Welcome to the North American Subaru Impreza Owners Club Thursday June 21, 2018
Old 03-01-2012, 08:39 PM   #1
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
Ok, I was told by a pretty trustworthy mechanic that my cat is bad. I know that's not very legible even if the mechanic is the most knowledgeable one out there.
With that being said I have a feeling it could be a possibility. And here's why:
-CEL p0420 for the last 4 months or so
-20 MPG (2.2L, manual) should be like 25-30
-my exhaust has that leaking sound to it but no exhaust leaks
-rotten egg smell a few times
How can you tell if a cat is bad?
I'd rather my CEL be for sensors than a cat. If its the cat I have to pay $800 for a new one to pass inspection in 6 months.
ManualOverAuto is offline   Reply With Quote
Old 03-02-2012, 09:18 AM   #2
DaWhiteScoob
Member#: 211268
2006 Impreza
AW
I'm pretty sure you have a clogged cat... the "rotten egg smell" gives it away also the P0240 cel.
You could have the cel code disabled to save a lot of money.
DaWhiteScoob is offline   Reply With Quote
Old 03-02-2012, 11:46 AM   #3
ManualOverAuto
Member#: 304662
Sedona red Pearl
Yea I cleared the code like last week. Still need to get a new cat eventually cause the gas mileage kills me. And it probably won't pass emissions :/
Old 03-02-2012, 09:03 PM   #4
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Odds are it's your cat, probably part of it has broken inside the pipe and it's clogging your exhaust up - causing the noise you're hearing. Crawl under it when it's cooled off and bonk the pipe with your hand and see if it sounds like crap rattling around in there.
If so, the best short-term fix is to unbolt it and mash the guts up and dump them out. You'll still have a CEL, but you're going to get better fuel economy by removing the restriction and it will lessen the likelihood of creating other problems. Save your dimes for a few months and get yourself a new cat. You may need to save enough for new sensors, as they may be the reason the cat went bad to begin with, or they may not come out of the old pipe in one piece.
CosmoTheCat is offline   Reply With Quote
Old 03-03-2012, 12:26 AM   #5
ManualOverAuto
Member#: 304662
Sedona red Pearl
As right as you sound, I really hope your wrong lol :/ ($800)
But I've known about it so it's no surprise, just hasn't been completely confirmed yet. Hoping it could just be a bad sensor causing it all. But before I buy new sensors I'll get under and see if I hear any rattle from the cat. Just gotta wait till its dry and not cold here.......
Old 03-03-2012, 12:35 AM   #6
lavid2002
Member#: 226864
Who pays 800$ for a cat dude? Get a used one and toss it in. 800 is madness
lavid2002 is offline   Reply With Quote
Old 03-03-2012, 01:05 AM   #7
Vrooom_Psh
Member#: 311923
04 STi
Sounds like your cat is done! what kind of mileage do you have?
9 times out of 10, P0420 = bad cat.
Buyer beware when buying a used cat. It's way way way cheaper but there's a chance there could be something wrong with it too, from my personal experience.
Vrooom_Psh is offline   Reply With Quote
Old 03-03-2012, 01:05 AM   #8
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
Yeah it is, subaru said it would have been $1000 to replace the one in the headers on mine when it went bad, luckily it was under 80k mile catalyst warranty
Id say 9/10 sounds something close, I have the 1/10 with different headers though haha
alt14 is offline   Reply With Quote
Old 03-03-2012, 07:53 AM   #9
jeepnut_nh
Member#: 261162
2000 Outback Sport
blue
where?
when i asked at the local junk yard, i was told that they cannot sell any used cats unless they want to pay a $10000 fine for each occurance.
something about the EPA not knowing it would be installed on the system it was designed for.
private sale might be doable, not sure if that would be illegal or not.
point being if anyone out here has a known good cat for a '00 OBS with a 2.2....PM me
rumor has it that only subaru cats will work well on subarus...i also hear they are in the $7-800 range, ive been afraid to call for a price.
jeepnut_nh is offline   Reply With Quote
Old 03-03-2012, 08:07 AM   #10
blaze wrx
Member#: 241423
02 WRX
blaze yellow
its seems crazy high.
I did a quick google search and found this OEM replacement for under $250
http://www.autopartswarehouse.com/sh...u/outback.html
It seems like people are always giving away used exhausts too... usually because they've replaced them with aftermarket so there's nothing wrong- but you have a good point, no sense replacing one bad cat with another
blaze wrx is offline   Reply With Quote
Old 03-03-2012, 10:58 AM   #11
alt14
Member#: 271928
2014 WRX Limited
^^ that's probably your best bet, walker exhausts might have something better too, I got an oem 05' cat pipe for an rs a while ago at it was only $270 I think (there's two cats on the 05 that I bought)
Old 03-03-2012, 11:06 AM   #12
ManualOverAuto
Member#: 304662
Sedona red Pearl
That was for parts and labor. But I'm sure I could find a cheaper oem replacement but labor is still gonna be there.
Old 03-05-2012, 03:45 PM   #13
cmiovino
Member#: 134005
2004 WRX Premium
Sometimes the P0420 can be the front O2 sensor... but given the smell and gas mileage, I'd say it's the cat too. Mine was ~$600 for our Forester, new and installed.
Old 03-05-2012, 09:13 PM   #14
CosmoTheCat
Member#: 3409
98 My FMIC
P0420 could be a vacuum leak.
