Welcome to the North American Subaru Impreza Owners Club Wednesday August 23, 2017
Old 08-12-2012, 05:24 PM   #1
Frank-i-e
Member#: 316463
2005 STi
World Rally Blue
Default Brake lights Stay on, no cruise control
Hey guys, so I'm having an issue. Like the title says ill drive my car and by the end of the drive and turn off my car my brake lights will be on. All 3 on the bottom row remain on even when shutting off the car. The only way I can get them to turn off is by pumping the brake when the car is already off.
Also with this issue my cruise control is not working. Assuming it detects that my brakes a depressed for some reason.
I have looked at this thread but sadly didn't fix my issue even replacing my bulbs. I didn't unplug the tail lights yet though.
http://forums.nasioc.com/forums/show...2365294&page=2
Thanks guys
FIXED: Brake light switch was the culprit.
Frank-i-e is offline   Reply With Quote
Old 08-12-2012, 06:04 PM   #2
leftbraned
Member#: 173364
2003 wrx
sounds like your brake light switch is going bad. Its under the dash and your brake pedal pushes it in. If its not getting pushed in all the way your cruise thinks you're using brakes and won't stay engaged and your brake lights will remain on even with the car off.
easy fix!
leftbraned is offline   Reply With Quote
Old 08-12-2012, 07:09 PM   #3
Frank-i-e
Member#: 316463
2005 STi
World Rally Blue
That's exactly what I was thinking but after reading that thread, I thought I may be a victim of some gremlins. Lol I'll have to order a switch here soon. I work at autozone and they can't get it, junk.
Old 08-13-2012, 01:15 AM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Check the adjustments for the brake switch and cruise control on the brake pedal. That will most likely take care of the trouble. There may be a weak return spring on the pedal also.
Old 08-13-2012, 04:48 AM   #5
Frank-i-e
Member#: 316463
2005 STi
World Rally Blue
Hey bud, I actually got down there and took a look and the previous owner has a bunch of wires and what not from the viper alarm, the audio and who knows what. Looks like the wiring was pulled some how and broke the switch in half. I tried getting in there and giving the pig tail some more room but I finished breaking the brake switch. It's the switch for sure, just need to find one.
Thanks everyone for the prompt responses!
I wish I knew what the heck he has going down there and clean it up but looks like a huge mess that if I mess up, I won't be able to make work. Lol
