Welcome to the North American Subaru Impreza Owners Club Monday October 22, 2018
Old 02-26-2012, 01:24 PM   #1
NVsubaru
Member#: 247111
2007 Impreza 2.5i
1971 VW Fastback
Default ECU reset running rough
Not sure if this is fairly common, but every time I reset my ecu my car runs very poorly afterwards. Usually it idles very low (500rpm) and after revving, like when coming to a stop, it will fall even lower. Sometimes it has even died, and thrown codes due to the low idle. Is this normal? After a few hundred miles or so it runs smoothly, but yesterday it took 3-4 seconds of cranking to start. Any ideas?
NVsubaru is offline   Reply With Quote
Old 02-26-2012, 02:31 PM   #2
GrundleJuice
Member#: 165749
First be sure the a/c, defrost, and excess electrical loads are off. After an ecu reset it is required to turn the key to on wait 20 seconds, turn to off. Then try to start. After starting, allow the car to idle for at least 7 mins. It is important that the accel pedal is not touched and that no loads are put on the engine during this time. If you can log, you can watch the trims adjust and stabilize and see when it stops moving around but usually it takes about 5-7 mins.
Old 02-26-2012, 03:04 PM   #3
NVsubaru
Member#: 247111
2007 Impreza 2.5i
1971 VW Fastback
Thanks for the help. I did not go through the proper procedure, I guess. Do you recommend I redo the reset and do it correctly, or will it be okay? I'd imagine it's harder on the motor not doing so...
Old 02-26-2012, 04:32 PM   #4
Rockclimber399
Member#: 309680
Running at really low rpm's can starve the motor of oil, though because there is very little load it generally doesn't make much of a difference. However I recently just had this issue on a completely different vehicle and it ended up being the EGR valve sensor. So you may check to see that whole system is in check.
Just a suggestion.
B
Rockclimber399 is offline   Reply With Quote
Car running sluggish after ecu reset? thiefdevious Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 11-06-2008 07:22 PM
Keyless entry- reset after ECU reset? sir_aspen_white Electrical & Lighting 1 04-22-2003 08:24 PM
('93-'01) Does an ECU reset change the way an auto tranny shifts? subymamma Impreza Forum 14 05-18-2001 11:44 AM
('93-'01) ECU reset? littleblue Impreza Forum 3 05-04-2001 01:00 AM
('93-'01) ECU reset causing me to run RICH ? bigbird Impreza Forum 5 04-10-2001 10:53 PM
