Welcome to the North American Subaru Impreza Owners Club Friday November 24, 2017
Old 10-22-2012, 01:06 PM   #1
thebigevilfoot
Member#: 253836
2008 AW e90 M3
2011 WRX 350/365- sold :(
Default 2011 WRX - Rough idle, constant stalling, won't stay running
Hey everyone, I was hoping someone could point me in the right direction of where to begin diagnosing this problem.
Heres the story:
I was coming off the highway after doing a pretty big pull, the car ran through the pull better than ever, it felt great all through the rpm range, as I was coming off the exit, I clutched in, my rev's dropped, and suddenly they dropped too far and the car began stalling out, I rolled into a parking lot and began looking for a vac leak somewhere, assuming a FMIC pipe came loose. I couldn't find anything, no smoke from the motor or oil filler, oil levels are fine, oil looks great/fresh. I started her up again to see if it would run. It began idling super rough bouncing around 400-500 rpm's almost cutting out, I revved it up to keep it running (at which point a little whitish/grayish smoke came out of the exhaust, but nothing serious so I assume) The car seemed to smooth out and the revs came up to 900 and it was idling fine. I drove it slowly home, it ran fine, obviously I didn't get on it, but from 0-3000 rpm's it drove like normal. I came to a light, at which point I clutched in again, the revs dropped and it started to barely run, until it finally stalled out again, I waited a bit a gain, started it up, revved it to keep it from dying and got it home, now it's home and I just don't know where to start. The MAF is plugged in, the AP read -10 a idle on the boost, so it doesn't seem to have any leaks, no codes were thrown, the engine doesn't sound weird when the idle smooths out, but the when it's rough, the car shakes pretty violently, and I hear a horrible vibration/shaking in the fuel tank behind me. On a side note, the past few months it seems like my Walbro is pretty damn loud, and when I'm at a stop I can hear it's drone, and if I rev it, it makes like a high pitched whine (but it does still prime when I turn it to the on position). On another side note, for as long as I can seem to remember, when I come to a stop in the car by clutching in, the revs always seemed to drop a little to 500, the car shakes a very little bit and the revs come up, but I heard that's pretty common? Is my fuel pump failing? Maybe it's just me, but on my last fill up (the current fill up that is) my car went through the first half a tank really fast, granted I have 750cc injectors, but it still seemed to go pretty fast. No drops of anything on the ground as far as I can see. Before this suddenly happened, the car was running AWESOME, I mean no hesitation or stuttering just raw power when I wanted it and normal when I didn't. Plugs on it are pretty new, the car only has 30k miles and I changed them maybe 15k ago to one step colder. I'm also 99% sure the last fill up was 93 as always (I go to the same gas station every fill up and they know me). Any clues? Thanks
Tom
Sorry bout the length of this, I just am a little scared, because anytime something like this did ever happen, it was a vac leak at the front mount somewhere, and this time the vac pressure checks out.
thebigevilfoot is offline   Reply With Quote
Old 10-22-2012, 01:18 PM   #2
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Sounds like a bosot leak to me. Have you secured the hose going from the top of the BPV to the back of the manifold? That one pops off pretty easily. Put it back on and use a zip tie. Also remove the rubber "caps" on both ends of the throttle body hose if you haven't done that already.
Old 10-22-2012, 01:18 PM   #3
Tripintaz
Member#: 245218
2013 STI Limited
#1 Check MUCH MORE thoroughly for boost leaks
#2 Check the AP to see if your fuel trims are trending beyond normal
#3 Check your fuel pump to make sure it is still operating correctly and that it is seated properly in the canister. Did you install it or did a shop? How did you address the part where people usually double up on the O-rings? (exactly why I'll never buy a warlboro for my car. The DW65c is a direct fit replacement)
Do the logs show anything weird?
Old 10-22-2012, 01:20 PM   #4
Tripintaz
Member#: 245218
2013 STI Limited
I just had to replace this hose yesterday. Mine blew open at one of the bends and then my vacuum lines started all popping off. A new BPV pipe and a bag of zip ties and its all good now.
Old 10-22-2012, 01:21 PM   #5
dsmtweaker
Member#: 265405
2013 Audi
What all mods do you have done?
dsmtweaker is offline   Reply With Quote
Old 10-22-2012, 01:53 PM   #6
thebigevilfoot
Member#: 253836
2008 AW e90 M3
Update, went downstairs to start it again. Started fine, gave it a rev, it shut right off as ifu turned the key. I put 2 rings on the pump, the bpv hose is On at the bpv. All work has been done myself. It fully bolted on minus turbo. Headerback fmic ebcs bpv etc.
