Welcome to the North American Subaru Impreza Owners Club Saturday October 24, 2020
Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 05-09-2013, 03:50 PM   #1
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
Default I'd like to play a game- guess my horsepower before I hit the dyno Saturday!
Ok I am going to the dyno Saturday. What do you guys think I will put down? I have an idea but would like to hear your opinions.
Dyno: Dyno Tech's mustang Dynamometer
Tuner: Jay Perry of Perry Tuned
Car: 2002 Subaru WRX Wagon MBP
Mod List:
Power:
-30k Stock EJ20 Long Block
-IHI VF-22 Turbo
-DW 750cc Injectors
-Walboro 255LPH Fuel Pump
-Perrin Fuel Rails
-Perrin Turbo Inlet
-Perrin After-MAF
-K&N Drop In Filter
-STI Spec-C Long Runner Intake Manifold (no tgvs)
-3mm Phenolic Intake Spacers
-Maddad UEL Header
-Maddad Cattless Up Pipe
-Stromung 3" Divorced Short Down Pipe (custom cattless lower section)
-Stromung 3" Catback
-Turbo-XS TMIC
-Forge BOV
-Hallman MBCS
-NGK 1 Step Colder Plugs
-Defi Control Unit
-Defi Link (oil pressure, water temp, EGT and MPH)
-Defi Boost Gauge
Suspension/Drivetrain:
-Tein Basic Coilovers (Soon to be swapped out for ISC N1 Streets)
-Whiteline Front and Rear Swaybars
-Whiteline End Links
-SPT Front Strut Tower Brace
-Tein Rear Shock Tower Brace
-Group-N Front 4-Pot Brake Kit
-Group-N Rear 2-Pot Brake Kit
-DBA-5000 Slotted Rotors (F&R)
-Goodrige SS/Teflon Brake Lines
-Kartboy Short Shifter
-ACT HD Clutch
-ACT Street Light Flywheel
-Mishimoto Aluminum Radiator
-Samco Hoses
-Cryo Treated JDM Gear Set
-BBS VZ Wheels (White)
-NEXEN 3000 225/45/17
I think that is about it.
Also do you guys think it would be beneficial to use a K&N Typhoon short ram intake with "heat shield" or just keep the stock box with K&N drop in and Perrin after MAF?? I have both.
naCAnItihS is offline   Reply With Quote
Old 05-09-2013, 03:53 PM   #2
Georgethefierce
Member#: 41713
. sprayfinishing
supplies.com
Georgethefierce is offline   Reply With Quote
Old 05-09-2013, 03:55 PM   #3
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
6, obviously
iamrazor is offline   Reply With Quote
Old 05-09-2013, 03:59 PM   #4
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
I like the optimism guys!
Old 05-09-2013, 04:06 PM   #5
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Serious guess? 260 hp /250 tq corrected at about 19-20 psi.
BlazeRex is offline   Reply With Quote
Old 05-09-2013, 04:09 PM   #6
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
Well its already been street tuned and is pushing 23psi tapering to 18psi.. Jay says there is a good amount left to go but I do not have a wide band yet so we are going to fine tune it saturday on the dyno.
Old 05-09-2013, 04:14 PM   #7
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Hmm. I'll revise to 265 hp / 265 tq after being tuned on the dyno. I've never had a vf on a 2 liter at that high boost, so I'm guessing on torque.
Old 05-09-2013, 04:40 PM   #8
Black94Snake
Member#: 274499
1994 5.8T Cobra
755rwhp @ 16psi
I don't think it'll break 260. Mustang dynos always read low.
Black94Snake is offline   Reply With Quote
Old 05-09-2013, 04:47 PM   #9
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
IIRC they guys at Dyno Tech said it was 13 or 14% less than the Dyno Jet down the street at DEZ Racing.
I also have a Hybrid EJ25 in the works. CP pistons and STI Rods. I need a new STI crank, one STI rod, a new Rod bearing and piston rings. Heads have already been machined for the EJ25 Block w/ new valves etc. But we will see when that happens. I have enough money out as it is lol.
