Welcome to the North American Subaru Impreza Owners Club Wednesday June 19, 2019
Old 12-01-2011, 01:28 AM   #1
07STifastashell
Member#: 291793
2007 STi Dom built
*sold*
Default JDM sti key works
Well I managed to score an easy yet fulfilling upgrade for my sti interior I researched around a little bit before buying this key only to find that it might not work with my car due to the immobilizer. I went ahead and bought it anyways.
Sure glad I did! I realized (as previously thought) that as long as the original key (with the smart chip) is within a certain range of the ignition, then the car will start up just fine, no different from using the standard key. I simply hang my original key on the same hook and have had absolutely no problem with it on my 2007 sti. I bought this key off rallysportdirect.com, http://www.rallysportdirect.com/STI-Subaru-JDM-Key although I'm sure you can buy it from plenty of other places.
As for actually carving the blank, I went to Home Depot (maybe not the best bet, but I took a chance) and had no problem. Although the employee had to run it through the machine twice, it came out nearly perfect looking and in perfectly working condition. You could also go to a locksmith or Subaru Dealership, but I'm not sure if they will charge or not. Home Depot didn't charge me a cent I definitely recommend this key as a simple upgrade that replaces the ugly and boring standard key.
07STifastashell is offline   Reply With Quote
Old 12-01-2011, 01:32 AM   #2
bjf498
Member#: 136774
2005 Impreza STI
It's been done before. I just cut the chip out of my keay and glued it in my remote.
Also. It's not really a jdm piece the 04 Sti had that key.
bjf498 is offline   Reply With Quote
Old 12-01-2011, 01:37 AM   #3
07STifastashell
Member#: 291793
2007 STi Dom built
*sold*
I was actually thinking about doing that, but this is pretty much just as easy because I had room for another key. Yea agreed, not JD. That's just what RSD calls it. It's authentic Subaru-made though. Close enough.
Oh and also, I've seen some people take open the lock/unlock remote and put the chip in there, which I think is actually a really good idea haha.
Old 12-01-2011, 03:21 AM   #4
bjf498
Member#: 136774
2005 Impreza STI
Yeah I did that for a while it gets old quick.
Old 12-01-2011, 04:15 AM   #5
davidmount
Member#: 173026
2003 WRX
Good deal, just don't lose the original key.
davidmount is offline   Reply With Quote
Old 12-01-2011, 06:51 AM   #6
infinite012
Member#: 74392
15 Foz
I like my key moar bettarer
infinite012 is offline   Reply With Quote
Old 12-01-2011, 07:04 AM   #7
DSRX2005
Member#: 271681
2013 WRB Subaru WRX
AJW Performance
Soo if you have this key, your old key (with the chip) always has to be near or in your car?
I got this key a real long time ago and thought i never had any problems with it. My old key has always been in my center console without me even thinking about it.
So if i take my old key out of my center console.. The new JDM key won't work??
DSRX2005 is offline   Reply With Quote
Old 12-01-2011, 07:22 AM   #8
klarowe
Member#: 284753
2004 WRX STI
World Rally Blue
Another way to do it (although it may not be the best solution as it will disable your immobilizer securtity) is to go on amazon or somewhere online (can probably also find it at your local best buy) and pick up a DEI 556u / 556UW universal immobilizer bypass and put your chipped key into the bypass. Then connect it as follows:
Bypass wire:~~Wire in Car:
Red~~~~~~~~Black/White (+) keysense (may differ with different years/makes)
Black~~~~~~~Chassis Ground
Blue~~~~~~~~Chassis Ground
Then connect the immobilizer ring and run it up and around your ignition barrel.
This will activate the universal bypass by the keysense (when you insert the key). For added security you can install a switch on any of the above wires so that it will bypass only when you want it to.
Just a thought...
klarowe is offline   Reply With Quote
Old 12-01-2011, 07:15 PM   #9
07STifastashell
Member#: 291793
2007 STi Dom built
*sold*
Haha! That's pretty funny. Depends on your year. I know they had this key on 04 sti...but then in 05, I think they put an immobilizer in the car.
