Welcome to the North American Subaru Impreza Owners Club Sunday January 20, 2019
Old 04-05-2012, 12:12 PM   #1
4Birdman
Member#: 315804
2003 WRX
Default P0301, P0302, P0420 codes - 2003 Outback
I've got a deal worked on a 2003 Outback with the 2.5L. It has 141k miles, new tune up, water pump, timing belt, etc. In good shape and runs good. Mostly.
The problem is that the CEL is flashing and I'm getting a P0301, P0302, and P0420 code. The car starts and idles fine and runs good when on the highway, but when you get in to it it bucks and is down on power.
I'm thinking it is the coil, since it is a 1&2 cylinder misfire and those are fired off of the same pack.
What do you guys think?
4Birdman is offline   Reply With Quote
Old 04-05-2012, 07:58 PM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
It could be the coil pack, it could be a hg, it could be plugs. do a compression test when you check the plugs.
Old 04-05-2012, 11:06 PM   #3
GrundleJuice
Member#: 165749
Sounds fuel related. Could be a sensor problem or an intake or pre cat exhaust leak. Try resetting the ecu and see if it helps in the short term. If it "fixes" it for a few miles, but the problem comes back then it's probably something I mentioned
p0420 code - 2008 WRX Trelor Open Source Reflashes 3 08-27-2011 01:40 AM
Yet another p0420 code - 2002 Outback 2.5l merlin2375 Service & Maintenance 3 07-13-2010 11:26 PM
cel p0301,p0302 pending code ben c Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-24-2009 07:45 PM
cel codes p0301 and p0420 hagood22 Newbies & FAQs 0 04-17-2008 10:14 PM
Misfires- P0301 P0302 P0303 P0304 AndyHidley Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-30-2001 02:18 AM