Old 05-09-2013, 06:49 PM   #10
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
Edit: it's a 2.0.....revised numbers
265/300
timeXlost is offline   Reply With Quote
Old 05-09-2013, 06:56 PM   #11
Wicked Performance
Member#: 265606
Stock 2.0 WRX peak on that dyno make 160-170whp and about the same or slightly higher for torque.
Most EJ205 VF cars w proper supporting mods make around 270whp and 270-300wtq depending on the peak boost level.
Wicked [email protected]
Wicked Performance is offline   Reply With Quote
Old 05-09-2013, 07:41 PM   #12
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
I'm guessing 15% less than you anticipate it will.
skimobile is offline   Reply With Quote
Old 05-09-2013, 07:49 PM   #13
Greg_M
Member#: 299003
2005 WRX Hybrid
Can we play hungry hungry hippos instead? This game is depressing.
Greg_M is offline   Reply With Quote
Old 05-09-2013, 10:51 PM   #14
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Just keep in mind, there's a lot of things that can cause variations in the readings. Anything from how the car was strapped down, how aggressively the dyno is loaded, slight errors in calculating the WCF, how aggressive the tuner decided to lean on timing for the given load on that day, etc. I like to see consistency over a few days.
Old 05-10-2013, 07:21 AM   #15
Craig A.
Member#: 122519
2005 LGT, 2018 BRZ
280whp
Craig A. is offline   Reply With Quote
Old 05-10-2013, 07:27 AM   #16
RSblood
Member#: 87778
2016 Toyota 4Runner
TRD Pro
I had the same exact mods on my car, made 250whp and 276wtq.
RSblood is offline   Reply With Quote
Old 05-10-2013, 07:33 AM   #17
Thug
Precious ❄
Member#: 603
Banana.
Thug is offline   Reply With Quote
Old 05-10-2013, 10:14 AM   #18
nhmtns
Member#: 94283
'19 Ascent
Didn't see a lot of stickers on the windows, so it's gonna be a pretty low number.
nhmtns is offline   Reply With Quote
Old 05-10-2013, 11:00 AM   #19
Jack
Add Lightness
Member#: 13699
not my president
(From General)
231hp, 251tq as it sits.
If you take off the dba rotors and put on real rotors:
900hp, 300tq
If you put on a VTEC go Bwaaaaaah sticker:
1200hp, 19tq at 75,000rpm
Old 05-10-2013, 03:19 PM   #20
blindfaith814
Member#: 132197
1998 RSti
Mud/Dust, touch of wrb
had just about the same setup on mine with a big 16g
on moons mustang dyno made 240\260 at 21lbs...added meth made about 10hp more
i dont see any tint, no JDM front lip, and only 17" rims....low 200s
blindfaith814 is offline   Reply With Quote
Old 05-10-2013, 03:21 PM   #21
HERSHEY
Member#: 148549
95 RHD GC V7 STi
04 WRX, Sold the BlackSTi
Exactly what this guy said.
What Octane? 89, 91, 93, 110, C16
How hot/humid it is that day
The list of variables can go on "fuh dayz"
I've had a couple of my previous cars tuned by a couple different people here on the forums and the same car w/o any difference in modifications they were 0-50awhp difference between the tuners and the corrections they used.
HERSHEY is offline   Reply With Quote
Old 05-10-2013, 03:22 PM   #22
Ryouske
Member#: 283981
2011 WRX
Wicked Rare Blue
Over 9000
Ryouske is offline   Reply With Quote
Old 05-10-2013, 03:24 PM   #23
gallandof
Member#: 285698
2013 BRZ
Galaxy Blue
about tree fitty.
gallandof is offline   Reply With Quote
Old 05-10-2013, 03:27 PM   #24
leach0789
Member#: 210903
2013 MS3/Turbo Miata
Nitrous Rhodes
Edit: FWIW, I made 273 whp on a Mustang dyno with a VF39 and a [email protected] tune.
leach0789 is offline   Reply With Quote
Old 05-10-2013, 03:28 PM   #25
vision.dynamix
Member#: 139955
2015 Subaru STI
17Forester / 18Crosstrek
Potato.
