07-17-2012, 12:16 AM | #1 |
Member#: 318130
Vehicle:2002 WRX PSM |
Headlight issues
So about 2 weeks ago my passenger side headlight when out. Of course, I assumed i just needed a new bulb. When i took the bulb out, it appeared that was the culprit. I replaced the bulb....but still nothing. Both headlights work when I flip on the high-beams, but the passenger side still doesn't on low beams. I've checked the fuses and those are alright as well. Anybody out there have this problem? Any suggestions are welcome...need to get this fixed so she will pass inspection...Thanks
07-18-2012, 12:44 PM | #2 |
Member#: 5887
BAIC
Vehicle:2002 GDAA (bugeye) 797 (blaze yellow) |
Which model year? You need to provide more details.
07-18-2012, 05:45 PM | #3 |
Member#: 64405
E. Canada
Vehicle:2018 STi WRB |
Have you already double checked that the bulb is seated correctly? That would be the most likely issue, and also easiest to try.
07-18-2012, 08:05 PM | #4 |
Member#: 33850
NESIC
Vehicle:2006 WRX Wagon WRC Blue |
try swapping the bulbs to verify that either the bulb is good or the connection is good.
check the plug for corrosion. check the main harness plug that connects the light to the car as well |
07-19-2012, 12:14 AM | #5 |
Member#: 318130
Sorry man, its an 02. and turned out it was a faulty socket. got her replaced and works as good as new. thanks for the ideas fellas
07-19-2012, 08:21 PM | #6 |
Member#: 33850
NESIC
good deal, glad you got it fixed up
07-19-2012, 11:35 PM | #7 |
Member#: 141373
E. Canada
Vehicle:2022 Crosstrek Sport 6MT |
Sweet. Fill your profile though
