08-18-2012, 06:25 PM | #1 |
Member#: 238618
Vehicle:2011 WRX 11.82 stock 5sp/eng vf52 |
turbo options and goals
Blouch 3.0xt-r (55lb)
Blouch 4.0xt-r (60lb) Fp Red 76hta (60lb) Going 8-9 cm,int wg and forced to go 3" inlet almost maxed out my 1000s at 440whp (49lb) so I ordered 1200cc injectors for e85
08-18-2012, 09:10 PM | #2 |
Member#: 238618
38 view no suggestions. Man u guys love me huh lol
08-18-2012, 09:20 PM | #3 |
Member#: 197062
Rotate your turbo if you're getting serious.
08-18-2012, 10:08 PM | #4 |
Member#: 305890
NWIC
Vehicle:2005 STI WRB |
What the hell does this have to do with a built motor?
08-18-2012, 10:58 PM | #5 |
Member#: 238618
No need to rotate or go ext wg, or go bigger than 60lb turbo. Then I need a bigger fmic, ext wg, 2200cc inj, etc.
Lbell05sti, I am finishing up a motor build. The block is built for 1000-1200hp, minds well up the turbo size. Where should I post the turbo thread? Oh wait there isn't one? |
08-18-2012, 11:02 PM | #6 | |
Member#: 197062
08-19-2012, 10:48 AM | #7 |
Member#: 238618
What makes me a serious drag racing are my record setting times on small turbos not the location of my turbo. What makes a rotated setup so superior? Can you prove that a rotated 35r puts down more power on pump gas vs me running a 2.5xtr on ethanol or a 3.0...etc
I also proved that my 5sp ppg gear ratio is superior to any stock sti 6sp ratio except in strength. That is what the regulars claim....the whole 5 guys in the usa that have broken ppg gears, 99% being helical without a trans brace lol... I am working on that as we speak. My only concern is the axles now if I upgrade turbo and to bettter tires |
08-19-2012, 11:47 AM | #8 |
Member#: 127745
NWIC
Vehicle:06 WRX 30r 6 speed 99L EJ255 6 Speed |
You have yet to prove ****, except that you can run your mouth.
CFM x 10 = estimated CHP. Account for VE, and then drivetrain loss. That should get you in the ballpark regarding the turbo you want. Or go see what other people have done with various setups, then add 25% cause you are the first ever, record breaking, most badass mofo ever to drive a subie |
08-19-2012, 07:39 PM | #9 | |
Member#: 218739
TXIC
Vehicle:2002 WRX hybrid |
huh? Can you prove that a stock location will make as much power on 87 octane as a larger rotated turbo on c16? Why not make comparisons that have a point? Like a stock location ATP GTX3071 on e85 vs. a rotated GTX3071 on e85.. You're argument is like saying an 18g on e85 will make more power than a 35r on piss water, so obviously the 18g is better for drag racing. If you're going to run ethanol, then run ethanol.. and I guarantee a 35r will make more power than a 2.5XT-R. |
08-19-2012, 09:08 PM | #10 |
Member#: 238618
My 2.5 will destroy any 35r on pump but that's not my point. Many things need to be upgraded go rotated 35r. I'm just saying big turbos suck on pump. I would rather have a 3.0 or 4.0 on e85 than a 35r on pump even w meth. I asked for turbo advice and I dont see proof that rotated turbos make more power than bolt on. I don't wanna be limited on boost due to lack of ethanol. Push the envelope ya know. The reason most cars are slow with a 35r is cause they are on pump low boost and have a 6sp and have to use 5th gear on top of not having enough inj or pump to supply high hp without spending big bucks.
08-19-2012, 10:18 PM | #11 | |
Member#: 197062
08-19-2012, 11:32 PM | #12 | |
Member#: 218739
TXIC
Destroy as in how? A small GTX35r makes around 450whp on pump gas and low boost. A quick search shows Dom 2.5s making around 350whp on pump gas. I guess you meant the 2.5 would be destroyed? Is your argument that you will not be able to purchase ethanol if you run a larger turbo? I don't follow.. if a certain fuel is available it doesn't matter what turbo you are running, you can still buy it. If it's just a matter of you don't want to spend the money to build an engine and fuel system that will handle more power than a 71mm turbo will make.. then that's a valid argument. But properly built car with a rotated 35r will be in the 9s. I haven't seen any Dom 2.5 running 9s. I have to admit I'm a little curious of your times on the Dom 2.5 since it will destroy any 35r. |
08-19-2012, 11:44 PM | #13 |
Member#: 259948
W. Canada
Vehicle:MPS 510 whp GTX35R Long Rod Motor |
****ty 92, 475whp on 20 psi gtx35r. Full boost by 4k, 8k redline.
08-20-2012, 02:07 AM | #14 |
Member#: 316296
Vehicle:2006 STIROID 10.5@131 on 29psi |
Have you thought about a FP Black? They support 35r numbers in stock location. Oh... never mind that would be a downgrade for you...
08-20-2012, 02:33 AM | #15 |
Member#: 305890
NWIC
I feel dumb now. Thanks for killing my brain with this thread. Location of turbo has nothing to do with the amount of power it will make, but due to space limitations fitting a proper intake on a larger turbo becomes very difficult. Your 2.5 will never out perform a proper 35r setup. Your comparing apple's to oranges, any compatible build as far as supporting mods to support a 35r vs a 2.5, the 35r will win regardless of what tranny you use.
08-20-2012, 03:35 AM | #16 | |
Member#: 163631
NWIC
Vehicle:07 Forester XT Dom 1.5XT-R |
08-20-2012, 09:04 AM | #17 |
Member#: 78640
NESIC
Vehicle:19 Tundra 20 Landcruiser | 12 IS-F |
08-20-2012, 12:17 PM | #18 | |
Member#: 48350
Vehicle:WRX 03/04/07 hybrid PSM |
Rotated just allows for larger turbo inlet piping, and uses different exhaust housing instead of the five bolt. You could actually "Rotate" a stock location turbo. Some turbos are too large to mount in a factory location. Most people dont rotate the smaller than 35r turbos because there really isnt a need to when stock location is available. Thats not to say you couldnt. Technically a person could low mount a 42-52lb per minute turbo and conceivably spool faster than your stock location turbo due to shorter exhaust piping. There really is no limit once you move from factory location. Edit: Missed this vvvvvv |
08-20-2012, 01:15 PM | #19 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
Didn't Buschur racing rotated a FP green and gained 20whp....?
08-20-2012, 02:05 PM | #20 |
Member#: 166005
Vehicle:2005 Saab 92x Beaten Silver |
All this stock location and IWG talk brought juan to mind...
Rotating has proven to be easier to work on as well as make more power between the easier flowing intake/inlet paths as well as larger exhaust housings created when moving away from the SL variations. |
08-20-2012, 02:22 PM | #21 |
Member#: 316296
Easier to work on for sure, I can get my GT3794 off in about 10 minutes!!
08-21-2012, 04:26 PM | #22 |
Member#: 238618
Don't have enough fuel for 5.0xtr of fp black. Choice now is 3.0 or 3.5xtr
08-21-2012, 05:26 PM | #23 |
Member#: 78640
NESIC
08-21-2012, 05:44 PM | #24 |
Member#: 206851
Vehicle:56 Belair Pro Street |
why is iwg even an option if you are looking to play record breaking bs games?
such a huge amount of hp and tq thrown away |
08-21-2012, 07:08 PM | #25 |
Member#: 127745
NWIC
Cause he has no idea how these things really works, ad thinks he can will his way into the record books
