Welcome to the North American Subaru Impreza Owners Club Thursday April 19, 2018
Old 01-10-2012, 11:19 AM   #1
Needablk07
Member#: 188216
2006 STI
Default 2.5 RS Motor Swap HELP
So i recently purchased a 2005 R.S with some engine nosie. The pervious owner said it might be rod knock, so i am looking into swapping/rebuliding the motor. My question is i have someone selling a 2008 2.5 impreza non turbo motor. I know the motor in my RS right now is a ej25, if that 2008 has the same motor will it be a direct swap??
Also i would like to know what other motors will swap right into that car without having to change anything really big out. Thanks.
Needablk07 is offline   Reply With Quote
Old 01-10-2012, 12:42 PM   #2
TravisL
Member#: 288101
Don't entirely take my word for it as I was swapping into an older 02' outback but this is what I think you'll run into.
The 08' will have the same short block, I'm going on a bit of a limb in saying the 05' is also an ej253 same as the 08'. What I know should be different is the i-avls that the 08' is equipped with, you would have a headache trying to make it operate exactly as it did form the factory. You could also build a controller for it and run it in a dumbed down rpm based state only, from my reasearch it's in high lift mode alot more than it is not.
I would think just about any SOHC EJ25 would be a fairly straight forward swap, just swap intake and possibly cam/crank gears so the triggers remain the same for your ecu. EGR stuff might be a little different, but should be fairly easy to sort, was in my case.
You could also use the 05' non-i-avls heads on the 08' ej253 short block I believe. Only reason I'm not certain on that is the ej251 heads will not work on a 253, but I'd like to think 253 non-iavls heads will fit and clear valves/pistons on an iavls engine(should).
TravisL is offline   Reply With Quote
Old 01-10-2012, 03:08 PM   #3
Needablk07
Member#: 188216
2006 STI
Thanks for all the help. I am pretty sure the two cars have the same motor in them. The motor out of the 08 i am going to try and get the ECU and engine harness so if i have both ECU and harness it should just be a direct swap correct??
Old 01-10-2012, 03:24 PM   #4
GEE-OTTO
Member#: 201277
2008 08 QSM 5MT LGT
QSM
A hot dip, line bore, cyl hone and possible decking with reassembly (new bearings, rings, seals, gaskets) would cost around the same as buying a newer engine and paying swap all the bits over (MAF, manifolds, heads) and then having to place trust that newer Short Block wont crap out on you 15K miles down the road.
If it is running with knock there is a good chance you can reuse most of the internals
GEE-OTTO is offline   Reply With Quote
Old 01-10-2012, 03:39 PM   #5
Needablk07
Member#: 188216
2006 STI
Ok thanks for the help. So basically pull the motor and see what we are working with?? But If i get a new motor swap with 29K or so on it with the ECU and harness would it just drop right in??
Old 01-15-2012, 03:25 PM   #6
Needablk07
Member#: 188216
2006 STI
Need some more help. Got someone selling a ej255 shortblock. Will the heads from my 05 r.s bolt up?? Need to know my options. Thanks for the help.
Old 01-17-2012, 12:20 AM   #7
Needablk07
Member#: 188216
2006 STI
Need some advice thanks.
Old 01-20-2012, 10:11 PM   #8
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
What is your current engine code? EJ251 or EJ253, you can find it on the driver side strut tower on a plate that is riveted to your strut tower.
Do you have AVLS heads?
~Josh~
Old 01-21-2012, 08:29 AM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
AFAIK any '99-'05 Impreza or Forester 2.5L, and any '00-05 Legacy 2.5L will be the same. The '08 engine is different in that it has the newer i-AVLS heads (variable lift), so it would not be a direct swap into your car. You might be able to use the shortblock from the '08 with your '05 heads/intake/sensors. See TravisL's comments about EJ251 vs EJ253.
I'm no expert on the various iterations of the SOHC motors, but I think all of this is correct.
That assumes the ECU and harness tie into the body harness in the same way, which is unlikely since you're talking about two different generations of Impreza.
Yes, they'll bolt up, but you'll end up with a low compression ratio due to the dish in the turbo motor's pistons, so the engine would be a bit of a dog.
He shouldn't. 2006 is the first year with the i-AVLS on the 2.5i.
Old 01-21-2012, 05:06 PM   #10
Needablk07
Member#: 188216
2006 STI
Thanks for all the responses. I am fairly sure that the engine code is EJ253 for the motor that is in the car right now. The motor i want to buy has a label on the front of the timing cover with the first 5 characters EJ253 which also matches the label on the current motor that is in the car now. So my questions if the codes are the same would it be a simple swap if i had the motor, harness and ECU for the new engine?? Thanks.
Old 01-22-2012, 06:34 PM   #11
Needablk07
Member#: 188216
2006 STI
Anyone??
