Welcome to the North American Subaru Impreza Owners Club Tuesday February 18, 2020
Closed Thread
Old 02-03-2012, 06:53 PM   #1
DJNauTicz
Member#: 222133
1999 Impreza RS 2.5
Rally Blue
please close this post..made other one for correction
DJNauTicz is offline
Old 02-04-2012, 06:12 PM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
yes, intake leak at the turbo inlet will allow unmetered air into the engine.
that, along with the other issues indicated by the ecu:
P1012 (could not find this listed anywhere--double check it)
P1446 Fuel Tank Sensor Control Valve Circuit Low
P0113 Intake Air Temperature Sensor Circuit Malfunction (High Input)
P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P1491 Positive Crankcase Ventilation (Blow-by) Function Problem
could definitely cause the car to fail to run.
ride5000 is offline
Old 02-05-2012, 05:32 PM   #3
DJNauTicz
Member#: 222133
1999 Impreza RS 2.5
Rally Blue
ride : my car run's fine with no issue..only issue i'm having right now is whenever i plug the MAF it start then shut right down on me . that's my main issue i want to find out why..
will that turbo inlet leak cost that issue??
i need to fix 1 issue at a time that's why
Old 02-05-2012, 11:39 PM   #4
Dat8687
Member#: 243261
2004 WRX
Java black pearl
I think so on some cars this will occur. If theres a leak between the Maf and the turbo inlet this is probably your problem
Dat8687 is offline
Old 02-06-2012, 02:53 PM   #5
ineedasubaru
Member#: 215509
2003 Wrx
Orange
You sir have a vaccum leak. Its not your MAF. Its that hole in the turbo inlet.
ineedasubaru is offline
Old 02-11-2012, 04:37 AM   #6
DJNauTicz
Member#: 222133
1999 Impreza RS 2.5
Rally Blue
dont know yet...just got my inlet today..and will try to install it tomorrow and hope it help..i keep you guys update ..
Old 02-17-2012, 02:01 PM   #7
DJNauTicz
Member#: 222133
1999 Impreza RS 2.5
Rally Blue
ok..instal the inlet fixed one issue..still have code
p0102 after install inlet , now the p0102 is gone
p0113
p1446 and p 1491
Old 02-17-2012, 02:20 PM   #8
ScoobyNub
Member#: 269662
P0102 Mass air flow sensor circuit low input
P0113 Intake air temperature sensor circuit high input
^both are MAF codes, check the wires
P1446: P1446 Fix
P1491: make sure the PCV plug is plugged all the way in, if it is, buy a new one.
ScoobyNub is offline
Old 02-17-2012, 04:09 PM   #9
Haelan
Member#: 151045
2013 Subaru STI
CBP
Check the MAF harness plug. If one of the pins were to get bent or pushed back inside the plug it can cause P0102 and P0113.
Haelan is offline
Old 03-03-2012, 02:51 AM   #10
DJNauTicz
Member#: 222133
1999 Impreza RS 2.5
Rally Blue
after checked everything currently i only have
p0113
p1446 and
p1491 left thank you guys for helping me out ..
ScoobyNub: i checked all the wire's .i even use a tested to test it everything seen to be fine..
haelan: i started my car use a tested to test the MAF harness everything work's fine..
got light and everything..
i'm run out of idea what to do ..
is there's an IAT sensor in there in this car?
Old 03-03-2012, 03:44 AM   #11
skankzwrx
Member#: 191845
2008 848 Ducati RED
you're not running aftermarket intake are you?
skankzwrx is offline
Old 03-03-2012, 04:41 AM   #12
DJNauTicz
Member#: 222133
1999 Impreza RS 2.5
Rally Blue
skankzwrx : yes i am running an afater market intake..is a noname brand.
Old 03-03-2012, 08:39 AM   #13
quazimoto
Member#: 70395
You probably have the intake installed backwards with in turn puts the MAF sensor backwards.The IAT sensor is the amber bulb thing in the MAF sensor. Did this problem start after you just either installed or re-installed the intake?
quazimoto is offline
Old 03-03-2012, 02:00 PM   #14
DJNauTicz
Member#: 222133
1999 Impreza RS 2.5
Rally Blue
Nope , car was running fine untill like about 2 months ago mean while i was driving car just die on me since then it show that code
Old 03-04-2012, 04:22 AM   #15
skankzwrx
Member#: 191845
2008 848 Ducati RED
Hmm where did you buy the MAF sensor at? If you have life time warranty, replace it with another MAF sensor. Maybe the one you bought is bad
Old 03-04-2012, 04:30 AM   #16
DJNauTicz
Member#: 222133
1999 Impreza RS 2.5
Rally Blue
I try 3 maf same issue 1 new 2 used still having the same issue
Old 03-04-2012, 02:38 PM   #17
skankzwrx
Member#: 191845
2008 848 Ducati RED
Are you running the foam intake like the Perrin for an example or the AEM filter kind?
Old 03-04-2012, 05:15 PM   #18
DJNauTicz
Member#: 222133
1999 Impreza RS 2.5
Rally Blue
Aem type .
Old 03-12-2012, 02:56 AM   #19
DJNauTicz
Member#: 222133
1999 Impreza RS 2.5
Rally Blue
bump it back up
Old 03-12-2012, 02:58 AM   #20
XanRules
Member#: 157348
180+ IQ Genius
Mindset Lifestyle
Do you have a tune? Complete mod list?
XanRules is offline
Old 03-12-2012, 03:04 AM   #21
hoffmanEstates
Member#: 122043
04 wagonier
psm
idle air control valve? iacv if not check for voltage ground signal ect.....on the harness for maf
hoffmanEstates is offline
Old 03-12-2012, 03:05 AM   #22
DJNauTicz
Member#: 222133
1999 Impreza RS 2.5
Rally Blue
i took it apart cleaned . still the same..
Old 03-12-2012, 03:06 AM   #23
DJNauTicz
Member#: 222133
1999 Impreza RS 2.5
Rally Blue
as i know of..never been tune ,
MOD
05 wrx
with sti exhaust.
vf39 turbo
turbo inlet .
thats about it nothing major.was going to p ut a pink injector but didn't install it yet..
Old 03-12-2012, 11:13 AM   #24
hoffmanEstates
Member#: 122043
04 wagonier
psm
maybe time to get a laptop and tactrix cable and start diagnostics or a Snapon scanner
Old 03-12-2012, 12:51 PM   #25
XanRules
Member#: 157348
180+ IQ Genius
Mindset Lifestyle
MOD
05 wrx
with sti exhaust.
vf39 turbo
turbo inlet .
You need a tune yesterday.
XanRules is offline
Closed Thread
I go past a certain rpm and my car bogs out please help snwboard4life69 Off-Topic 49 12-20-2007 11:48 PM
Car bogs down & dies right after start up?? silence2-38554 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-14-2007 06:25 PM
were is the plug to turn off day time running lights please help tsubaru02 Electrical & Lighting 3 04-17-2005 08:13 AM
ATTN: who was the blue WRX 101N today right after SJ IN N OUT meet? pio!pio! Bay Area Impreza Club Forum -- BAIC 1 08-15-2002 02:32 AM
Starting the Car this Morning...after new plug install last night... dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-03-2002 07:10 PM
