I have for sale my 2000 subaru 2.5 rs impreza all wheel drive 5 speed this has been the best car I've ever owned but am in need of a bigger vehicle for my family it has 0 problems no leaks doesn't smoke doesn't use water or oil I have always used mobile 1 when changing the oil in the past couple of months I have done some normal maintenance here is a list of all the new in recently new parts new front and rear DBS brake rotors new Hawk HPS pads front and rear 2 month old Dunlop Direzza star specs ( there awesome) Cobb intake new o2 sensors new knock sensor new timing belt and water pump new a oem red stitched shift boot and Foerster shift knob brand new aluminum dual core radiator Brand new fail safe thermostat brand new shifter bushings tws short shifter brand new 75 weight 140 Mobil 1 synthetic gear oil in the front trans and rear differential It has the factory CD player installed along with a factory sub it sounds pretty amazing for a stock setup It has the factory SUBARU alarm installed Transmission has no grinds or pop out it shifts as smooth as the day it was purchased this car literally needs nothing other than to be driven windows and sunroof work perfect AC and heat work perfect everything works as it should including the cruise control this car has been very well maintained an adult driven I have records for everything the only flaw on this car is that the roof and wing paint have faded mainly because it has been a Florida car all of its life it was originally purchased in Orlando and because it is a Florida car it is completely rust free it currently has 133 k on it interior is 8 out of 10 n I would say 7 out of 10 just because of the Roof and wing being faded all the other paint is awesome this car has just about every Factory option was available at the time including an Limited slip diff I have a clean carfaxreport and clean florida title in hand which means it is completely accident free call or text justin at 904 five nine nine 3603 .Justin pics can be seen here
http://jacksonville.craigslist.org/cto/3535078230.html
