Welcome to the North American Subaru Impreza Owners Club Friday July 20, 2018
Old 03-01-2012, 08:56 PM   #1
farminator
Member#: 311964
02 f150
Default 2000 outback under preasure at idle
just did the head gaskets on my buddys 2000 outback. car had 175K. i notice oil buildup in the intake wich i thought was piston rings. compression test came out with great numbers. only real problem is when its idling and you put your hand up to the plenum it feels like air is being pushed back out, go up 100 rpms and its under vaccum. i assume this isnt normal. any thoughts? (i do not have a vacuum tester but ill be picking one up soon)
farminator is offline   Reply With Quote
Old 03-05-2012, 01:18 PM   #2
farminator
Member#: 311964
02 f150
could it have anything to do with the PVC system? i noticed their are no check valves, just hoses running to the intake.
Old 03-05-2012, 03:45 PM   #3
GrundleJuice
Member#: 165749
There should be a pcv valve on the aft side of the crankcase, below and to the right of the TB.
Old 03-06-2012, 04:10 AM   #4
Robert Harik
Member#: 308034
Use a vacuum gauge to find out what the vacuum really is.
Robert Harik is offline   Reply With Quote
Misfire at idle and 2,000rpm under load liljons06STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 02-20-2012 02:26 AM
Chirping noise at idle and under power ormandj Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 02-20-2011 10:21 AM
Exhaust leak at gasket by rear diff 2000 outback stevenmurray Legacy Forum 1 10-25-2010 12:22 AM
Lean at idle, rich under boost? Vacuum leak? saab-on-the-cobb Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 02-15-2009 12:54 AM
Leaning out under boost, 15 fuel correction at idle SpoolinPA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 60 03-03-2007 02:08 AM
