Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2020
Old 04-18-2013, 06:38 PM   #1
tloo13
Member Sales Rating: (2)
Member#: 288403
2009 WRX
Default ISC Wheel Adapters
Product: ISC Wheels adapters
Style Reviewed: Gold adapters, 15MM wide
Vehicle used for review: 2009
MSRP: $ 299.00
Where to buy: http://www.iscsuspension-na.com ( I got mine from AJW Performance )
Description according to ISCs website:
Finally, A name brand Subaru wheel adapter that works well and is affordable! No sense in paying 450.00 for competitors adapters any longer. This set ( 4) of bolt pattern adapters will allow you to bolt STI fitment wheels (5x114) to your WRX (Legacy, Forester, BRZ or any 5x100 Subaru)! These are 15mm wide.
The ISC Subaru wheel adapters fit all 5x100 Subarus. Precision CNC-machined billet aluminum bolt pattern adapters, and twenty special low-profile lug nuts. The adapters are hub-centric for both the car and wheels. Offered in both a anodized ISC gold, or a stealth black finish. ISC Logo is engraved on spacer as well.
Materials Used:
Adapter: CNC 7075 light weight high grade aluminum
Included Hardware: M12*1.25, Grade 10.9
Initial Impression: Once i opened the box, i could see the outstanding anodized gold finish peeking out from behind the bubble wrap. everything looked great, and i couldn't wait till i could put them on my car.
Here is a quick step by step with pictures that i took throughout the installation process.
1. gather all the parts that you need for the install
2. I also did a quick test fit of the adapters into the back of the new wheels, just as a double check. As i expected, the ISC adapters fit flawlessly into my BBS.
3. Get the car off the ground and remove all 4 wheels. If you don't have access to a lift, a jack and 4 jack stands works just as good.
4. Once all the wheels are off, take a wire brush and clean up all the surfaces the adapters will be mating to.
5. Add a little bit of anti-seize around the center bore pilot, so that the adapters will come back off when it is time for the winter wheels to go back on.
6. Install the spacers over the car's studs with the supplied hardware from ISC. Tighten these bolts in a cross star-like pattern, just as you would tighten wheel lug nuts. Torque to 86 ft-lbs.
As you can see from the above photo, the lugs are sticking out pretty far past the adapters. This will cause problems when trying to mount the wheel,causing the wheel to hit the studs before actually tightening down, so be careful. According to ISC, wheel stud modification is only required with the 15 mm adapters and the 25 mm adapters require no modification to your stock wheel studs.
7. My BBS wheels that i am mounting on the car have pockets on the back of the wheel, but were not deep enough. so, i had to trim 1/4" off of each stud. Also, cutting this little amount off allows me to still run my winter wheels without the adapters installed.To do this, i used a cutoff wheel on an air tool, but if you are good with a sawzall, that will work too. After all 20 studs were cut, i used a M12 x 1.25 thread chaser to clean up any and all threads that may have gotten damaged. This was a very easy process, just time consuming due to the number of studs. Re-install the adapters on the car.
8. Test fit the wheels on the car. Take special notice to where the wheel meets the mating surface of the adapter, making sure that it is flat and there is no clearance issues with the lugs hitting the wheel.
9. If everything looks good, you're ready to put your new, 5 x 114 STI bolt pattern wheels on. Be sure to torque all wheels to 86 ft-lbs. Because the wheel adapters are new, it will take some time for the new studs to seat properly into the aluminum body of the adapter. I torqued all my wheels as usual, then went around the car again and re-did them all again. I then drove the car around the block, and re-torqued them a third time. i also re-torqued them after 100 miles of driving, just to be sure.
After driving on these for almost a week, there is nothing but positive things i can say about these. All winter i struggled with a new summer wheel decision and the lack of variety in the 5x100 bolt pattern. Once i heard that ISC had the 5x100 to 5x114 adapters coming out this spring, it increased my options ten fold. I love the way my car looks with the new wheels, and that wouldn't have been possible without the quality and affordability of these adapters from ISC. TWO THUMBS UP FROM ME!!
tloo13 is offline   Reply With Quote
Old 04-19-2013, 02:59 AM   #2
jinstwrx
Member#: 338623
2011 Subaru WRX
red
any vibration at high speed?
looking forward to a future update. lol
jinstwrx is offline   Reply With Quote
Old 04-19-2013, 12:08 PM   #3
tloo13
Member#: 288403
2009 WRX
nope, I have not experienced any vibrations at all so far. The car feels great!
