Welcome to the North American Subaru Impreza Owners Club Friday November 24, 2017
Closed Thread
Old 07-27-2013, 03:48 PM   #22001
NWsoobie
Member#: 289516
2012 WRX
ISM
Originally Posted by cliff_11WRX View Post
Alot if not all of the forcewerks stuff is ripped off of HTAuto's stuff. So pretty much that diffuser will look very very similiar to the first one HTAuto made.
Yep. I've seen both in person and really couldn't tell a difference.
NWsoobie is offline
Old 07-27-2013, 05:35 PM   #22002
13whiteguywrx
Member#: 351622
2013 Wrx
Installed a intake on my wrx today nice little noise it makes.
13whiteguywrx is offline
Old 07-27-2013, 06:05 PM   #22003
JWHWRX112
Member#: 351928
2012 WRX Sedan
How do u like the K&N? Did u tune with it?
JWHWRX112 is offline
Old 07-27-2013, 06:47 PM   #22004
13whiteguywrx
Member#: 351622
2013 Wrx
No need for a tune yet. I like it so far going to flash over to stage one and see the difference though
Old 07-27-2013, 06:48 PM   #22005
13whiteguywrx
Member#: 351622
2013 Wrx
I like it I can already tell little bit more throttle response
Old 07-27-2013, 07:25 PM   #22006
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
You need a tune.
You've completely thrown off the mass air flow sensor by altering the intake piping. A correct tune will have MAF scaling to dial it back in.
Usually aftermarket intakes are larger piping, so slower moving air, so lower MAF readings, so less fuel. but since it's actually more air, now being given less fuel, you're leaning out an already incredibly lean tune.
blehhh is offline
Old 07-27-2013, 07:27 PM   #22007
13whiteguywrx
Member#: 351622
2013 Wrx
My buddy had it on his car for over a year without an issue. I will get a tune soon but it's not necessary unless you start changing such things as the DP, inter cooler and such, I asked several different Subaru specific shops in the area all with the same answer.
Old 07-27-2013, 07:29 PM   #22008
SIBorsellino
Member#: 320014
2012 Impreza WRX STi
Finally took off the roof rack, looks pretty slick. I'll see you guys at BNW tomorrow!
SIBorsellino is offline
Old 07-27-2013, 07:45 PM   #22009
Nighthawkra
Member#: 292655
2012 WRX limited
WRB pearl
Got her got her on the dyno today
First pull was about the same as this result, the second pull it dropped to about 277 hp 285 tq due to heat soak so after letting it sit for a while and spraying the IC with water, this is what it did
Nighthawkra is offline
Old 07-27-2013, 07:49 PM   #22010
Silwrx11
Member#: 354893
2011 Wrx
SSM
Originally Posted by blehhh View Post
You need a tune.
I completely agree! As long as hes driving like a 90 year old, he should be okay. I would get a tune quick bud!
Silwrx11 is offline
Old 07-27-2013, 07:58 PM   #22011
Rowrx11
Member#: 338312
You need a tune.
You recommend to use the stock air with panel filter cosworth on stage 2 2011 wrx? or.... a full intake ?
my setup:
process west tmic
synapse diverter valve
tsudo bellmouth downpipe
invidia n1 dual catback
protune 19-20 psi
Rowrx11 is offline
Old 07-27-2013, 09:14 PM   #22012
corvid
Member#: 300097
Well there you have it everyone, some guy was fine with putting on an aftermarket intake without tuning for it.
What are the names of the shops that told you it's okay to run an intake without a tune on this model?
corvid is offline
Old 07-27-2013, 09:34 PM   #22013
13whiteguywrx
Member#: 351622
2013 Wrx
Look smartass it's my car and I will do with it what I want.that being said I did not say it will work flawlessly without a tune yes it will run slightly rich. And i called several shops around the Charlotte Nc area . There specific words were with that intake they have not seen any 2008-2013 WRXs with issues. It's not running rich it's not boost spiking. I drive my car with care I don't thrash it around like some of you not saying you do.Yes I will have a tune soon but no it's not necessary. This is a picture thread not an opinion thread if I wanted your opinion I would have posted this in a different thread.
Old 07-27-2013, 09:35 PM   #22014
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
You're absolutely wrong on this one. Blehh was 100% correct. Any aftermarket intake (and possibly but less drastically certain aftermarket filters) on these cars requires a tune due to airflow differences.
Your friend might have had it on his car for a year with "no issues", but no apparent issues does not mean that he wasn't putting his engine at severe risk. As Blehh said, you're basically hoping that your ecu will adapt the fuel mappings to compensate for the lean conditions that intake will cause.
