10-27-2011, 07:34 PM | #1 |
Member#: 99543
South East
Vehicle:2015 STi Launch Ed. 2002 WRX Wagon (222k mi!) |
oil light on '02 wrx
Red oil light is just *barely* glowing. Unaffected by lights on/off/dimmer.
Is this a short...? Does glowing a tiny bit note a problem thats not bad enough to be fully lit? ?
10-27-2011, 08:55 PM | #2 |
Member#: 22412
SWIC
Vehicle:2024 Legacy Sport |
Check your oil level - the oil light comes on when there is basically no oil pressure. If the oil level is fine, then the oil pump could be going - try using a pressure gauge to measure the actual oil pressure and see if the sender is going, or if you really have no oil pressure.
10-27-2011, 10:31 PM | #3 |
Member#: 99543
South East
If i had no oil pressure, would I get a CEL?
Oil level is great, just a smidge above full dot. Is the sender an electronic item accessible from outside the engine? |
10-27-2011, 10:35 PM | #4 |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
Your oil pressure is fine, you have a bad connection from sensor to block. Usually caused by corrosion or moisture. The sender is below the alternator on the top of the block. Remove, clean and reinstall.
If you had low oil pressure (the light comes on at 2.1psi) the light comes ON. |
10-27-2011, 10:36 PM | #5 | |
Member#: 79643
NESIC
Vehicle:2021 STI TE Terminal black pearl |
Oil level is only 1 factor in no pressure. The sensor is under the alternator. |
10-27-2011, 10:37 PM | #6 | |
Member#: 79643
NESIC
10-27-2011, 10:40 PM | #7 |
Member#: 99543
South East
Well that makes sense. Run it for a day and see if moisture evaps or should I replace / fix connection?
Top radiator hose blew last week, sprayed off coolant carefully with car running. Where do I look for this? |
10-27-2011, 10:44 PM | #8 |
Member#: 99543
South East
Cool, thx guys
10-27-2011, 11:17 PM | #9 |
Member#: 99543
South East
The 2-prong elec plug going straight down into the engine? Left of center of the altenator?
10-27-2011, 11:26 PM | #10 | |
Member#: 79643
NESIC
It should be right under the alternator, I don't remember how many wires but it's threaded directly into the block. |
10-28-2011, 08:55 AM | #11 | |
Member#: 99543
South East
http://www.flickr.com/photos/subyjoe...7627996485078/ |
10-28-2011, 08:58 AM | #12 |
Member#: 99543
South East
10-28-2011, 09:15 AM | #13 | |
Member#: 79643
NESIC
10-21-2012, 04:37 PM | #14 |
Member#: 266288
International
Vehicle:2002 WRX STG II PSM |
bringing this one up from the dead. did removing, cleaning and reinstalling correct the issue because im running into a similar problem with my 02 wrx now. I had the top radiator hose blow but that was almost four months ago now. guess ill try this tomorrow and see what i come up with.
12-22-2019, 07:27 PM | #15 |
Member#: 491788
I just experienced the exact same issue, blown radiator hose and dim oil light. Thank you so much for the insight friends.
12-23-2019, 06:53 PM | #16 |
Member#: 460860
Vehicle:2003 WRX Blue |
This happens in my car after heavy rain. Moisture gets in the connection to the sensor under the alternator. Letting the car warm up and evaporate the moisture makes the light go away.
Oil Separator leak on '02 WRX w/226,000 miles | ktmhk53 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 10-07-2011 05:44 PM |
can someone help me? on the side of the road oil light on | harrisont | Southern California Impreza Club Forum -- SCIC | 22 | 02-08-2009 11:28 AM |
Wrx Cel And oil light on???? | elementsk8trbam | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 08-28-2006 04:53 PM |
Rally Innovations light bar from GC8 fit on '02 WRX | snhuxc | Electrical & Lighting | 3 | 12-05-2005 05:53 PM |
WTB: Driver's side fog light for '02 WRX | larryg | Private 'Wanted' Classifieds | 4 | 11-19-2003 06:30 PM |
