Welcome to the North American Subaru Impreza Owners Club Wednesday February 21, 2018
Old 03-25-2012, 12:46 AM   #1
cartwheels4amile
Member#: 190405
2002 Impreza WRX
Default Let's play: Guess That Noise!
So here is my new (to me) 99 Outback. Traded a guy my WRX for him to repair (had developed a knock) and in return got this Outback which he had supposedly done head gaskets, timing belt and water pump, and a clutch on. Seemed like a great deal, even had the local Subie dealer check it out and they said it was the cleanest car of that year they'd seen. Of course, I get it home and it starts to sound like this when I start it up the next day.
Did some reading and it sounds like these cars have an issue with piston slap... and the noise DOES quiet down when the motor is warm. But it still freaks me out.
Have a listen and tell me what y'all think.
cartwheels4amile is offline   Reply With Quote
Old 03-25-2012, 04:14 PM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Guess is right, It could be piston slap, can't really tell from here, I would take it to a shop and see what they say.
Old 03-25-2012, 04:29 PM   #3
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
lose lifter?
DHRDAN is offline   Reply With Quote
Old 03-26-2012, 02:02 AM   #4
forestersub
Member#: 303883
06 Impreza Hatch
that is not piston slap atall. i would say more likely its lifter /s. how aqbout you have the lifters / tappets adjusted and see how things sound.
forestersub is offline   Reply With Quote
Old 03-26-2012, 02:20 AM   #5
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Definitely not slap. Slap sounds more like rod knock. That's definitely external sounding like something in the head; shims, valves, springs, etc.
cal_look_zero is offline   Reply With Quote
Old 03-27-2012, 01:05 AM   #6
SubieHondaGuy
Member#: 312223
1. He could have used the wrong head gaskets(used the sohc ones) and it will make the same sound
2.Could be a bad tensioner, they are known to make noise when they are failing.
SubieHondaGuy is offline   Reply With Quote
Old 03-27-2012, 02:16 AM   #7
cartwheels4amile
Member#: 190405
2002 Impreza WRX
Took it to a garage and they told me the car is in need of a valve adjustment. Good ears, guys! I'll have it done and report back to see if it sounds better.
Old 03-27-2012, 02:19 AM   #8
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Sounds valvetrain related to me. I would check intake and exhaust valve cam clearances. Are the heads SOHC?
~Josh~
Old 03-27-2012, 10:06 PM   #9
melonhead419
Member#: 314843
1995 Subaru Legacy L
Hunter Green
Might be lifter related....Theyre non adj too I think....
melonhead419 is offline   Reply With Quote
Old 03-28-2012, 01:11 AM   #10
Blase M
Member#: 84955
2000 impreza rs
blue
I had a loose spark plug that sounded like that once.
Blase M is offline   Reply With Quote
Old 03-28-2012, 03:22 PM   #11
47businesscoupe
Member#: 243590
07 forester
Ask the guy if he replaced tensioner/and pulley and if he replaced idlers, bearing failure of cogged idler allows it to contact the oil galley makes a very simular sound (telegraphs sound like a internal engine noise rod knock etc.)
47businesscoupe is offline   Reply With Quote
let's play: Name That Plug!! mazda02subaru Newbies & FAQs 8 09-23-2010 07:15 PM
Its time to play: guess that part! WRX300 Off-Topic 5 07-19-2008 04:49 PM
let's play name that noise suby ej25 Tri-State Area Forum 3 08-14-2003 12:31 PM
Let's play: Name that Movie JGard New England Impreza Club Forum -- NESIC 127 11-01-2001 02:55 AM
Let's Play: Name That Lip MagicMT Interior & Exterior Modification 21 08-11-2001 02:42 PM