Old 04-19-2013, 12:45 PM   #4
burnurass
Member Sales Rating: (23)
Member#: 176557
2013 Impreza WRX
More pictures but in 25mm if anyone was curious
burnurass is offline   Reply With Quote
Old 04-19-2013, 04:27 PM   #5
tloo13
Member#: 288403
2009 WRX
A few side shots after the install...
Old 04-20-2013, 08:03 AM   #6
yudangorgor
Member Sales Rating: (4)
Member#: 151107
2011 WRX
is it advised to use spacers if i'm tracking my car?
I mean I can always take them out for track and put them back on for street driving..
i hear them being bad for wheel bearing, but wouldn't it be the same thing if you got lower wheel offsets?
yudangorgor is offline   Reply With Quote
Old 04-24-2013, 07:50 AM   #7
burnurass
Member#: 176557
2013 Impreza WRX
25mm ISC Spacer/Adapters installed with 08+ STI BBS wheels. 18x8.5+55 offset. +30 actual offset after the spacers. I'm running 245/40/18 tires.
Stock alignment, Stock Suspension/Height.
I need a roll in the rear for sure. :P It's rubbing on bigger dips/hard turns, especially with a full load.
Old 04-24-2013, 08:16 AM   #8
tloo13
Member#: 288403
2009 WRX
Looks good man!
Old 04-26-2013, 12:38 PM   #9
bue car
Member Sales Rating: (192)
Member#: 176134
1995 Coupe, Sedan &
Wagon!
FYI, you will not have to cut your oem studs if your wheels have the pockets in the back, like OEM wheels do.
bue car is offline   Reply With Quote
Old 04-26-2013, 12:39 PM   #10
burnurass
Member#: 176557
2013 Impreza WRX
The pockets are too small on the STI BBS wheels.
They still have to be notched out on the STI Enkei's (there's a forester guy that did it).
20MM will def clear, and obviously I have no issues with the studs with 25mm.
Old 04-26-2013, 01:15 PM   #11
bue car
Member#: 176134
1995 Coupe, Sedan &
Wagon!
Good notes right there! Maybe just the earlier models had bigger gaps?
Old 04-26-2013, 01:17 PM   #12
burnurass
Member#: 176557
2013 Impreza WRX
I guess so, not really sure!
I just know for the GR/GV chasis wheels, there isn't enough room for sure.
Evidence (15mm with GR Sti BBS wheel)
Old 04-30-2013, 10:29 AM   #13
naCAnItihS
Member Sales Rating: (15)
Member#: 259481
2002 WRX STI Wagon
MBP
I recently purchased the ISC Suspension 15mm wheel adapters from AJW Performance.
Vehicle used for review: 2001 Subaru Forester L
Wheels used for review: 2005 STI Gold BBS 17x8 et 53
Initial Impression: Once I received these adapters and inspected them I noticed that they seemed like a quality piece. The machining/anodize seemed to be of great quality. They fit on the hubs and into the wheels perfect. However I did have to cut back the studs for the wheels to fit perfectly. I knew I was prob going to have to do this when I ordered them. No big deal. My other set of winter wheels (Rota Boosts) still fit on the lugs perfect.
Overall Impression: I am very satisfied with the adapters and would recommend them to others. I kind of wish I went with the 25mm adapters just for a more aggressive fitment and lack of having to cut the studs. But its all good and I am happy. I have about 1k miles or so on them now.
A few installation notes:
-CLEAN your hubs thoroughly (car and wheel). I experienced a bit of steering wheel vibration because I did not do this (pulled winter wheels off and put the adapters on).
-Also torque them to the hub in a step sequence. I did 50ftlb then 75ftlbs then 90ftlbs.
-Recheck the torque on the wheels after finishing all the wheels and then again after a bit of driving. The lugs will fully seat into the adapter a bit and may cause your lugs to come loose initially.
naCAnItihS is offline   Reply With Quote
Old 04-30-2013, 10:44 AM   #14
tloo13
Member#: 288403
2009 WRX
Fozz looks awesome!
Old 05-04-2013, 09:19 AM   #15
IMPORTIMAGE
NASIOC Storefront Vendor
Vendor Sales Rating: (617)
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
wow, lots of great reviews!