But most often it's a bad cat.
Old 03-06-2012, 12:25 AM   #15
ManualOverAuto
Member#: 304662
Sedona red Pearl
Thanks for all the replies. If the cat is bad then it's bad, nothing I can do about it.
I would like to specify that by smelling the rotten egg smell I mean I've smelled it maybe 3 or 4 times max. Not very common but has happened. Although since its been winter I haven't smelled it once (odd?). Either way in 6 months when inspection is due I'll need a new one anyway.
Old 03-06-2012, 03:49 AM   #16
Robert Harik
Member#: 308034
You can test to see if you have a exhaust / cat restriction by hooking up a vacuum gauge to your intake manifold. Once you start the car, let it idle , if you have a restriction your vacuum will start out normal( 18- 22 ( Hg) inches of mercury) and then slowly drop( vacuum will get less).
Robert Harik is offline   Reply With Quote
Old 03-06-2012, 10:03 AM   #17
ManualOverAuto
Member#: 304662
Sedona red Pearl
Ok might try this. Will any vacuum gage work?
Old 03-06-2012, 11:35 AM   #18
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Originally Posted by jeepnut_nh View Post
where?
Post a WTB in your local regional forum here on NASIOC. That's what local forums are for. I'm sure there's a couple of people out there who have installed headers and a high flow cat and have a stock one just sitting gathering dust.
Not that it helps you, but I've got 4 or 5 stock WRX downpipes out in my shed. There's guys like me all over the country. I'm not unique. You just need to put your request in front of the right eyes. And don't worry about what you are doing being illegal. It is illegal for a business to sell used catalyst parts, but you are at no risk with a private party sale.
Old 03-06-2012, 11:40 AM   #19
jeepnut_nh
Member#: 261162
2000 Outback Sport
blue
thanks for the info matt, i will do that once i find work and get back on my feet
Old 03-06-2012, 02:42 PM   #20
Robert Harik
Member#: 308034
Any one that is accurate and within the right range( at least 0 -25 Hg. They make ones for auto use that are really useful for all kinds of testing.
Old 03-06-2012, 05:18 PM   #21
ManualOverAuto
Member#: 304662
Sedona red Pearl
So if the cat is clogged where do I go from there? There has to be an underlying cause to why it's getting clogged. I just hope it's not a head gasket burning oil and clogging it up. I did recently see that my coolant was a lot lower than usual, but I never smell burning coolant or oil. My oil is usually always at the same level when I check it too.
Hopefully it's just old and needs replacement. Or even better, my cat could be fine and it's just an o2 sensor, that'd be greeeaaattt.
Old 03-06-2012, 07:53 PM   #22
Robert Harik
Member#: 308034
Your right, cats die from contamination( usually oil , coolant),but can also be destroyed by overheating( monolith( inside) melts/ falls apart). Its caused by raw fuel reaching and burning inside the cat. It can be caused by very rich running( bad sensors) , missing( every time a cylinder misses unburned fuel is passed into the cat).If you still have the problem that melted( if that is the your problem) the cat in the first place , it will eventually ruin your new cat.
Old 03-06-2012, 09:04 PM   #23
ManualOverAuto
Member#: 304662
Sedona red Pearl
Can you tell more specifically when looking at the old cat what could have cause it to go bad? Like what residues are around/on the inside of the cat? If so I'll have them check it if I get a new one.
I don't believe I'm burning oil but my coolant seems to always go down to like 1/2-3/4 of the way full after its topped off, so maybe I'm burning coolant.
Another possibility could be that maybe it's the original cat. I know my exhaust pipes underneath are newer than the car but I've heard that you don't always replace the cat when you get new pipes. Makes sense because if the cat isn't bad it'll save $800+ on that new exhaust. Car has almost 110k and 11-12 years on it so who knows.
Old 03-06-2012, 10:33 PM   #24
Robert Harik
Member#: 308034
First find out if it is bad, then diagnose. Like I said ,usually a dead cat( not the road pizza type) is caused by oil or coolant contamination and these are not usually blocked/ clogged up. If it is melted or the substrate has fallen apart, it is from overheating and that is caused by large amounts unburned fuel getting into the cat. Thats it.
Old 03-06-2012, 10:50 PM   #25
ManualOverAuto
Member#: 304662
Sedona red Pearl
Are those things are the ONLY things that can cause a cat to go bad?
What if i told you my exhaust from the cat on up are all original (110k, 11-12 years on car, 3 owners), and everything else after the cat was replaced at one point.
Dont you think small amounts of unburned fuel / burned oil / burned coolant over a longer time (11-12 years) could do the same damage?
Alot of oil/coolant/unburned gas over a shorter time. = Small amounts of oil/coolant/unburned gas over a long time.
Right?
What are the symptoms of a bad injector timeless Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 06-14-2016 01:43 PM
VF39 BAD SEALS? What are the reccuring effects of bad seals in a turbo? Drewbaru04 North West Impreza Club Forum -- NWIC 2 05-16-2009 11:50 PM
What are the good/bad for Adjustable Rate Mortgages? styng88 Off-Topic 14 09-26-2005 03:13 PM
Strut going bad? What are the symptoms? Opie Brakes, Steering & Suspension 2 03-05-2003 06:25 PM
what are the symptoms of a bad clutch? Keith Technical Forum Archive 6 09-18-2000 10:12 PM
