Welcome to the North American Subaru Impreza Owners Club Wednesday August 15, 2018
Old 02-22-2012, 08:23 PM   #1
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
Default Valve tap? *Watch video*
Sound is heard when the camera moves closer to the left and right sides of the engine (hood closed obviously).
Is this the Subaru valve noise or just our good ole noisy boxer engines?
The sound is a little higher pitch in real life but is constant. Always there no matter what. Heard on both sides of the engine.
My car has 108,xxx miles and I have not done the 105k valve train maintenance. I don't know how to check valve clearance and really don't want to pay someone to do it (just had all my belts, TB tensioner, water pump an thermo done, $$$$$$$!!!).
If this is the common Subaru valve noise or valve tap, is it bad? Hasn't ever seemed to get worse or better.
ManualOverAuto is offline   Reply With Quote
Old 02-22-2012, 08:35 PM   #2
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
I just did my valves and my engine sounds identical. I want to say it's the power steering pump that sounds like that.
cal_look_zero is offline   Reply With Quote
Old 02-22-2012, 08:50 PM   #3
ManualOverAuto
Member#: 304662
Sedona red Pearl
Can't be because I can hear the noise specifically on the left AND right sides of the engine. Power steering pump is near the middle I believe, atleast the fluid container is.
Old 02-22-2012, 09:01 PM   #4
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
With your ears, or a mechanic's stethoscope?
Old 02-22-2012, 09:09 PM   #5
ManualOverAuto
Member#: 304662
Sedona red Pearl
Ears.
Old 02-22-2012, 10:04 PM   #6
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Ok, put a little faith in someone who has rebuilt about a half dozen of these engines. It's not valve noise. I can't say exactly what that noise is, but it's too distinct to be a valve tick.
Old 02-22-2012, 11:22 PM   #7
ManualOverAuto
Member#: 304662
Sedona red Pearl
Ok. Does it sound like something I should be concerned about? If you can tell by just a noise lol.
Also you said you've rebuilt your fair share of "these" engines. You are referring to the 2.2s right? (more specifically the phase 2 ones)
If so I just want to know how they have looked at high miles. Most common things to go wrong and other need to know things like that. Just trying to get info from people with actual experience with the 2.2s so I can take good care of mine.
Old 02-22-2012, 11:50 PM   #8
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Not a care in the world. You'll notice it sounds slower than an rpm, which implies that it's some accessory. My 91 Legacy made the same sound, as does my 97 OBS.
Keep coolant and oil in them, and they'll go forever. I have 230k miles on mine.
Old 02-22-2012, 11:58 PM   #9
NVsubaru
Member#: 247111
2007 Impreza 2.5i
1971 VW Fastback
My 2007 2.5i has exactly the same noise, sitting next to a concrete wall it becomes really noticeable, but it's a subie thing. If you're not burning oil too badly there shouldn't be a problem. Try an oil system cleaner for a few hundred miles before your next change if you want to feel better about it.
NVsubaru is offline   Reply With Quote
Old 02-23-2012, 01:30 AM   #10
05-rsx
Member#: 101188
MY07 WRX Wagon
There are obviously several 'sounds' going on in the video, and having the hood closed doesn't help distinguish the location, but to me the most obvious 'tapping'-like sound there is the normal sound of injectors opening/closing.
05-rsx is offline   Reply With Quote
Old 02-23-2012, 01:34 AM   #11
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
Me too, its normal, mines sounded like that since mile 1 now with 76k
alt14 is offline   Reply With Quote
Old 02-23-2012, 01:28 PM   #12
Robert Harik
Member#: 308034
normal
Robert Harik is offline   Reply With Quote
Old 02-23-2012, 02:10 PM   #13
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
Nothing to worry about.
Gr3en is offline   Reply With Quote
Old 02-23-2012, 04:14 PM   #14
evil03mustang
Member#: 309184
2006 Legacy GT
DARTH VADER BLACK
This.
evil03mustang is offline   Reply With Quote
Old 02-29-2012, 07:24 PM   #15
jpthagoatman
Member#: 294007
2001 Legacy L
Grape
Very normal..
jpthagoatman is offline   Reply With Quote
Old 03-01-2012, 08:01 PM   #16
SubaruSubRosa
Member#: 309386
If it makes you feel any better my brand new '12 sounds the same way. I'm 99% sure it's the injectors ticking.
SubaruSubRosa is offline   Reply With Quote
Old 03-01-2012, 08:06 PM   #17
darksc00by
Member#: 102140
2016 Single Speed or
Death
ding ding ding
darksc00by is offline   Reply With Quote
89 Loyale with passenger side valve tap jem1 'Old School' Subaru Forum 6 08-03-2006 07:59 PM
Engine/ Valve tap pistoffjstr Legacy Forum 8 02-15-2006 09:06 PM
valve tap? 5zigenwrx Southern California Impreza Club Forum -- SCIC 2 02-13-2004 11:45 AM
Valve tap?!? SoLo OnE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-11-2004 12:08 AM
Valve tap??? JaBooo Normally Aspirated Powertrain 10 12-03-2001 08:12 PM
