Welcome to the North American Subaru Impreza Owners Club Thursday January 18, 2018
Old 03-29-2012, 10:13 PM   #1
chevyman1968
Member#: 311197
1999 Legacy Outback
High Comp Dohc 11.1 to 1
Default Timing Belt install
Okay I am installing my timing belt and I am wondering if there is any way I could mess it up? If I have all my timing marks aligned and everything is put together right? This is my first timing belt install so I am kinda nervous.
chevyman1968 is offline   Reply With Quote
Old 03-29-2012, 10:29 PM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I would never say you can't mess it up but if you are careful you probably won't.
Old 03-29-2012, 10:52 PM   #3
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
All I can advise is gently turning it over by hand to make sure you're lined up. 4 cams and interference heads could be ugly.
cal_look_zero is offline   Reply With Quote
Old 03-29-2012, 11:08 PM   #4
SubieHondaGuy
Member#: 312223
If all marks line up its dead, always turn the motor over by hand a few revolutions to make sure no contact and the tensioner tensions properly.
SubieHondaGuy is offline   Reply With Quote
Old 03-29-2012, 11:08 PM   #5
SubieHondaGuy
Member#: 312223
If all marks line up its dead on, always turn the motor over by hand a few revolutions to make sure no contact and the tensioner tensions properly.
Old 03-30-2012, 07:34 PM   #6
2.5_IMP
Member#: 163604
Well, which one is it?
Some helpful links:
http://www.motor.com/magazine/pdfs/072001_08.pdf
http://www.motor.com/magazine/pdfs/082001_08.pdf
http://www.motor.com/magazine/pdfs/092001_08.pdf
http://www.motor.com/magazine/pdfs/102001_08.pdf
http://www.motor.com/magazine/pdfs/112001_08.pdf
2.5_IMP is offline   Reply With Quote
Help! Timing Belt Install, stuck on the... you know, install RS-Flyboy Normally Aspirated Powertrain 11 07-09-2009 02:03 PM
Timing belt install CpnNeeda Service & Maintenance 11 07-03-2005 03:37 PM
Timing belt install?? AK'S REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-15-2004 01:18 PM
Timing belt installation for a PE belt? IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-27-2003 04:45 PM
02 WRX timing belt install after crash cky211 Service & Maintenance 1 12-29-2002 12:25 AM
