Welcome to the North American Subaru Impreza Owners Club Saturday December 15, 2018
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 04-04-2013, 04:15 PM   #1
Subimods
Vendor Sales Rating: (32)
Member#: 209139
2016 STi
Hyper Blue
Cool Turbo Inlets, Intercooler Y pipes, After Maf Tubes, Synapse Diverter valves, + more!
It seems as if everyone gets the normal mods done to their car but always forget about the other add on products like the Turbo Inlets, Intercooler Y pipes, Maf Hoses and some other overlooked items!!!
For starters we have a few choices for the Turbo Inlet:
[11311] Retail: $189.99
PM us for our Low Pricing SHIPPED!!!
The "Generic" Turbo inlet is the most economical inlet we carry.
Fitment is great on these and for the price you can't go wrong.
Perrin Performance Turbo Inlets, one of the best on the market!
[PSPINT401] Retail: $229.99
Intercooler Y Pipe Kits:
The Colors currently available are Black, Blue and Red. Pricing is the same for all color options too.
02-05 WRX
[MMHOSE-SUB-INT BK/RD/BL] Retail: $136
06-07 WRX
[MMHOSE-SUB-INT6 BK/RD/BL] Retail $160
04-07 STI
[MMHOSE-SUB-INT4 BK/BL/RD] Retail: $116.00
After Maf Tube:
02-04 WRX & STi
MIshimoto After MAF tube, both 76mm and 80mm available
76mm [MMHOSE-WRX-AM7 BK/BL/RD] Retail: $85.00
80mm [MMHOSE-WRX-AM8 BK/BL/RD] Retail: $89.00
Electronic Boost Control Solenoid:
GrimmSpeed Electronic Boost Control Solenoid made for every turbo'd subaru 02+
Direct Plug&Play, **Will need tuning after installed**
PN: [057001-2-3-7]
Retail: $119.99
Synapse Synchronic Diverter Valve - 2002-07 WRX/04-11 STi:
A few specs on this item:
Synchronic DV is the first, truly compact, zero-diaphragm, high-flow Diverter Valve with a blistering actuation time measured at 25 milliseconds. Mass air flow (MAF) and speed density (MAP) applications can apply the new design in push or pull orientation with the ability to fully re-circulate or vent-to-atmosphere the valve’s discharge. Construction is based on near-net investment casting of aerospace-grade Aluminum for the body, followed by post-process CNC machining of all components including the forged billet 6061 actuator assembly. A complete selection of available mounting flanges are interchangeable between the SB and DV series and users can either upgrade from an existing BOV/DV by simply bolting on an adapter or weld on to a new project using the Aluminum or Stainless weld flanges. Boost/vacuum connections are made via 1/8th NPT threaded bosses that accept either Boost Connect™ or included nickel-plated-brass barb fittings. Each assembly is pressure tested to withstand 60 psi and positive lock clamshell retainers are included with each assembly for fitment.
This kit is for 02-07 Subaru WRX and 04-11 STI with Top Mount Intercooler.
[DV001A.004] Retail: $279.00
K&N drop in Panel filter available for the 02-07 (pictured) and also the 08+ upon request!!!
K&N's high flow replacement air filters are designed to increase horsepower and acceleration while providing excellent filtration. K&N replacement air filters are washable and reusable and come with a 10 Year / Million Mile Limited Warranty. Simply replace the OEM filter with a K&N FilterCharger® replacement filter and drive for up to 50,000, depending on driving conditions, then follow the cleaning instructions to use the filter again and again.
Retail:71.21
Our Price is $45
PM us on more Combination Details on other misc. pieces
__________________
[CENTER][SIZE="3"][B][COLOR="Red"]
[COLOR="Black"][B]|[/B][/COLOR] [COLOR="Red"]Lowest Prices On Subaru Performance Parts Anywhere[/COLOR][/COLOR] [B][COLOR="black"]|[/COLOR][/B] [COLOR="SeaGreen"]Price Matching Available[/COLOR][/SIZE]
[SIZE="1"][COLOR="Black"]ALL "Shipped" prices are for within the Continental US Only (Lower 48 States). Military & First Responder Discounts Available! We want to earn your business![/COLOR][/SIZE] [/B]
[B][COLOR="Black"]Email:[/COLOR][/B]
[B][COLOR="Black"]Phone:[/COLOR][/B] 860-291-0015 [b][COLOR="Black"]Facebook:[/COLOR][/b]
[b][COLOR="Black"]Instagram:[/COLOR][/b]
[/CENTER]
Subimods is offline
Old 04-05-2013, 03:12 PM   #2
Subimods
Member#: 209139
2016 STi
Hyper Blue
COBB SF Short Ram Air Intake (08+ STI)
Available in Blue & Black
Retail: $195
Sale Price: $195
Cobb's SF Impreza WRX STI Intake system utilizes several unique features in an effort to maintain optimal flow for performance while minimizing turbulence that can cause engine management problems. Cobb's straightener grid is specifically designed to smooth the incoming air flow as it passes the Mass Air Flow (MAF) sensor for precise readings. This eliminates the "dead spots" caused by intake turbulence. In order to provide a Legacy GT intake system that looks as good as it functions, Cobb utilized a one-piece plastic high-temperature composite plastic body. Not only does this save weight, it also prevents heat soak, keeping incoming air cooler. You will not find a more researched & developed short ram intake for your Legacy GT than the Cobb SF.
