Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 03-27-2012, 03:41 PM   #1
Kolat
Member#: 301679
Default What do you guys think? headgasket?
97 imp L 2.2
Oil level stays high unless it gets low on coolant. As soon as it gets low its down 2 quarts of oil. Happens about every 3k mikes.
Motor has 226000 on it.
T
Kolat is offline   Reply With Quote
Old 03-27-2012, 04:19 PM   #2
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
That's weird. How often does the coolant get low?
cal_look_zero is offline   Reply With Quote
Old 03-27-2012, 04:30 PM   #3
stiltz357
Member#: 311373
2009 impreza 2.5i
dark grey metallic
if u check ur dipstick does it have kinda look like it has chocolate milkshake on it? do u have white smoke coming out of the exhaust?
stiltz357 is offline   Reply With Quote
Old 03-27-2012, 05:12 PM   #4
Kolat
Member#: 301679
Happens about every 3k, oil looks like its not contaminated, no white smoke.
T
Old 03-27-2012, 05:12 PM   #5
Kolat
Member#: 301679
T
Old 03-27-2012, 05:47 PM   #6
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Use some subaru coolant additive.
Old 03-28-2012, 10:45 AM   #7
Bluefoton
Member#: 141373
2022 Crosstrek Sport
6MT
Can you spot an oil leak? First and foremost though, why do you get low on coolant?
Old 03-28-2012, 07:43 PM   #8
Kolat
Member#: 301679
It has the typical oil leak from the pass side valvecover gasket.
No idea on the coolant except that maybe I get low from it keeping my oil level high
T
Old 03-28-2012, 11:55 PM   #9
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
T[/quote] ?
Old 03-28-2012, 11:59 PM   #10
lavid2002
Member#: 226864
The question here that needs to be asked is how often do you get low on coolant? Leaks? Recent radiator, heater core, water pump, or coolant leak work done to the car? This would just be air purging out of the system and no big deal.
Look on the bottom of the oil fill cap. Does it have a white milky paste on it?
Oil look black or fresh? Or does it look white ish with signs of coolant contamination.
No smoke? No oil problems? Recent work done on any of the things I listed above?
If no no and yes, then you don't have a problem. Put some coolant in it and be on your way
-Dave
lavid2002 is offline   Reply With Quote
Old 03-29-2012, 12:01 AM   #11
lavid2002
Member#: 226864
T
?[/quote]
? Wut?
The coolant system is totally separate from the oil system. The only way the would mix is from a failure of some kind, usually headgasket failure. In this case there would be coolant in oil or visa versa. If you dont see this then your oil level has nothing to do with your coolant level.
Old 03-29-2012, 03:33 AM   #12
tphakkhc
Member#: 311823
What? Your coolant does not get low because your oil is high. You either have not put enough coolant in your car or it may have looked like you did because of air in the system or you have coolant leaking from somewhere probably a hose or the radiator. It could possibly be leaking at the head gasket but if you do not have white smoke, etc then that probably rules that out. As for your car burning up a lot of oil if there is no oil in your coolant then your head gasket is probably fine and your car is just running like *****
tphakkhc is offline   Reply With Quote
What do you guys think of a SPT intake? What do you have? chomponthis231 Newbies & FAQs 28 07-07-2009 09:01 AM
Thinking of going wingless, what do you guys think?? Calitri-Boost Member's Car Gallery 66 09-30-2006 02:42 PM
What do you guys think I should do?? evokiller04 Proven Power Bragging 13 06-13-2006 07:28 PM
Thinking about bidding on this eBay car, what do you guys think? Cjchaps Mid West Subaru Owners Club Forum -- MWSOC 18 01-04-2002 01:42 AM
