Welcome to the North American Subaru Impreza Owners Club Wednesday May 23, 2018
Old 01-14-2012, 09:51 PM   #1
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
Default same CEL twice, at the same time?
My car is throwing the p0420 code, most likey caused by my bad cat converter.
The scanner i have says code 1 of 2, and it tells me i have p0420 both times.
What do you think this means? Maybe both o2 sensors are bad, or getting bad readings?
I hope its just the scanner being weird and i just have one CEL problem. I know i have a bad cat which would give the secondary o2 sensor a bad reading. If the primary o2 is bad, then i got problems, lol. Maybe a head gasket problem, if it burns oil, and the oil cakes up the sensor. Idk maybe im just being a little parnoid, but let me know what you think.
ManualOverAuto is offline   Reply With Quote
Old 01-14-2012, 10:35 PM   #2
NH8991
Member#: 197937
2016 Golf R
Under the radar silver
One is probably the code when it was pending, i.e. the ECU was waiting to see if it registered another 'event' before throwing the CEL, the other is the confirmation of that 2nd event i.e. when your CEL came on.
Whether your cat is gone or it's a sensor issue I couldn't say.
NH8991 is offline   Reply With Quote
Old 01-14-2012, 10:45 PM   #3
ManualOverAuto
Member#: 304662
Sedona red Pearl
Ok, that makes sense.
and I know for a fact i have a bad cat. Costs $800 and doing that sometime next month. Just hope thats all.
thanks
Old 01-15-2012, 03:23 AM   #4
RolySaul
Member#: 294005
Sorry for barging into your thread, guys, but I thought because it's only a day old I won't be dredging up old threads, and it's directly relevant (I think) to your post. I'm totally new, and it won't let me post a thread yet, so I'm begging for someone to give me a boost sort of thing. I'm just trying to get some response from guys who sound like they know a heck of a lot more about it than me.
I've been trying to do the right thing and search as much as I can through other threads about this issue, but I'm coming up with conflicting information, and seeing as how you guys are discussing this tonight I thought you might not mind if I tagged along sort of.
I'm throwing p0420 also, on an '07 totally stock rs wagon which has been maintained absolutely mint all the way up to 143,000 which is where it is now, and that leads me to the 1st totally noob question that I hope sort of fits in here: Is expert maintenance and proper fuel system oversight going to prolong the life of the cat or the sensors, or do they last a predictable amount of time or miles, or do they just fluke out and fail whenever due to manufacturing errors and the like?
I guess my point is I know the previous owner maintained this car to the hilt, and spared no expense eliminating any problems immediately, does this mean that I have better chances of the cat being good for longer??
Again lads, sorry for the hijack, but since I have no posting privileges yet I thought this thread sounded like a maybe-not-get-booted way to post my questions.
Thanks
RolySaul is offline   Reply With Quote
Old 01-15-2012, 10:18 AM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
[A]nd I know for a fact i have a bad cat. Costs $800 and doing that sometime next month. Just hope that[']s all.
$800?! I assume that's for the OEM part? There are much, much cheaper options on www.rockauto.com. There's not a snowball's chance in hell I'd pay $800 for a cat pipe.
I assume you've already replaced the O2 sensors? When you say you know you have a bad cat, how is that? Is the catalyst bed broken up inside (and you can hear it rattling around)?
Not really.
Pat Olsen
Patrick Olsen is online now   Reply With Quote
Old 01-15-2012, 11:45 AM   #6
ManualOverAuto
Member#: 304662
Sedona red Pearl
[quote=Patrick Olsen;36128365]$800?! I assume that's for the OEM part? There are much, much cheaper options on www.rockauto.com. There's not a snowball's chance in hell I'd pay $800 for a cat pipe.
That price is parts and labor. Probably a little steep still.
Old 01-15-2012, 12:33 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
The cat pipes are notoriously hard to replace, particularly on a New England car, because the fasteners are pretty much guaranteed to be rusted solid.
If you can find a fellow NESICer or two to help, though, you could at least wipe out the labor part of that bill.
Old 01-15-2012, 01:08 PM   #8
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
$800 seems pretty high considering the cost of the materials, but I always do the work on my cars so my view of what things should cost is skewed. I think you should give some thought to upgrading to a set of stainless headers and cat section of your choice. You have to do more leg work, but you could save some of your hard earned money.
~Josh~
I've never had 2 bigger dogs at the same time before. They are going AT it. Neek Off-Topic 37 01-11-2010 10:41 AM
This Makes me Sad and Happy at the same time :| MidnightSti05 Off-Topic 1 04-01-2008 03:40 PM
Playing 2 games on the same TV at the same time! Mattr762 Off-Topic 31 01-19-2005 07:29 PM
4 Sti's at one place at the same time! zuczek Canada Region Forum 0 08-19-2004 02:48 AM
can i wire the car so the fogs and brights run at the same time? jpsimon Electrical & Lighting 3 05-15-2003 10:28 AM