Again, no apparent issues does not mean that your car is not at severe detonation risk due to running lean.
nightdown fox is offline
Old 07-27-2013, 09:37 PM   #22015
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
Ah, that's a good point (you wouldn't be running rich, you'd be lean) but yeah, that's a good point, good luck!
Old 07-27-2013, 09:39 PM   #22016
corvid
Member#: 300097
Blow your engine for all I care, one less semi-literate idiot on the road with a wrx. Just don't spread your uneducated opinion for others to interpret as truth.
corvid is offline
Old 07-27-2013, 09:50 PM   #22017
13whiteguywrx
Member#: 351622
2013 Wrx
Will do. Not saying what I said is truth nor right. But my perception and measurements should be correct the maf is exactly In the same spot from the filter to the turbo inlet pipe also the tubing the maf sits in is 65mm oh wait that's the same as factory. By using these measurements the maf should be able to do its job and the ecu should be capable of making the corrections necessary. Like I said though I don't plan on running it wild or wot until I tune it. I'm just waiting on the tune may just use an AP to flash it for now.
Old 07-27-2013, 09:51 PM   #22018
J_Maher_WRX
Member#: 290307
You're a moron. Lol
Do some real research before modding your car, though why should you care if you blow your engine right...
J_Maher_WRX is offline
Old 07-27-2013, 09:54 PM   #22019
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Someone close this daytime drama story. It supports to be picture thread
Louie is offline
Old 07-27-2013, 10:09 PM   #22020
13whiteguywrx
Member#: 351622
2013 Wrx
Well I guess I need to do a bit more research. Call me a moron dumbass all day long it's okay doesn't offend me one bit. I am new to subaru and the way to tune them. Thanks for the advice I understand your trying to help. I will throw my stock box back on and go from their. Have a good Sunday. Just difficult to hear one thing and be told something else same day. Research time.
Old 07-27-2013, 10:10 PM   #22021
Rowrx11
Member#: 338312
Can anyone answer my question? Hahaha
Rowrx11 is offline
Old 07-27-2013, 10:25 PM   #22022
Nighthawkra
Member#: 292655
2012 WRX limited
WRB pearl
I can't but I do remember all the debates all the pros had on the forum a year or so back.. basically as far as cai n sf intakes are concerned... I think it was left that they don't do much more unless u get a pro tune for it. I ordered a Cobb sf intake with box mainly for the sound.. I don't expect a world of diffrence...
I had a guy at central fl turbo tell me today I'll get more hp from a stock IC to front mount ...
Old 07-27-2013, 10:45 PM   #22023
G-Sep
Member#: 346983
2013 13 WRX rolling
on oranges
Blam!
Red Sunset-4 by giuseppe.diflumeri, on Flickr
Interesting sunset last night with a rainbow! Had to try to get this in.
G-Sep is offline
Old 07-27-2013, 10:57 PM   #22024
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
Yeah man no worries, just research. The measurements you took don't take into account the piping differences and airflow in that intake versus the stock intake. MAF sensors on modern turbocharged applications are extremely tricky. It's one of the reasons why SPT stopped offering the intake for late model WRX/STIs. It's the same deal on the Mazdaspeeds that also use MAF sensors. The stock intakes on those cars are horrible, and aftermarket intakes actually give moderate gains... But with direct injection and no tune, the fuel pumps can't keep up. Now on the older SRT-4s with a MAP sensor, you can do an intake all day long with no tune... But it also doesn't net you any more power than stock. Generally, the Subaru stock intake is pretty well engineered, so intakes don't give any gains at stock+ levels (other than sound) but they have to be tuned for.
Stock intake is good for 350+ hp... But you're already at stage 2, and it's just a map swap away for an intake, so why not...?
Now that's an awesome pic man.
Old 07-27-2013, 11:05 PM   #22025
jjablo6
Member#: 265697
2015 STi
Ligtening Red
i noticed a huge difference in AFR when i went from COBB SF to AEM CAI.. i would get a tune just to be safe but to each their own
jjablo6 is offline
Closed Thread
('11-'14) 2011-2012 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 151 04-29-2014 09:35 AM
01-07 wrx and sti drivetrain? xj bmx Newbies & FAQs 13 01-26-2012 04:30 PM
('11-'14) 2011 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 1 11-17-2011 12:51 AM
Anyone have the 06-07 Impreza WRX and STI master part number and picture list STEALTH-WRX Interior & Exterior Modification 0 08-22-2008 03:12 PM
The Official World One STI and SEMA picture thread.. WorldOne Member's Car Gallery 25 11-29-2003 06:21 PM
