Welcome to the North American Subaru Impreza Owners Club Sunday January 20, 2019
Old 02-15-2012, 01:59 PM   #1
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
Default oil filter adapter plate
I can't seem to find any posts about this but does anyone know for sure if a m20-1.5 oil filter adapter plate will work on a 07 2.5i, I do know that it works with wrx/sti's
alt14 is offline   Reply With Quote
Old 02-15-2012, 09:45 PM   #2
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
All EJ motors take the same oil filter, so if it works on one, it should work on another.
What do you want an oil filter adapter plate for?
CosmoTheCat is offline   Reply With Quote
Old 02-16-2012, 12:01 AM   #3
alt14
Member#: 271928
2014 WRX Limited
Not that I really need it but the other week my friends car was totaled and he gave me his oil temperature, pressure and boost gauge along with that adapter plate, thought id just give it a go for the hell of it without the boost gauge since I know it would only be a vacuum
Old 02-16-2012, 11:47 PM   #4
CosmoTheCat
Member#: 3409
98 My FMIC
Gotcha.
The only thing I'd be concerned with is the direction the wires/tubes come out of it.
Old 02-17-2012, 12:50 AM   #5
alt14
Member#: 271928
2014 WRX Limited
Next time I change my oil im going to test it out just to get an idea, he also gave me an oil relocation kit but I wasn't planning on using it
The good thing is they're all digital prosport gauges that are just wires, the sender for the pressure would be the only real problem that it sticks straight out from the plate but the plus on that is the plate has four ports and can also be mounded in any direction
Old 02-23-2012, 07:22 PM   #6
alt14
Member#: 271928
2014 WRX Limited
The threads fit but im not sure if the plates going to clear the timing belt cover
Old 02-23-2012, 10:49 PM   #7
GrundleJuice
Member#: 165749
on my 07 ej253 i did just this. there is plenty of room to mount the prosport sending units as long as you have the clock angle right. i can take a pic if you can't get yours to clear something.
p.s. i ran the sending unit wires up along the back of the fan housing with the fan wires. used all the same hold downs and clamps for a clean invisible install.
Old 02-23-2012, 10:50 PM   #8
alt14
Member#: 271928
2014 WRX Limited
Pictures would actually be great!
Mishimoto Oil Filter Sandwich Plate Adapter released! Mishimoto Vendor Announcements 0 02-04-2011 03:13 PM
FS : FS: BOV, Gauge pod, Boost gauge, Oil filter adapter plate blackspike85 Interior/Dressup/Audio & Security 49 12-11-2010 12:14 PM
Oil Filter Adapter Plate amitch45 Electrical & Lighting 5 03-22-2009 05:33 AM
Oil Filter Sandwich Plate Adapter for Sensors div Engine/Power/Exhaust 3 11-04-2008 04:46 AM
prosport oil filter adapter plate on 2007 wrx's ridestreet84 Impreza Forum 1 02-17-2008 09:11 PM