Old 01-22-2012, 07:37 PM   #12
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
If the engine codes are the same they should swap however you should swap your intake over to the new engine because the wiring may be different. You cant just swap the ecu because the wiring may be different between engine and ecu.the easist way is to swap intake. that shortblock should work also with your heads and intake.
Old 01-22-2012, 11:12 PM   #13
Needablk07
Member#: 188216
2006 STI
Intake meaning the throttle body, intake piping and filter?? If I have the ecu and harness for the new engine and the codes are the same and it is a usdm motor and car I should be set than right??
Old 01-22-2012, 11:26 PM   #14
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Intake means that metal thang that bolts to the top of both heads. If you use that and the wiring harness from your old motor it should work. the ecu will be different from 05 to08 the wiring may be different also so to avoid problems use your old ecu, intake and engine wiring harness.
Old 01-24-2012, 03:00 PM   #15
Needablk07
Member#: 188216
2006 STI
So the full intake manifold??
Old 01-24-2012, 03:46 PM   #16
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
No, just because both say ej253 does not mean that they are the same. The shortblock will be the same but the heads/sensors/accessories might be different depending on the year/model of the donor car.
Have you had a mechanic confirm that you even have rod knock? I wouldn't take the POs word for it.
geronimo81 is offline   Reply With Quote
Old 01-24-2012, 04:04 PM   #17
Needablk07
Member#: 188216
2006 STI
Got yea. Thanks for the help. It's out of an 08 Impreza. So I am guessing the newer model will have different sensors than the 05 Impreza rs?? Haven't had anyone confirm it but I am in automotive school, spoke with my instructor and he said from what I am hearing that it is a main bearing problem. I was thinking about dropping the oil Pan to take a better look but honestly if I can get another lower mileage motor for a low price and drop it in I feel it's a little less headache. Than take the bad motor out and take my time and see what the real problem is.
Old 02-23-2012, 10:16 AM   #18
Needablk07
Member#: 188216
2006 STI
Need a little more help. Got the new motor and everything ready to go in and it was the new 08 motor has valve timing on the cams. The motor that came out doesn't. I have been reading swapping the heads is a quick was to fix that but i just want to drop the motor in. I have the full engine to cabin harnness and the ecu. Just swapping those harnesses out will work??
Old 02-23-2012, 12:09 PM   #19
5k077
Member#: 128235
2007 WRX
Just swap the heads. Less headache.
5k077 is offline   Reply With Quote
Old 02-23-2012, 12:20 PM   #20
Needablk07
Member#: 188216
2006 STI
That's what I am finding out. Now if I have a spun bearing you think the heads might alright to reuse??
Old 02-23-2012, 12:23 PM   #21
GrundleJuice
Member#: 165749
With an 07 engine/ecu it would. The 08 uses a whole new ecu type and protocol so it might not be comparable with thw chassis side. Not 100% sure, though.
That would require machining the heads and deck to true. Not just a slap em in and go, thing.
Lesser of two evils I guess.
Old 02-23-2012, 12:40 PM   #22
Needablk07
Member#: 188216
2006 STI
If I can get the complete firewall harness for the 08 2.5I will it swap right into the 05 .
Old 02-23-2012, 06:44 PM   #23
DiagTech
Member#: 176286
2000 Impreza OBS-T
Matte Black/Beige
Swap the block, clean the heads up and be done with it. Labour time will be a fraction of swapping engine/electronics.
DiagTech is offline   Reply With Quote
Old 02-23-2012, 07:22 PM   #24
Needablk07
Member#: 188216
2006 STI
Yeah sounds like what I am going to do. Thanks for the help. What should the cleaning consist of?? Should I take the heads to a machine shop and have them make the call?? Also what else should I be replacing on these ej253 engine?? Thanks for all the help.
Old 02-23-2012, 08:00 PM   #25
DiagTech
Member#: 176286
2000 Impreza OBS-T
Matte Black/Beige
You want to search head gasket replacement. Many people have many different methods. I would replace required gaskets, clean block/head mating surfaces, wash the heads well if there is metal in the oil.
WTT 02 wrx motor or ej20h For stock 2.5 rs motor sti=heaven Private 'Wanted' Classifieds 0 07-29-2009 12:51 AM
2.5 RS T or 2.5 RS Sti swap V3rdug0 Newbies & FAQs 3 03-09-2006 02:44 PM
fs:99 2.5 rs motor drift king Private 'For Sale' Classifieds 10 03-04-2005 03:33 AM
1998 2.5 rs motor dohc on ebay turbocolin Tri-State Area Forum 0 09-28-2004 02:35 PM
WTB: WRX or 2.5 RS motor CatchMyDrift Private 'Wanted' Classifieds 13 06-13-2004 12:04 PM
