11-22-2011, 11:03 PM | #1 |
Member#: 117573
Excessive Oil consumtion ! valve guide ?
my car is burning ton of oil ! The valve guide have about 140k miles on them but my machinist check and said that they still in good condition . i change new seal twice still having the same problem .I just pull the manifold off today to look at the exhaust guide and almost all of them have oil around them. any help would be great
11-23-2011, 09:23 AM | #2 |
Member#: 199032
SWIC
Vehicle:04 UMS Tuned sti Turns out it's Black! |
I've been told by my machinist that a small amount of oil accumulation around that is normal...
11-23-2011, 09:31 AM | #3 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
have you done at least a compression or leak down?
have you pulled the turbo to see if those seals are leaking (provided you have a turbo car)? |
11-23-2011, 11:56 AM | #4 |
Member#: 117573
I have done all of the above . Everything check out fine. When I'm in boost the car puff a big cloud of black smoke .
11-23-2011, 12:30 PM | #5 |
Member#: 289606
Vehicle:06 WRX white |
what color are the valve stem seals on the exhaust?
11-23-2011, 09:42 PM | #6 |
Member#: 117573
the seal are blue on the exhaust brown on the intake super tech seals. brought the head to anther shop they guy said the same thing the guide are still in good condition. funny thing is that all 4 cylinder burn oil.
11-24-2011, 02:41 AM | #7 |
Member#: 289606
I've never used the Supertech seals. It could be a bad set of seals.
11-24-2011, 08:58 AM | #8 |
Member#: 170439
Vehicle:I <3 Lamp |
Have you looked into a bad turbo seal or an improperly set up crankcase ventilation set-up?
11-24-2011, 04:08 PM | #9 |
Member#: 170602
Vehicle:06 Wrx RWD Auto 76MM-AEM-2200's |
^thats something to look into as well.
11-25-2011, 02:01 PM | #10 |
Member#: 117573
Yea I have check all that ... I have used oem seal as well same problem. That why I'm clueless
11-26-2011, 12:49 PM | #11 |
Member#: 126526
SCIC
Vehicle:2007 STi Limited #339 UGM -SOLD |
I agree. You may want to check and make sure your PCV system is working properly. It sounds like your crankcase is building pressure and its forcing oil out thru the exhaust guides.
11-26-2011, 01:11 PM | #12 |
Member#: 226211
Vehicle:2002 impreza WRX JDM blue |
PCV system hoses tend to harden by the age due to heat and they somehow make worst seal on connections. can it make vacuum leaks in ventilation system>pressure in crankcase>oil burning?
when I was reassembling pcv hoses, they were hardened like a plastic and they were loose on connections |
11-26-2011, 01:56 PM | #13 |
Member#: 64908
Vehicle:10.8 XT+9.2@155 GR+ 9.1/157mph 2015 STI |
PCV is probably your problem
You check the valve stem to guide clearance? Valve guide issues are usually noted when the car sits at idle for a while and you rev it. It will billow smoke. |
11-26-2011, 04:23 PM | #14 | |
Member#: 241953
Vehicle:02 hybrid/6speed 01 2.5 RS sedan |
How much oil are you burning? Like in 1k miles.... Black smoke =fuel Blue smoke = oil White smoke/steam = coolant /water |
11-27-2011, 04:15 AM | #15 |
Member#: 117573
my pvc system is vented to the atmosphere. i got 2 line from the valve cover and one from the pvc nibble . I check the guide to valve clearance and it about .003-.004 thou . I also looked at the valve today all 4 cylinder burn oil pretty evenly .The carbon build up is on the valve face not on the stem so it probably not the guide. maybe thru the ring ? compression and leak down are good
Oil weeping from header: valve guide? | REX8 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 06-12-2009 07:50 PM |
oil consumtion? | mufflerman69 | Service & Maintenance | 15 | 02-27-2009 02:16 AM |
Ferrea 4G63 Valve Guides/Locks/Valve Stem Seals | ITSME4G63 | Non-Subaru Stuff | 0 | 02-07-2007 11:02 AM |
Oil consumtion 05 OB | Mr.Sparkle | Outback Forum | 23 | 12-23-2005 09:55 AM |
UDP installed and excessive oil consumption? | ColinL | Technical Forum Archive | 11 | 10-03-2000 09:11 AM |
