Welcome to the North American Subaru Impreza Owners Club Saturday July 21, 2018
Old 02-23-2012, 11:08 PM   #1
PhamilySedan
Member#: 132249
2003 Bugeye PSM
RIP RSTi
Default 2002 Impreza 2.5RS Having Hesitation/Idle Issue
Hey fellow NASIOC'ers,
I've been trying to tackle this problem for a LONG time now. Since about November my car has been sitting because it's been giving me these two problems. The first problem was that I was leaking oil through my spark plug gaskets. I just re-did the valve cover gaskets and spark plug gaskets as well as brand new spark plugs today.
The real problem lies hear. On a cold or warm start, the car will idle just fine until a few seconds or a minute passes and then the idle gets REAL rough. Sounds as if it has a HUGE cam in it haha It won't die but it does a real steady hard idle. If you count "one" then "two" real slow, that's about how rough it idles. Also, this is probably related to the idle issue. When I accelerate the car bogs/bucks hard. For example, if i'm at lets say 3K RPM, and i'm trying to get it to 4K RPM, it'll start bucking/bogging anywhere inbetween until it reaches a higher RPM. (Not at any certain RPM but at any random RPM) I'm thinking that this might be a bad O2 Sensor?
I thought that the bad spark plug gaskets were causing the misfire, but nothing has changed after I replaced those today. Any help would be greatly appreciated because I miss driving her haha C'mon guys help me out!
PhamilySedan is offline   Reply With Quote
Old 02-24-2012, 06:28 AM   #2
Flat-4-Life
Member#: 233070
1999 Impreza 2.5rs
Aspin White
i have been having the same problem for about the pas 2 months or so i finally broke down and took it to a shop and it seems that i have a bad ecu i am going to subaru this morning to verify it is the computer.
just so you know i have replaced my maf, iacv, both o2 sensors, all spark plugs, the ignition coil, spark plug wires, valve cover gasket, cleaned the throttle body and intake manifold and seafoamed my engine, replaced all vacuum hoses, the crank pos sensor and fuel filter.
Flat-4-Life is offline   Reply With Quote
Old 02-24-2012, 10:12 AM   #3
TDagen
Member#: 163648
2002 Resurrected WRX
I'm having the same problem 99 legacy 2.5 Dohc.
I had a code for knock sensor and misfire. I replaced knock sensor and the misfire and rough idle ect persisted. Then I replaced the Maf sensor. No luck.
Now ive got a misfire code, the code scanner was also flashing egr Cat and 02 on the top of the Code reader. So im wondering where to go from here. I've heard someone say the egr was causing this on there car and they soaked it in brake cleaner and it fixed it so I'm gonna try that tonight.
TDagen is online now   Reply With Quote
Old 02-24-2012, 11:37 AM   #4
PhamilySedan
Member#: 132249
2003 Bugeye PSM
RIP RSTi
Sounds good guys.
Flat-4-Life, i'be also replaced the IACV, spark plugs, VC Gaskets, and what not. Sounds like we might have the same problem. Please post back if it really is your ECU! Next thing that i'm going to replace are the O2 sensors. . haha
Old 02-25-2012, 09:17 AM   #5
PhamilySedan
Member#: 132249
2003 Bugeye PSM
RIP RSTi
Bump!
Old 02-25-2012, 01:44 PM   #6
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
If the spark plug wire ends were soaked in oil by the leak and I have a misfire then I usually check plug wire resistances. #1 =5.6k to 10.6k ohms. #2 =7.3k to 13.7k ohms. #3 =5.9k to 11.1k ohms. #4 =7.3k to 13.7k ohms.
When you are measuring the wires look at the coil where the wires attach for burnt spots or white traces from the spark trying to jump. Bad wires can cause the spark to jump and physically burn the coil towers as well. If you need wires Subaru sells the whole set for a reasonable price. Replace the coil too if it is burnt and has been arcing.
If all that is OK then you need to start looking for vacuum leaks.
