Welcome to the North American Subaru Impreza Owners Club Saturday March 25, 2017
Old 02-22-2013, 12:20 AM   #1
VTL
Member#: 345791
07 GD
Grey
Default How to install remote start Viper 5904
Hi guys
I want to know if someone has already this installed on their car and can help me.
I dont know how to program the command and the wires to make the remote start work.
Some help please?
VTL is offline   Reply With Quote
Old 02-22-2013, 01:15 AM   #2
blessthekellen
Member#: 273859
MY98
WRX
Hah.
Goodluck.
If you have no experience with wires or remote starter/alarms, please do not just wing and attempt this. Pay a professional.
blessthekellen is offline   Reply With Quote
Old 02-22-2013, 01:34 AM   #3
AWDmonk
Member#: 271442
2006 Impreza 2.5i
CGM
http://www.bulldogsecurity.com/
I use this when I install remote start systems. It'll tell you what wires are what under the dash. After that, just read the directions from your kit and it should be pretty straight forward.
*I am not a professional and take no responsibility if you cause an electrical fire and burn your car to the ground.
AWDmonk is offline   Reply With Quote
Old 02-22-2013, 11:54 AM   #4
VTL
Member#: 345791
07 GD
Grey
its been done by a professional but the instructions are pretty vague, the only think that isent working properly is the remote start but the rest is fine
Old 02-28-2013, 10:48 PM   #5
treefan
Member#: 176856
02 wrx wagon
white
Why don't you bring it back to the professional to get it fixed. There should be a warranty if installed by a professional.
treefan is offline   Reply With Quote
Old 03-06-2013, 11:22 AM   #6
VTL
Member#: 345791
07 GD
Grey
not so easy like that, Im in venezuela and for what I see you need also to configure the control for a manual car and I cant do this configuration :/ looks like it dosent work or Im doing something wrong
Old 03-06-2013, 01:07 PM   #7
morse9443
Member#: 325412
2012 WRX
OBP Stg 2
This is a difficult install on a manual car. Do you have the bypass? You need to lose a key to it to make the remote start work on a manual.
Keep searching. There has to to be some install guidelines somewhere. The professional installer I use took 8 HOURS to install mine.
morse9443 is offline   Reply With Quote
Old 03-06-2013, 02:15 PM   #8
klarowe
Member#: 284753
2004 WRX STI
World Rally Blue
Because it is a manual transmission, they most likely disabled the remote start feature. There are multiple additional connections to make in order for it to work properly and safely. I agree with everyone here... pay a professional.
Morse: 8 hours ?!?!?!?! I own my own install business and have already done probably 4 or 5 new wrx's this season... and none of them took me over 3 hours. And even the 3 hour install was a full alarm with multiple sensors and additional options... and the first one I did. The last one I did (just a basic remote start / keyless entry) was done in about 1.5 hours.
klarowe is offline   Reply With Quote
Old 03-06-2013, 03:36 PM   #9
Modfydsubi
Member#: 310974
2011 WRX
BLK
The remote should tell you why it is not remote starting. When you press the remote start button, the alarm should beep and vibrate a certain amount of times telling you what is preventing it from starting. Most times, the alarm is not connected for remote starting simply because it is a liability for stick shift cars to have remote start function. The nuetral safety switch could be not grounded or the switch not plugged in, or it may be turned off. Even programming of the alarm could be an issue. I wouldnt know until you give us more info. I will tell you this though, if you never had him hook up the remote start from the beginning, you have alot more work to do. There is a module to bypass the chip in the key for the vats system. Two of which are available: DEI 556U which uses your stock key in order to similate correct resistance to start the vehicle OR DEI XpressKit which acts as a key when wired in place of the vats key system. Im telling you now, if installed incorrectly, the car WILL NOT start.....just know what you're getting yourself into.
Modfydsubi is offline   Reply With Quote
Old 06-22-2013, 06:56 AM   #10
tiozes
Member#: 360195
Hi I am Spanish and nobody here this type of alarm installed.
I installed the viper and everything works fine except the remote start.
There is no way to make it work always gives me the error of toggle switch off but it's all connected and the switch is ok, I've tried everything and not to do, always gives the same error.
regards
tiozes is offline   Reply With Quote
Old 06-23-2013, 01:49 AM   #11
Steven17s
Member#: 356852
2013 WRX
Pearl White
If your installer only installed the alarm portion of this unit, it will take just as long to install the remote start functions (Ignition wires, immobilizer bypass, clutch bypass, parking brake wire, neutral safety switch, brake wire, tachometer wire, hood switch, etc.). On top of that it will also need to be programmed to work in manual mode to safely use. I would follow everyone elses advice and pay to have the work completed if you have never done this before. Good luck!
Steven17s is offline   Reply With Quote
Old 06-23-2013, 05:33 AM   #12
crystalgreysti
Member#: 233085
2007 sti
cgm
So ived been thinking of getting this for my 07 sti. Im a noob in this area whats bad about installing it on a manual transmission?
crystalgreysti is offline   Reply With Quote
Old 06-23-2013, 07:53 AM   #13
tiozes
Member#: 360195
I have installed all the cables and everything works fine, but no way to activate the remote start, always appears the toggle swich off and tachometer is not programmed with the cars rpms.
Old 06-23-2013, 08:00 PM   #14
wrxeter
Member#: 134734
2013 WRX SE
Tangerine Orange Peel
There's nothing bad about it. It's just the complexity of installing it on an auto vs a manual.
A manual has to be wired to make sure the remote start will only engage if the car is not in gear, tricks the ECU into thinking the clutch is pressed, bypasses the transponder, makes sure the engine isn't already running, and that the hood is closed.
wrxeter is offline   Reply With Quote
