Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 02-17-2012, 04:10 PM   #1
CAPTAIN1N5ANO
Member#: 252297
2002 WRX STI
MIDNIGHT BLACK PEARL
Default Sti Headgaskets On 2.5rs??
I have a 2001 2.5rs that the headgaskets were done 30K ago and are already leaking. Can I use headgaskets from a newer 2.5 turbo and will they last longer?? I had thought someone said this can be done. Thanks for the help.
CAPTAIN1N5ANO is offline   Reply With Quote
Old 02-17-2012, 04:23 PM   #2
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
i heard of it
here is my thread on the topic:
http://forums.nasioc.com/forums/show...5#post35281725
AliBenn is offline   Reply With Quote
Old 02-17-2012, 08:17 PM   #3
05-rsx
Member#: 101188
MY07 WRX Wagon
Just did both HGs on my 05RS (251 here in Aus) with 642s (STi HGs). No installation dramas. As far as how it runs - so far, so good.
They're 0.1mm thinner a side, which shouldn't cause an issue; after speaking to my mechanic (who has been working on Subarus for 25+years) he said you are doing well to get interference on the SOHCs.
Don't forget to have your heads machined - it will save you doing it again in the near future.
Whilst the engine is you also a good time to check (and replace if need be) timing belt, rocker cover gasket (I think that needs to be done anyway), spark plug seals, idler pulleys, clutch (I did the latter 4, the TB had only been done 2 years ago)
05-rsx is offline   Reply With Quote
Old 02-17-2012, 09:08 PM   #4
rhino6303
Member#: 181314
2005 Impreza OBS SRR
05 Legacy GT RBP
Yea it works. I have them on my 2005 obs. Have your heads machined and be sure that all surfaces are perfectly flat and clean. Use the gaskets that end in 642. Enjoy!
rhino6303 is offline   Reply With Quote
Old 02-17-2012, 09:35 PM   #5
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
exacty what the two posters above said. Did the same thing. Your CR is raised by 0.1 which in theory yields an extra 1hp as well
Old 02-17-2012, 10:37 PM   #6
jamal
Member#: 71875
yes absolutely use sti headgaskets on a 99-01 RS. 11044AA642
I can't believe the dealership still puts in POS graphite coated gaskets. Up until 09 only the phase 1 2.5 n/a motors got mls gaskets for some reason.
jamal is online now   Reply With Quote
Old 02-18-2012, 08:41 AM   #7
GrundleJuice
Member#: 165749
My 07 has MLS head gasket from the factory.
Old 02-19-2012, 01:33 AM   #8
Bluefoton
Member#: 141373
2008 2.5i-hatch -
^ do you have the part nr? Curious to see when they changed..
STi exhaust on 2.5RS Siluck2 Normally Aspirated Powertrain 8 10-17-2007 12:01 PM
My cgm sti hood for your 2.5rs cgm hood, and my cgm sti wing for 2.5rs wingless NYC Sti_ck_IT Private 'Wanted' Classifieds 15 08-16-2007 11:42 PM
what parts from wrx or sti work on 2.5rs???? whipito Normally Aspirated with bolt-on Forced Induction Powertrain 0 04-19-2007 04:37 PM
pretty new pictures - STi BBS on 2.5RS Fred South East Region Forum 29 09-09-2004 09:18 PM
