Welcome to the North American Subaru Impreza Owners Club Thursday March 23, 2017
Old 12-03-2012, 06:17 PM   #1
fnlyfnd
Member#: 100247
2015 Outback Premium
Carbide Gray
Default 2000 Impreza L 2.5L swap
The car is a 2000 L. The engine is a 2001 RS 2.5L
The car's 2.2L worked before the swap
The 2.5L worked before the swap
Timing is good
Fuel pressure is good
Coil pack and spark plugs are good
Compression is good
The motor cranks but won't start. We tested spark with an inline spark tester, and the problem seems to be with spark. We swapped a known working coil pack, and had the same result.
So, the question is; Why won't the ecu send the signal to fire?
fnlyfnd is offline   Reply With Quote
Old 12-03-2012, 07:33 PM   #2
m1r4g3
Member#: 220476
2--> 06 STI & 12 Leg
WRB & SWP
did you switch ecus?
m1r4g3 is offline   Reply With Quote
Old 12-03-2012, 09:07 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
Put the EJ22 engine harness (or whole intake manifold) onto the EJ25. Plug in the connectors and hit the key.
Jay
Old 12-05-2012, 07:33 AM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
Also, if you have changed the ECU to an EJ25 ECU.....put the EJ22 ECU back in. The pin locations are different between the models and not compatable.
Jay
