Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Old 03-19-2012, 10:11 AM   #1
chevyman1968
Member#: 311197
1999 Legacy Outback
High Comp Dohc 11.1 to 1
Default Water pump question
I am rebuilding a 2.5 dohc this week and was wondering if I could use the water pump over? It was replaced about 40,xxx ago. I checked it over and the bearing is still good. If I can't use it over, Is it better to get a Subaru pump or go after market?
chevyman1968 is offline   Reply With Quote
Old 03-19-2012, 10:25 AM   #2
Jessekrs123
Member#: 236927
2015 BRZ 93 LEGacy33
1984 BRAT
This is one of those preventative maintenance items, meaning, if you are going to have everything apart, might as well just replace it for good measure rather than having it fail prematurely before you have everything apart again.
An OE Subaru pump should be just fine, and you should replace the thermostat while you have it all apart as well. (Another preventative maintenance item)
Don't forget the gasket as well as cleaning off the mating surface, and don't forget that the water pump bolts should not be heavily torqued. Snugging them up will do just fine. Don't forget to install the thermostat right side up as well.
Jessekrs123 is offline   Reply With Quote
Old 03-19-2012, 10:28 AM   #3
Colter84
Member#: 249901
2007 STi
This is one of those situations that if you ask 5 people you're bound to get 5 different answers.
With that being said, some would say why not do it when you're in there since they can be had for fairly cheap, and it will obviously be a much easier job with engine out.
On the other hand, if it's only got 40k on it, there's a good chance that it could last until your next timing belt change is due.
It really just depends on your personal preference and budget. Personally I like to replace everything that I can afford when doing something like that. If you do change it you might as well put a new thermostat in it as well.
Colter84 is offline   Reply With Quote
Old 03-19-2012, 10:40 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
I'll provide the dissenting view and say that I would definitely re-use the pump if it's only got 40k on it. I'm well-versed on preventive maintenance - I'm in the Navy, it's how we do everything - but IMO it's entirely possible to be too preventive by addressing things that aren't a problem.
Old 03-19-2012, 10:57 AM   #5
lavid2002
Member#: 226864
Replacing a water pump at 40k is being a little anal. But on the flip side, mine failed at 55k ish
lavid2002 is offline   Reply With Quote
Old 03-19-2012, 11:03 AM   #6
chevyman1968
Member#: 311197
1999 Legacy Outback
Okay, I think it will really depend on how things go this week. If I have room in my budget I would prefer to replace it that way it doesn't decide to quit on me when I am driving. I do agree with Patrick though. I don't like to replace stuff if it isn't a problem, but I am also use to working on Chevy v8s where the water pump is out front and easy to get to. I was told that when you change the timing belt you do the water pump and vice versus. So, idk.
Old 03-19-2012, 04:16 PM   #7
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I would also add it depends on how fast you are. if it takes you 4 or 5 hours to do a water pump than you might want to do it, if you can do it in a hour and a half then maybe not.
Old 03-19-2012, 07:57 PM   #8
chevyman1968
Member#: 311197
1999 Legacy Outback
Since I have the engine out I will prolly just replace it. It will save me having to replace it in the car later.
Water/meth injection water pump question atomic4877 Water/Methanol Injection, Nitrous & Intercooler Cooling 3 09-24-2009 06:29 PM
Water pump question Rocketcar Service & Maintenance 1 01-28-2006 03:41 PM
timing belt,water pump question. help WRC STYL Service & Maintenance 0 01-09-2003 07:43 PM
water pump question IggDawg Normally Aspirated Powertrain 4 07-08-2002 08:47 AM
Quick Water Pump Question BJamerican Service & Maintenance 2 12-12-2001 10:52 PM
