Welcome to the North American Subaru Impreza Owners Club Saturday July 21, 2018
Old 01-30-2012, 01:15 PM   #1
Mr_Furious
Member#: 298713
1997 Impreza, Wagon
Default Header HELL
So this weekend I installed a header on my 97 impreza with a 1.8l
following much advice that I read on various forums, I got a dual port for a 2.5rs.
To start I should say that I broke the factory exhaust manifold a couple of weeks ago and had to replace it.
Even the local Lordco parts shop said go buy one off ebay.
And I did.
But install was such a bitch.
the ports for the heads were about 1.5-2 inches too close together so I had to put one side on then stretch the other side to mount on the passenger side head.
that was fairly tough when you're lying on your back.
The gaskets were ok-ish but the holes on the manifold gaskets seemed about a 1/4 inch smaller than the ports. and the port on the gasket for the cat seemed about a 1/4 inch too big.
it all bolted up but I guess I'll have to see about any leaks.
Anyone else had this kind of fitment issue.
Secondly will there be any detrimental effects from the manifold gaskets being smaller than the ports. (wondering if i should have cut the holes bigger) Should I replace the gaskets or will it even matter
My concern is the gasket will burn off a bit and clog up the cat.
On the positive the car sounds better. and the butt dyno feels much more responsive.
Now I have to replace the rest of the exhaust with a catback. So the plan is to get a cheap wrx exhaust and do the flange modification to it so it will mount up.
I cleared the existing cel but have a new one. but I'll have to scan it to figure which code it is now.
Mr_Furious is offline   Reply With Quote
Old 01-30-2012, 09:47 PM   #2
5k077
Member#: 128235
2007 WRX
How did you manage this? My ebay header is the same way but I can't stretch metal :P
5k077 is offline   Reply With Quote
Old 01-31-2012, 12:17 PM   #3
Mr_Furious
Member#: 298713
1997 Impreza, Wagon
you have to loosen the cat/exhaust support to remove the old one by lowering it down first.
what I did is mount the cat to the header first.
then lifted the header up and put on the left/driver side and attached 1 bolt to hold it in place. loosely but securely.
then I turned to the side and pulled on the right side....It takes a fair bit of strenght and pulling but it will give a bit.
then when it was just about to mount I just got it on one exhaust stud put 1 bolt on it to hold it in place then attached the other bolts and slowely tightened them all till it pulled the flanges up to the heads and tightened them up.
on a side note I got a uel header....I don't know if a equal length header would be the same...but I'm sure it would be similar.
IN HINDSIGHT.....it would have been easier to make a wedge out of wood ....like a door stop and tapped it in between the two pipes to spread them....maybe this will work for you.
Breast Milk & Grown Men: Oh hell yes! VS Oh hell no! Asinine Off-Topic 74 06-05-2007 01:52 PM
MadDad(TM) Velocity Headers, GT Spec Gen. II Header, and XX Tuning Header Jard Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-21-2005 09:45 AM
How the hell do you get the header bolts off linux>windows Normally Aspirated Powertrain 17 09-22-2004 11:37 AM
installing gruppe-s headers today.. how the hell do i do it?! djcttb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 09-14-2004 11:28 AM
Headers, Headers and more Headers? Mr.Hanky Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 03-25-2004 07:25 PM
