Temp Too High??? | shaowen | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 01-17-2002 11:38 AM |
