Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 03-07-2012, 01:46 AM   #1
cjac2879
Member#: 304620
2006 Impreza 2.5I
Default Possible massive tranny leak.. Need suggestions
First off let me say, that the car is at the shop awaiting a mechanic to look at it, but I was hoping to maybe get some answers here.
I have a 2006 Subaru Imprezza 2.5I.. 73000 Miles on it.. Ive owned it since 43000.
Last night I drove home from work and parked my car.. I had zero issues with how the car drove.. was very smooth since i owned it... I moved my car today so my wife could get by, and I pulled it back on my driveway.. I noticed that I had a trail of fluid where I had driven.. I pulled it all the way up and looked under.. On the drivers side of the car in front of the tire, I had ALOT of fluid dripping.. I had the wife start the car while I looked and it poured out, and I could hear a gurgling sound (think pushing water through a pinched straw).. The fluid was darker, not red, So I thought it was oil.. I checked oil, and was down a qt.. I added the quart and went to drive to the mechanic.
I drove a mile to the end of my road and when I went to give it gas to pull out, I had nothing.. NO GEARS.. No drive, no reverse... I popped the hood and checked trans fluid NOTHING... Looked at the car.. I had "trans fluid" spraying through my tire and out from under my headlight (all drivers side)... The leak seemed to be isolated somewhere behind the headlight, but because of the skidplate, I couldnt see up from underneath..
I towed the car to the shop, and am awaiting the diagnosis.. Just hoping to get an answer or suggestions in here... Let me reiterate, that up until I stopped at the end of my road, the trans ran fine...
Do the trans coolant lines run in that area? It seems like it is to far forward in the car to be the transmission itself.. I am hoping I blew out a line if that is possible?? is it?? please be nice and give me good news...
Please let me know if you have any ideas, and sorry for the short story, I was trying to be detailed..
cjac2879 is offline   Reply With Quote
Old 03-07-2012, 01:57 AM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
The trans lines run on the driverside up to the radiator, so yes it sounds like you blew a cooler line.
Old 03-07-2012, 02:00 AM   #3
cjac2879
Member#: 304620
2006 Impreza 2.5I
Oh, I should also say that when all hell broke loose and I had no gears.. My check engine light also came on
Old 03-07-2012, 02:06 AM   #4
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
The check engine light probably came on because of your loss of fluid.
Old 03-07-2012, 02:18 AM   #5
cjac2879
Member#: 304620
2006 Impreza 2.5I
Thanks Mod.. thats a little bit ease of mind
Old 03-07-2012, 03:02 AM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I assume this is an automatic? If so its most likely the transmission cooler lines.
Old 03-07-2012, 01:18 PM   #7
cjac2879
Member#: 304620
2006 Impreza 2.5I
It was a blown hose guysl... Iappreciate the little piece of mind you guys gave me before I went to bed!!!
Thanks
Old 03-07-2012, 01:58 PM   #8
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Thanks
Your welcome thats what it sounded like.
cant find coolant leak need suggestions zero-d Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 11-26-2007 08:12 PM
Coolant Leak. Need Suggestions. BIG GUN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-26-2006 09:48 PM
need suggestions for exhaust leak foureyedlameo Mid West Subaru Owners Club Forum -- MWSOC 2 11-11-2005 09:59 PM
Massive, MASSIVE oil leak jasona Normally Aspirated Powertrain 16 10-11-2005 12:56 PM
Deep puddles + STi = HEADGASKET LEAK!! Need some suggestions for stronger motor ;) 300blueballs Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 10-08-2004 08:26 PM
