Welcome to the North American Subaru Impreza Owners Club Monday January 21, 2019
Old 03-29-2013, 04:03 PM   #1
S206DGM
Member#: 339537
Default et35 Track Use on GV WRX/STi?
Does anyone run a et35 for track use on a 2011-2013 wrx?
S206DGM is offline   Reply With Quote
Old 03-29-2013, 06:01 PM   #2
kos
Member#: 118334
2006 Carmine Red WRX
2005 Aspen White RS
In terms of offeset for wheels? Yes. Plenty. Our FAT / Snail Performance 09 WRX runs 18x9.5 +35 and will be running a 10JJ +20 once the new wheels arrive.
kos is offline   Reply With Quote
Old 03-29-2013, 06:25 PM   #3
S206DGM
Member#: 339537
I didnt know if people were concerned with the lower offset and how it might effect the wear on suspension/hub parts
Old 03-29-2013, 07:17 PM   #4
kos
Member#: 118334
2005 Aspen White RS
The wheel bearings on the 09+s are very easy to replace as well, unlike the 02-07s which needed to be pressed in.
Old 03-29-2013, 11:26 PM   #5
Rokkit
Member#: 84181
NASA #530 GTS2
I run +45 with a 15mm spacer... it puts more wear on the wheel bearing sure... But you're tracking the car and should be mindful of these wear parts and inspect them frequently.
You will replace 5x100 hubs more often than the 5x114 due to design as kos said.
Rokkit is offline   Reply With Quote
Old 03-31-2013, 11:10 PM   #6
S206DGM
Member#: 339537
I need some advice.
I have a set of 17x8 et45 RPF1s and a set of Rota G Force 18x9 et35. I prefer the look of the rotas for daily driving however I do go to some track events.
I definitely need to pick up some new tires for the Rota and the RPF1 and was thinking about maybe downsizing my wheel collection. My question is, would it be okay to track the Rotas and get some star specs?
Old 04-01-2013, 12:30 PM   #7
kos
Member#: 118334
2005 Aspen White RS
I have tracked Rotas, never had a problem with mine. They also get daily driven as well, 18x9 G forces just like what you have.