Elbert Bass is offline   Reply With Quote
Old 02-27-2012, 08:27 PM   #7
Flat-4-Life
Member#: 233070
1999 Impreza 2.5rs
Aspin White
Well I finally got a result back from Subaru they are saying that someone had rewired my o2 sensors to go opposite of where they should go anyway I replaced the rear one on my own and I could not do the front one myself so I took it to a shop and according to Subaru the shop i took it to could not do it either so they took out my new rear o2 sensor and put my new pre cat o2 sensor in then swiched the wires to cover it anyway try your o2 sensors and that should do the trick if it doesn't then I have no idea
Old 02-27-2012, 08:34 PM   #8
Flat-4-Life
Member#: 233070
1999 Impreza 2.5rs
Aspin White
Tdagen have you done a compression test yet might help point you in a better direction also what cylinder/s are/is misfiring?? And if you are having vacuum leaks your car will not start at all and if it does then not for more then a second or two these engines need the extra compression that the intake manifold creates turbo or not
Old 02-27-2012, 11:00 PM   #9
PhamilySedan
Member#: 132249
2003 Bugeye PSM
RIP RSTi
That's what I'm thinking of trying. I've heard the first o2 sensor can drastically effect the way the car drives. Thanks for the input and hopefully that will solve my problem. I'll report back after I get the o2 sensor replaced
Old 02-28-2012, 12:46 AM   #10
Flat-4-Life
Member#: 233070
1999 Impreza 2.5rs
Aspin White
Good luck to you I should get my car back in the next couple days then again I am also getting my head gasket replaced lol
Old 02-29-2012, 12:55 PM   #11
farminator
Member#: 311964
02 f150
could it be a tps out of adjustment? it would explain the rough acceleration but not the idle. hard to tell since flat 4 life replaced almost everything i would guess to check in the first place.
farminator is offline   Reply With Quote
Old 02-29-2012, 01:02 PM   #12
farminator
Member#: 311964
02 f150
also might want to try a power balance test on your injectors
Old 02-29-2012, 01:56 PM   #13
Flat-4-Life
Member#: 233070
1999 Impreza 2.5rs
Aspin White
well i just got a call from subaru saying that it was the ecu like i had thought and now i am waiting on parts and i get a "brand New" car back. i hope this helps you in your search for the "truth" happy wrenching
Old 03-02-2012, 05:05 PM   #14
PhamilySedan
Member#: 132249
2003 Bugeye PSM
RIP RSTi
haha thanks Flat-4-Life. I have yet to do anything other than what i've stated before. Also, going to try and replace the upstream o2 and see if that works. If not, i'm going straight to the ECU haha THANKS!
Old 03-02-2012, 07:10 PM   #15
Flat-4-Life
Member#: 233070
1999 Impreza 2.5rs
Aspin White
no prob i hope it works out for you good luck
Old 10-26-2012, 10:29 PM   #16
Snou52
Member#: 329168
2014 STI
I know this is old but was the problem found and fixed?
Snou52 is offline   Reply With Quote
Old 11-07-2012, 09:24 AM   #17
Daniel_DeWitt
Member#: 325029
2002 Impreza 2.5RS
Midnight Black
I have this exact problem.
Replaced front o2 sensor, and idle air control valve. Don't know where to go from here :/
Daniel_DeWitt is offline   Reply With Quote
Old 11-07-2012, 10:08 AM   #18
wrbwrx52
Member#: 275907
2011 wrx
wrb
i had the same problem with my 02 rs, replaced fuel filter, plugs, wires, coil, and front o2 sensor, cleaned the throttle body and replaced the idle air control and it was good as new. have done over 1k miles since and still no problems
wrbwrx52 is offline   Reply With Quote
Old 11-07-2012, 11:26 AM   #19
Snou52
Member#: 329168
2014 STI
i take it everyone with this problem has either an intake or exhaust system on their car? i have a full header/exhaust and i'm thinking it's due to the increase air flow to the O2 sensor. my car does not like the cold wet seattle weather. when the weather dips my check engine light flashes during idle. it's been a little warmer in seattle as of late and my check engine light hasn't flashed in a week or so. weird stuff =T
Old 11-07-2012, 12:32 PM   #20
Daniel_DeWitt
Member#: 325029
2002 Impreza 2.5RS
Midnight Black
I do have an exhaust but it has been on for months before this problem occurred. Not sure if that means anything but yeah..
