See www.mapdccd.com for more information, purchasing, firmware downloads, setup and installation instructions.
Contact [email protected]
Feature overview
- Plug-and-play USB interface
- Four freely configurable DCCD control maps
- Tunable Auto mode
- Manual mode
- Free firmware updates with improvements and new features
- Full stand alone operation
- Live output display
- Built in precision 3-axis accelerometer
- Data logging output
- Parking brake override
- ABS override
- Input for integrating your own external sensors into your control maps e.g. gyros, accelerometers, steering wheel angle sensors, an external ecu input, an STI thumbwheel input, separate throttle and braking control maps and more!!
There are three main operation modes available. Any of the modes can be selected at any time. The three main modes are: manual, automatic and mappable modes 1 to 4. The MapDCCD controller lights will indicate the current operation mode and the live DCCD output.
Operation modes in detail
Manual mode
Manual mode is basic DCCD control. The front dial or external thumbwheel input is used to vary the static DCCD lock from 0 to 100%.
Automatic mode
Automatic mode is simple and automated DCCD control. Automatic mode varies the amount of DCCD lock based on your throttle position and your vehicles lateral acceleration using the built in accelerometers.
The DCCD lock is calculated using a continuous high speed mathematical model of vehicle dynamics to predict the required amount of DCCD lock.
The front dial or external thumbwheel input is used to vary the aggression of the vehicle dynamics model. Setting the dial high will bias the vehicle toward under steer tendencies, while setting the dial low will bias the vehicle toward over steer tendencies. The dial can be adjusted to any position in between to allow you to tune vehicle response to your preference.
Map modes 1-4
The map modes provide advanced DCCD control and are especially suited to a motorsports environment. Each map mode allows fine tuning of acceleration, braking, corner entry, corner exit and more
Each map mode has two main sections ***8211; The throttle section and the braking section. The braking section is activated when the foot brake is pressed; otherwise the throttle section is default.
Throttle section
The throttle section allows mapping of the DCCD lock based on four parameters: RPM, TPS, Vehicle speed and a sensor input. The sensor inputs available include internal lateral or longitudinal accelerometers or an external sensor.
Braking section
The braking section has two braking maps ***8211; one for when only the foot brake is applied and another for when the foot brake is applied and the throttle is also applied (and above a set threshold), deemed "left foot braking".
The braking section allows mapping of the DCCD lock based on four parameters: The foot brake being activated, TPS, vehicle speed and a sensor input. Like for the throttle section, the sensor inputs available include internal lateral or longitudinal accelerometers or any external sensor.
We are now proud to announce Maxwell Power Services as an official distributor where customers in the US can now purchase MapDCCD controllers directly. http://www.getadomtune.com/contactus.html
Control unit
Mapping software
Setup window
Example of live DCCD output
