Welcome to the North American Subaru Impreza Owners Club Sunday June 25, 2017
Old 04-22-2013, 12:22 AM   #1
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
After having the bumper off a bunch of times the clips weren't holding it as well as they used to. On the track the corners pop out at high speed and near the passenger head light the edge was always misaligned. I found a picture of a time attack car on nasioc that had used Dzus fasteners to hold the bumper on so I decided to try it myself.
Some of you may be familiar with these clips but I've never really messed with them.
I replaced 4 of the 6 under hood plastic clips with dzus self ejecting fasteners. The holes needed to be opened slightly using a step drill bit.
under view
For the corners that were popping off, I had to install them on the outside of the bumper. Here's what I used:
I used the existing screw hole with a longer screw to mount the backing plate.
back side of bumper with washers to give the rivet something to grab:
Fastener ejected:
Driver side tightened:
Passenger side:
I can now take the bumper off with nothing more than a flat head screwdriver or a quarter in about 30 seconds and it's held on a lot better than it was with the plastic clips.
06rexwagon is offline   Reply With Quote
Old 04-22-2013, 12:45 AM   #2
04wrx008
Member#: 261447
2004 Impreza WRX
Great job! This is how a removable bumper should look!
I'll be doing a fmic soon and might have to do this as well!
04wrx008 is offline   Reply With Quote
Old 04-22-2013, 01:35 AM   #3
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Looks good. Way better than those stupid latches that are an eyesore, but why not put them on another part of the bumber that is not a body line? Also, do they come in black?
Old 04-22-2013, 11:27 AM   #4
vision.dynamix
Member#: 139955
2015 Subaru STI
2017 Forester 2.5i
Latches are toolless.
Old 04-22-2013, 11:31 AM   #5
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Where did you order the Dzus fasteners from?
Psychoreo is offline   Reply With Quote
Old 04-22-2013, 11:32 AM   #6
vision.dynamix
Member#: 139955
2015 Subaru STI
2017 Forester 2.5i
Jon I found a huge box in my garage if you want some.
Old 04-22-2013, 11:41 AM   #7
STMTuned
Member#: 227871
STM
00 Drag RSTi [email protected]
Good write-up and nice work on that.
STMTuned is offline   Reply With Quote
Old 04-22-2013, 12:44 PM   #8
06rexwagon
Member#: 114730
[email protected]
you can take these off with a penny and they look much cleaner than a latch in my opinion.
This place:
http://www.bryke.com/Dzus_Fasteners.html
Old 04-22-2013, 12:45 PM   #9
kpluiten
Member#: 120273
06 WRBWRXWGN
You don't have a a coin or key anywhere in the car or the immediate vicinity? No one around you has one either? You are that tool-less??
Any if you're that tool-less, why are you taking your front bumper off in the first place?
Old 04-22-2013, 01:06 PM   #10
m1r4g3
Member#: 220476
2--> 06 STI & 12 Leg
WRB & SWP
what size are they
m1r4g3 is offline   Reply With Quote
Old 04-22-2013, 02:06 PM   #11
06rexwagon
Member#: 114730
[email protected]
Originally Posted by m1r4g3 View Post
what size are they
5/16" with long plates.
Old 04-24-2013, 01:26 PM   #12
brendan04wrx
Member#: 167494
04 STi
psm
looks great! wish I did these before I put my bumper on/off 6 times
brendan04wrx is offline   Reply With Quote
Old 05-08-2013, 02:53 PM   #13
SubaruWrxNewb
Member#: 236017
Did using these eliminate everything else? I'm trying to figure out what I would need so that I could eliminate having to unbolt the bumper to the fenders, those bolts behind the fender liners are a pain.
SubaruWrxNewb is offline   Reply With Quote
Old 05-08-2013, 03:31 PM   #14
vision.dynamix
Member#: 139955
2015 Subaru STI
2017 Forester 2.5i
This place:
Depending on the tension of the fastener, a coin doesnt always work.
I never said I was toolless. But sometimes I forget to keep a flathead handy, or in haste one gets lost or ends up at the bottom of the toolbox. I dont always take the bumper off to work on it. Most of the times its to get the car on a trailer. At night, in the dark.
You can eliminate everything if you want. You dont have to use any fasteners besides the ones at the corner of the bumper/fender.
Old 05-08-2013, 09:01 PM   #15
NJ_wrx
Member#: 268855
2009 WRX
red
I really like the functionality and clean look. I've taken my bumper off so many times that I had to get a body shop to glue it back on at the clips connecting to the fender. No adding fog lights in the future for me
NJ_wrx is offline   Reply With Quote
Old 05-08-2013, 09:10 PM   #16
2004wrxy
Member#: 237136
2003 WRX 6MT
JBP
nice work!
2004wrxy is offline   Reply With Quote
Old 09-09-2013, 10:28 AM   #17
sledge_hammer
Member#: 125784
2004 Wrx
Whats the best way of properly drilling through the bumper and getting it aligned with the bracket?
sledge_hammer is offline   Reply With Quote
Old 09-09-2013, 05:56 PM   #18
MattyQ610
Member#: 288729
sweet set up man
MattyQ610 is offline   Reply With Quote
Old 09-10-2013, 11:35 AM   #19
06rexwagon
Member#: 114730
[email protected]
I install the bracket first, without the spring in place. Then I mark the back side of the bumper through the center of the bracket hole. Drill a small pilot hole from the back, then put the bumper in place and drill toward the bracket with step bit. The step bit will self center in the hole of the bracket.
Old 09-10-2013, 10:39 PM   #20
scottg25
Member#: 368010
Do they make these for the 05 wagon?
scottg25 is offline   Reply With Quote
Old 09-10-2013, 10:50 PM   #21
06rexwagon
Member#: 114730
[email protected]
They don't make a kit for any of our cars. I just ordered some fasteners from bryke racing and did a custom install. You can do it on any year.
Old 09-11-2013, 12:30 AM   #22
dinggoo
Member#: 295432
2003 WRX
MBP
Well looks like I found my next mod glad I didn't add the latches yet
dinggoo is offline   Reply With Quote
Old 09-11-2013, 09:46 AM   #23
ergastjrtwen
Member#: 368041
ergastjrtwen is offline   Reply With Quote
Old 09-12-2013, 09:29 AM   #24
dyjedyjstfwen
Member#: 368146
dyjedyjstfwen is offline   Reply With Quote
Old 09-12-2013, 09:34 PM   #25
xirallicgdb
Member#: 247850
2007 SWP STi
CGM '07 Forester
I really like this too. I may follow your foot steps here. I've been trying to figure out how to QR the bottom though? Maybe a rod that holds the bottom to the frame somehow with a dzus.
Thanks for the great idea!
xirallicgdb is offline   Reply With Quote