COBB SF Air Box (08+ STI)
Available in Black
Retail: $135
Sale Price: $135
The Cobb Tuning SF Air Box was designed to capture the cool air supplied to the SF intake through the factory intake snorkle. The aluminum heat shield consists of a one piece surround, directional lid, and stainless fasteners that help reduce a loss of power that could be robbed from your motor by a heated intake charge.
Special NASIOC Pricing Combo $315
__________________
[/CENTER]
Subimods is offline
Old 04-08-2013, 02:58 PM   #3
Subimods
Member#: 209139
2016 STi
Hyper Blue
All PM's replied and orders shipped!!!
__________________
[/CENTER]
Subimods is offline
Old 04-09-2013, 12:03 PM   #4
Subimods
Member#: 209139
2016 STi
Hyper Blue
Don't skimp out on the intake systems factory weak points, make your turbo breathe better!
All PM's replied
__________________
[/CENTER]
Subimods is offline
Old 04-09-2013, 05:27 PM   #5
Subimods
Member#: 209139
2016 STi
Hyper Blue
Perrin bits shipped out!!! Thanks again
__________________
[/CENTER]
Subimods is offline
Old 04-10-2013, 12:46 PM   #6
Subimods
Member#: 209139
2016 STi
Hyper Blue
To the TOP!!!
__________________
[/CENTER]
Subimods is offline
Old 04-11-2013, 01:36 PM   #7
Subimods
Member#: 209139
2016 STi
Hyper Blue
Orders shipped out, pre-weekend orders out the door!!!
__________________
[/CENTER]
Subimods is offline
Old 04-12-2013, 01:14 PM   #8
Subimods
Member#: 209139
2016 STi
Hyper Blue
All PM's replied, FRIDAY BUMP!!!
__________________
[/CENTER]
Subimods is offline
Old 04-15-2013, 01:26 PM   #9
Subimods
Member#: 209139
2016 STi
Hyper Blue
Specs on the Synapse brand are replied to along with the inlets
Thanks for the orders guys
__________________
[/CENTER]
Subimods is offline
Old 04-16-2013, 01:52 PM   #10
Subimods
Member#: 209139
2016 STi
Hyper Blue
PM's replied, shipped out a few turbo inlets the other day. Good luck with the installs guys!!!
__________________
[/CENTER]
Subimods is offline
Old 04-17-2013, 12:12 PM   #11
Subimods
Member#: 209139
2016 STi
Hyper Blue
PM's replied, there is a difference in the USDM and JDM Intercooler Y-pipe kits so please let me know what you have when ordering!
Thanks, Justin
__________________
[/CENTER]
Subimods is offline
Old 04-18-2013, 10:56 AM   #12
Subimods
Member#: 209139
2016 STi
Hyper Blue
PN: [057001-2-3-7]
Retail: $119.99
__________________
[/CENTER]
Subimods is offline
Old 04-18-2013, 06:30 PM   #13
Subimods
Member#: 209139
2016 STi
Hyper Blue
Perrin orders shipped out
__________________
[/CENTER]
Subimods is offline
Old 04-19-2013, 12:31 PM   #14
Subimods
Member#: 209139
2016 STi
Hyper Blue
PM's replied, GS EBCS shipped out
__________________
[/CENTER]
Subimods is offline
Old 04-19-2013, 09:57 PM   #15
shawnb1984
Member#: 353123
2006 Sti
Hello, what could you do for the 06 Sti Perrin After Maf Intake tube in Red, thanks.
shawnb1984 is offline
Old 04-22-2013, 12:06 PM   #16
Subimods
Member#: 209139
2016 STi
Hyper Blue
PM sent!
__________________
[/CENTER]
Subimods is offline
Old 04-23-2013, 02:23 PM   #17
Subimods
Member#: 209139
2016 STi
Hyper Blue
Retail:71.21
Our Price is $45
__________________
[/CENTER]
Subimods is offline
Old 04-23-2013, 06:39 PM   #18
Subimods
Member#: 209139
2016 STi
Hyper Blue
All PM's replied
__________________
[/CENTER]
Subimods is offline
Old 04-25-2013, 01:55 PM   #19
Subimods
Member#: 209139
2016 STi
Hyper Blue
To the top! Let your turbo spool easier
Contact us today for more details
__________________
[/CENTER]
Subimods is offline
Old 04-26-2013, 05:37 PM   #20
Subimods
Member#: 209139
2016 STi
Hyper Blue
__________________
[/CENTER]
Subimods is offline
Old 04-29-2013, 03:23 PM   #21
Subimods
Member#: 209139
2016 STi
Hyper Blue
All PM's on Perrin products replied Available in multiple colors!!!
__________________
[/CENTER]
Subimods is offline
Old 04-30-2013, 11:43 AM   #22
Subimods
Member#: 209139
2016 STi
Hyper Blue
All PM's replied and packages made
__________________
[/CENTER]
Subimods is offline
Old 05-01-2013, 12:59 PM   #23
Subimods
Member#: 209139
2016 STi
Hyper Blue
All PM's replied and orders shipped out from last night
__________________
[/CENTER]
Subimods is offline
Old 05-01-2013, 04:02 PM   #24
Subimods
Member#: 209139
2016 STi
Hyper Blue
Retail: $195
Sale Price: $195
Available in Black
Retail: $135
Sale Price: $135
__________________
[/CENTER]
Subimods is offline
Old 05-02-2013, 03:40 PM   #25
Subimods
Member#: 209139
2016 STi
Hyper Blue
PM's replied and orders shopped out.
If you have any questions or comments then please feel free to PM or give us a call today!
__________________
[/CENTER]
Subimods is offline
Closed Thread
