09-19-2002, 04:53 PM | #1 |
Member#: 563
Vehicle:2002 Subaru WRX WR Blue Pearl |
Differential and Trany fluids?
Hey all, approaching 30k on my rex and I am going to flush the coolant here at the shop I work at, but my question is what fluids are in the tranny and the rear diffs? What kind should I replace it with? Do I need to just change the rear diff fluid or change the center diff also?
THanks Steve
09-19-2002, 05:19 PM | #2 |
Member#: 6006
Vehicle:2002 WRX |
i was in the same situation..heres my post
hope this helps http://forums.nasioc.com/forums/show...hreadid=239115 |
09-19-2002, 07:13 PM | #3 |
Member#: 563
Ok, so I use 75 90ns (3.7 qts) in the tranny and just regular 75 90 in the diff?? How many quarts in the diff? Thanks for the reply.
09-19-2002, 10:11 PM | #4 |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
You can either read GQ's reply to that post or look in the owner's manual as suggested in that post... 0.8 quart .
Brian http://www.northursalia.com http://www.imprezamods.com http://www.scoobymods.com http://www.deniedmywarranty.org |
09-20-2002, 08:06 AM | #5 |
Member#: 563
Ok, thank you sir, that clears that part up. Do you use 75 90ns for the tranny and regular 75 90 for the diff? or do you use 75 90ns on both. THanks
Steve |
09-20-2002, 04:32 PM | #6 |
Member#: 6006
Vehicle:2002 WRX |
75-90ns=front
75-90=reAR |
Differential Oil and Transmission fluid question | Popwar4207 | Newbies & FAQs | 4 | 06-19-2009 06:17 PM |
differential and transmition fluid swap | zonda128 | Newbies & FAQs | 15 | 05-18-2009 05:43 PM |
differential and auto trans fluid leaks - Subaru Liberty | rjbonde | Newbies & FAQs | 0 | 09-17-2003 09:01 AM |
differential and auto tranny fluid | Kevex | Service & Maintenance | 4 | 03-11-2002 10:36 PM |
quick ? bout trany fluid | Sobelizard109 | Transmission (AT/MT) & Driveline | 6 | 01-03-2002 11:40 PM |