Old 11-08-2012, 12:22 PM   #21
wrbwrx52
Member#: 275907
2011 wrx
wrb
my rs is completely stock and i got this problem, could always check fuel pressure to, make sure theres enough
Old 11-09-2012, 07:44 PM   #22
Daniel_DeWitt
Member#: 325029
2002 Impreza 2.5RS
Midnight Black
Fixed my problem today, THROTTLE POSITION SENSOR!
Old 11-09-2012, 09:55 PM   #23
mikemace1976
Member#: 337480
Angry My Stock '05 RS 2.5 idles At Almost 0.....
My completely stock 2.5 RS has been idling at almost 0 RPMs for 3 days now. Ever since it was towed and the tow yard left the dome light on killing the battery. They had to jump it when I picked it up and it's been like that ever since. The car never had any problems until this incident. Car has 85,000 miles/136794km on it and has been maintained well. I've had the battery disconnected plenty of times and I know all about letting the car relearn to idle, this isn't the case. Help me please!!!!
mikemace1976 is offline   Reply With Quote
Old 02-18-2015, 09:53 AM   #24
Zaraia
Member#: 412302
Default my 02 RS and my discovieries.
Im sorry i know im kinda late to the party but After i decided to trade my audi a4 for my new baby (02 RS 2.5 awith 32k miles), it started having the same problems, it still has the same problems but im kinda curious as to what causes this because i had test driven the car several times before i actually bought it and it never gave me these problems, it only does it after the car has warmed up because when its just turned on it doesnt happen. A few days ago me and my dad decided to check the tps and the iacv, when we took out the iacv and cleaned it the car started idling at higher rpm's, before it idled at 500 rpm's and now it idle's at 1500 or so. Therefor i decided to buy a new iacv. If that doesnt work ill buy a tps and see if that fixes it.
Zaraia is offline   Reply With Quote
Old 10-21-2017, 08:38 AM   #25
Ivany97
Member#: 476404
Default 2005 2.5rs idle/acceleration issue
Whenever my battery is disconnected from the car it canít properly relearn itís idle. Iíve let it run for 20 minutes and itíll idle around 350rpm and then as soon as you tap the gas it wonít recover properly itíll just die. Itís actually still drivable, itís just brutal trying to drive a standard car with no neutral in traffic. It also sort of skips and spudders down low, like if Iím rolling off the clutch or under any kind of load like bottom of second gear going up a slight hill ltíll chug for a second and then once I get up to a high enough rpm itís fine. I should also mention that there is a code for the upstream o2 sensor, I installed a new one last night and cleared the code and the problem still persists. Iíve also cleaned the maf and cleaned the throttle plate and still nothing. Iím taking an automotive course and my instructor believes itís something to do with the ecu but idk. Really frustrating so if anyoneís solved this issue please shed some light!! It sucks when you have to turn your car back on 30+ times in traffic just to get anywhere.
Ivany97 is offline   Reply With Quote
2006 Impreza 2.5i Power/rough idle issue subarumafia700 Normally Aspirated Powertrain 3 02-22-2010 07:46 PM
Buying a new 2002 Impreza 2.5RS eclip5e New England Impreza Club Forum -- NESIC 24 01-30-2002 01:30 AM
('93-'01) What are the cheapest and best mods for a 2002 impreza 2.5RS? Hyudra Impreza Forum 18 07-04-2001 04:20 AM
2002 Impreza 2.5RS ashtaron14 Vancouver Impreza Club Forum -- VIC 8 03-07-2001 08:04 PM
