Welcome to the North American Subaru Impreza Owners Club Friday September 21, 2018
Old 01-21-2012, 08:31 PM   #1
Vinny G
Member#: 211173
2016 WRX Premium
Default Overheat
I have a 05 rs, and yesterday I was venturing home in the snow/ice and lost control and hit a curb. My fog light bulb burned out and my wheels are slightly out of alignment, but my main concern is my car is starting to overheat ever so slightly. Its happening at low speeds, and when sitting still. Cruising is fine, especially with the heat on. Does anyone know what my problem may be?
Thanks
Vinny G is offline   Reply With Quote
Old 01-22-2012, 10:14 AM   #2
Spigatelli
Member#: 306391
2005 Outback 2.5i
Check the fans. One of the electrical connections may have come undone or a wire may have broke.
Spigatelli is offline   Reply With Quote
Old 01-22-2012, 11:28 AM   #3
Vinny G
Member#: 211173
2016 WRX Premium
That's what I'm thinking. I can't hear them turn on when sitting still.
Old 01-30-2012, 09:51 PM   #4
Vinny G
Member#: 211173
2016 WRX Premium
So after 2 weeks, I've had no problems, and its been cold so I've had heat/defrosters on all the time. but Tonight I got a little warm in my car so I turned the defroster/foot heat off and came to a red light. I was talking to my friend in the car next to me, and I looked to see my temp rising. I turned the heat and defrosters back on and it stopped climbing when it hit the 3/4 slash mark. Once I started to accelerate again the temp dropped back to normal so I drove with the defrosters on all night again and it didn't happen again.
Old 01-31-2012, 09:51 AM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Other than listening for the fans, have you done any actual troubleshooting or investigation? Have you popped the hood to see if the fans are cycling properly while the car is stationary? Is the radiator fully topped off? Does the overflow reservoir have the correct amount of fluid in it when the engine is hot and when the engine is cold?
Old 01-31-2012, 06:05 PM   #6
Vinny G
Member#: 211173
2016 WRX Premium
Radiator cap isn't getting pressurized. Fans come on when it reaches temperature. Did a leak test, not leaking. My head gasket appears to be leaking oil.
Old 02-01-2012, 07:07 PM   #7
Vinny G
Member#: 211173
2016 WRX Premium
And head gaskets appear to be leaking oil
Old 02-01-2012, 07:15 PM   #8
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
As Pat alluded to, your overheating may be from an air bubble in the cooling system. But how did the air bubble get there? If the issue is indeed air in the coolant, it could be from the radiator cap or head gasket.
Or your oil leak may be incidental.
Old 02-06-2012, 03:49 PM   #9
Vinny G
Member#: 211173
2016 WRX Premium
I'm thinking it may be the illusive head gasket.
Old 02-06-2012, 08:13 PM   #10
surowrxa
Member#: 102895
'12 Forester
'17 Outback
Maybe, but maybe not. Our '99 Forester has had seeping external leakage from both sides for a few years now with no temp issues. It's gotten so bad I'm worried about the oil getting onto the exhaust, but no overheat/air in the system.
surowrxa is offline   Reply With Quote
Help car wants to overheat at idle seven881 Normally Aspirated Powertrain 5 03-16-2003 09:58 PM
Overheat problems Ti-REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-10-2003 11:48 AM
help overheat red of the sun Service & Maintenance 16 12-28-2002 11:25 AM
('93-'01) Engine Overheat, CE light problem Piusma Impreza Forum 11 06-04-2001 05:35 PM
Engine Overheat CRAZY KEN Normally Aspirated Powertrain 7 04-30-2001 07:04 AM