Old 12-01-2011, 07:34 PM   #10
05bluesti
Member#: 251804
05 WRB STi
Tried this and no luck
If the immobilizer chip isnt in the same exact position, the car starts then dies immediately
anyone have same problem and know how to fix it??
05bluesti is offline   Reply With Quote
Old 12-01-2011, 08:04 PM   #11
07STifastashell
Member#: 291793
2007 STi Dom built
*sold*
That's odd. The thing I'm wondering is...where is the immobilizer and how far can the chip be away from it to work?
Old 12-01-2011, 08:58 PM   #12
05bluesti
Member#: 251804
05 WRB STi
I've heard about the chip needing to be near the green light circle around the ignition, I pulled chip outta extra key and put in key fob thing, no cigar tho
At least I know the immobilizer works tho
Old 12-01-2011, 09:26 PM   #13
07STifastashell
Member#: 291793
2007 STi Dom built
*sold*
Haha yes, it works quite well! But actually sometimes when I try to use my unchipped key, it just does not want to work but other times, even if in the exact same spot as before, it works perfectly. Chipped key remains in the same place and this remains a mystery to me of why it doesn't work every time haha
Old 12-01-2011, 10:23 PM   #14
DSRX2005
Member#: 271681
2013 WRB Subaru WRX
AJW Performance
Hmmm well I do have a 2005, this just isn't something I've ever thought of. So i guess it's just a good thing that i never took my old key out of my car! I'm glad I never clean out my center console!
Old 12-01-2011, 10:54 PM   #15
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Only the 32bit cars have immobilizers. IE not yours. 04+ STi and 06+ WRX.
Old 12-01-2011, 11:15 PM   #16
bjf498
Member#: 136774
2005 Impreza STI
05+ Sti actually the 04 is where this key comes from it does not have the immobilizer.
The chip in my remote works but my remote is the only thing on my key ring other than an Sti fob and the key (all on one ring) so my remote is very close to the ring of doom.
Old 12-02-2011, 05:55 AM   #17
And70
Member#: 171055
2001 STI Wagon
2nd Top Scoob #22
considering how that key was designed for the New Age GDB/A in 2000 I'm not quite sure how it's not a JDM piece ?????
And70 is offline   Reply With Quote
Old 12-02-2011, 06:18 AM   #18
jxkim
Member#: 239150
2003 WRX Sedan
i don't think its worth carrying the extra key. even though i have the same one
jxkim is offline   Reply With Quote
Old 12-02-2011, 06:54 PM   #19
tuzzio
Member#: 292532
05 STI
I'd just tape the original key under the dash, and then never lose it or worry about it not working with the sti key. Also, thats not "jdm" per say, because my usdm 04 sti uses that key, and the dealership sells them.
tuzzio is offline   Reply With Quote
Old 12-02-2011, 06:58 PM   #20
xevash
Member#: 229132
2006 WRX Limited
SRR
You'd tape a key to your car under your dash?
xevash is offline   Reply With Quote
Old 01-10-2015, 01:39 PM   #21
sub_man
Member#: 370487
I have a programmable blank jdm Subaru key if anyone needs one.
Thanks.
sub_man is offline   Reply With Quote
04 JDM STI key use on 06 STI ? MoMoZzz Vancouver Impreza Club Forum -- VIC 12 06-04-2009 01:08 PM
04 JDM STI key use on 06 STI ? MoMoZzz Electrical & Lighting 0 06-03-2009 08:43 PM
JDM STi key for 05 STi or no?? SoareS Newbies & FAQs 50 08-29-2005 11:57 PM
sti key works for the gc8 also scubydrew New England Impreza Club Forum -- NESIC 2 06-02-2003 08:30 PM
STi key work for legacy? Sobelizard109 Legacy Forum 10 01-20-2003 03:36 PM