Old 10-22-2012, 02:00 PM   #7
Jose99
Member#: 164319
2012 STi / 08LGT
Excuse my stupid question but why would you put two O-rings on the fuel pump instead of the one and the spacer thing that comes with it?
Jose99 is offline   Reply With Quote
Old 10-22-2012, 02:38 PM   #8
thebigevilfoot
Member#: 253836
2008 AW e90 M3
There is enough room for 2 rings and the spacer, 1 doesn't give a good seal, I dot mine is just si damn loud, at idle I can hear it over my frggen' magnaflow haha.
Old 10-22-2012, 02:55 PM   #9
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Check the other side of that hose.
Old 10-22-2012, 02:57 PM   #10
thebigevilfoot
Member#: 253836
2008 AW e90 M3
Will do. Thanks for the advice... Fingers crossed
Old 10-22-2012, 03:11 PM   #11
Tripintaz
Member#: 245218
2013 STI Limited
I had a hard time pulling mine off when I was replacing it yesterday. If that side blew off then holy ****.
Check the hose for any breaks too. Also, underneath the intake manifold where the BPV hose attaches to the turbo inlet is quite a few vacuum lines to check. IRRC there are 3 or 4 that attach to the turbo inlet itself. One is for the BPV, one for the PVC system, and one attaches to the boost sensor and if you have a 3 port EBCS probably that too. Towards the back of the intake where the BPV hose runs, there are 3 vacuum lines underneath it. 2 of them have little c clamps attached and one does not. You will want to check these too.
Old 10-22-2012, 04:32 PM   #12
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
That is the most common issue, besides the rubber caps on the throttle body hose. It is a straight, smooth, plastic nipple. No barb or clamp or anything to hold the hose on.
Old 10-22-2012, 05:21 PM   #13
Tripintaz
Member#: 245218
2013 STI Limited
I learn something new everyday. There are so many easier places for lines to pop off since that one has a clamp on it. My BPV pipe actually exploded out of the side rather than come lose from the turbo inlet or the BPV itself. But hey, I've seen crazier things happen to cars.
Old 10-22-2012, 06:35 PM   #14
thebigevilfoot
Member#: 253836
2008 AW e90 M3
Guys, I'm sorry, but I'm a dumbass. I rechecked all the piping to the FMIC, a quick tug and the passenger side pipe nearest to the core fell right out, retightened and it's good.
On a side note, I noticed that my targest boost at idle is -10.8 and mine only shows in at -10. Is this a big deal? Also I have a FMIC but am not tuned for it yet (I understand gains are not there, but I'm waiting for my universal IWG bracket to come in for my 20g retune) but since it's bigger can that explain why I'm at -10 instead of -11ish? Or do I just have a small leak somewhere? Thanks
Tom
Old 10-22-2012, 06:38 PM   #15
Wicked Performance
Member#: 265606
your target boost at idle that you are logging is simply whatever is in the boost control table. comparing it to your manifold pressure doesnt tell you anything as at anything less than wastegate boost pressure, that table wont have any effect.
Wicked Performance is offline   Reply With Quote
Old 10-23-2012, 09:56 AM   #16
Tripintaz
Member#: 245218
2013 STI Limited
Tom
It's called Target Boost because the ECU will try and reach that value. It's not always possible to hit the exact number the ECU is targeting. Hence TARGET.
I'm shaking my head that you didn't check the intercooler piping thoroughly first...
Old 10-23-2012, 11:58 AM   #17
some dude
Member#: 100300
06 WRX
CGM
Can u guys tell me why a boost leak would cause this type of behavior?
some dude is offline   Reply With Quote
Old 10-23-2012, 12:01 PM   #18
easterbran
Member#: 307359
'05 STi Stage II
My Sti showed the same problems and it turned out to be the A/F ratio sensor. Try unplugging yours and see if this fixes the rough idle? Just a thought.
easterbran is offline   Reply With Quote
Old 10-23-2012, 01:12 PM   #19
Mitchell.Hackney
Member#: 236195
2004 Mazda Miata
Man, this sounded very similar to mine, which turned out to be the fuel pressure regulator. I'd suggest keeping an eye on your Fuel Pressure since you've installed a larger fuel pump. I have a 2012 STi which is stock other than a DW65c Fuel pump and ID1000cc Injectors with an E85 Tune. My Fuel Pressure regulator went after 12000 Miles. (Maybe 1K with the new setup on a VERY conservative/daily driving tune)
Mitchell.Hackney is offline   Reply With Quote