__________________
Open Daily
#1-941-257-9618 AIM= importimagerace
Best Deals on
!!! Let us Beat your Lowest Price Quote!!!!!
IMPORTIMAGE is offline   Reply With Quote
Old 06-14-2013, 01:29 PM   #16
ISC Suspension
Vendor Sales Rating: (0)
Member#: 252676
These have been a real hit thus far!
__________________
[B]Business Hours:[/B]
9am-5pm EST
603-715-9078
[I][B]Join us on our Social Media![/B][/I]
[B]Contact Info:[/B]
[B]All service, rebuilds, and customer support done in USA.[/B]
ISC Suspension is offline   Reply With Quote
Old 08-13-2013, 01:11 PM   #17
ISC Suspension
Member#: 252676
How is everyone liking their adapters?
__________________
9am-5pm EST
603-715-9078
Old 12-10-2013, 04:46 PM   #18
brianglawson
Member Sales Rating: (3)
Member#: 229468
2004 Impreza WRX STI
do you sell a 20mm version of this??? would 20mm clear everything without having to have pockets or trim studs?
brianglawson is offline   Reply With Quote
Old 12-15-2013, 12:49 PM   #19
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
They have been working out really great we've found in combination with the cosmis racing wheels to get those wide wheels on our 5x100 buddies into a subaru friendly offset!
__________________
Open Daily
Best Deals on
Old 02-08-2014, 08:23 PM   #20
dsolis
Member Sales Rating: (36)
Member#: 121775
2008 STi Hatch
Aspen White | Gold BBS!
Product: ISC Wheels adapters 5x100 to 5x114
Style Reviewed: Black adapters; 15MM
Vehicle used for review: 2000 Subaru Impreza 2.5rs coupe
Initial Impression: The machined anodize are most certainly of great quality, definitely impressed! Having them hubcentric is also an added piece of mind. Sit perfectly on the hub.
Overall Impression: Extremely satisfied with them, zero wheel vibration!
Notes:
For GC8 owners; you will need to cut about 5mm off your studs to clear the BBS, unfortunately the pockets behind the wheels were not deep enough. Nothing my little Dremel couldn't handle!
Here they compliment the ISC coilovers
dsolis is offline   Reply With Quote
Old 02-24-2014, 10:11 AM   #21
WRS
Member#: 46359
2006 FSTI
ASPEN WHITE
Will post pics of my 25mm installation, Maybe the 20 mm is a good idea for futur.
WRS is offline   Reply With Quote
Old 03-11-2014, 01:41 PM   #22
08Legacy-GT
Member Sales Rating: (18)
Member#: 325949
interesting, thanks for the pics/review!
I hear that running spacers though isn't good in the long run but maybe come winter i'll be getting myself some BBS goldies and not at the absurd 5x100 prices!
08Legacy-GT is offline   Reply With Quote
Old 03-16-2014, 04:41 AM   #23
raytay112
Member#: 353398
i noticed that these adapters posted from the past has 7075-T6 stamped on it. and on AJW website as of today 3/16/14 it's called out 6061. any reason behind this?
raytay112 is offline   Reply With Quote
Old 03-17-2014, 12:10 PM   #24
AJW Performance
Vendor Sales Rating: (38)
Member#: 219896
There was a mix up when the info was originally written, they are indeed 7075-T6. We'll get t work on updating this, thank you for bringing it to my attention.
- AJW Performance IT Guru
__________________
[B]Best Pricing and Customer Service in the Business![/B]
[B]Shop Line: 603-715-9076[/B]
[B]Hours:[/B]
[B]Monday- Friday Closed weekends[/B]
[B]9:00 AM to 5:00 PM at shop[/B]
[B]21 Meadowbrook Ln[/B]
[B]Unit 10[/B]
[B]Gilford, NH 03249[/B]
facebook us: "AJW Performance"
Follow some of our work- [U]
[/U]
AJW Performance is offline   Reply With Quote
Old 05-05-2014, 12:39 PM   #25
WRS
Member#: 46359
2006 FSTI
ASPEN WHITE
Rolled rear fender, no rub. 2006 FXT, 5x100 to 5x114.3 25mm with BBS 18" STI.
Zero Camber : Will try to set it at -1.5 degré.
