Welcome to the North American Subaru Impreza Owners Club Sunday January 20, 2019
Old 05-25-2013, 10:45 PM   #1
Buzzed Trucks
Member#: 316128
2012 WRX Hatch
Default Fog light panels for larger fog lights (2011+)
I am creating this thread to see if I can gain some input for larger fog lights on the 2011, 2012, and 2013's. I know there are a ton of people interested in larger fog lights since the stock ones are on the small side.
The main reason why companies are not releasing these panels is because the bumper needs to be cut. I did a little R&D myself and found that the bumper cover will definitely need to be cut. I figure a 4.5" diameter fog light will be a pretty good size so I grabbed a 4.5" grinding wheel and mocked it up. The other issue I came across is that the steel bumper also doesn't give you much room. A 4.5" fog light will be a VERY tight fit, even if it does fit. I have attached a photo showing where the bumper sits behind the bumper cover. The blue tape signifies the bumper. The fog light will have to sit in the bottom left of the panel for it to fit, hence why the stock fog lights sit there.
Now I know a lot of people are willing to cut their bumper cover, but are they actually willing to cut a little off a little bit of the steel bumper? You would only need to cut a couple inches off the side, basically where the blue tape is. This will give us a ton of clearance for larger fog lights.
I am planning on making a few prototypes for myself, and I would love some input from you guys. Hopefully I can get these dialed in to where I can go into production.
Buzzed Trucks is offline   Reply With Quote
Old 05-25-2013, 10:55 PM   #2
tnguye09
Member#: 278571
2011 WRX
interested to see the outcome. I want some fog lights but don't wanna sell out $400 for OEM which doesn't even work that well.
tnguye09 is offline   Reply With Quote
Old 05-26-2013, 02:36 PM   #3
Buzzed Trucks
Member#: 316128
2012 WRX Hatch
So I did a little mock up with some cheap 4" fog lights from pepboys. I'm not sure if I will be able to go much bigger if I want to maintain the "vent" on the side. I am planning on making the passenger side vent functional for a cold air intake.
As you can see in the pics, I cut out the bumper cover and you can see the bumper behind it. I then cut out part of the bumper to give me clearance. I made a ghetto bracket to hold the light. My next step is molding a panel for it to look good.
Old 05-26-2013, 09:45 PM   #4
apkarian100
Member#: 207053
2018 WRX
PR
What are you going to do for a shroud?
apkarian100 is offline   Reply With Quote
Old 05-26-2013, 10:25 PM   #5
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
I've been trying to source a similar driving lamp bezel / kit:
Big-E is online now   Reply With Quote
Old 05-26-2013, 11:34 PM   #6
W.K.S.
Member#: 314986
^^^^Holy **** I want that!!! Quoting and putting in the ht autos thread.
W.K.S. is offline   Reply With Quote
Old 05-27-2013, 12:51 AM   #7
Buzzed Trucks
Member#: 316128
2012 WRX Hatch
I will be molding a panel so everything looks nice.
I'm planning on mine turning out similar to these, but a little different.
Good luck getting HT Autos to make these. There's already been a ton of people trying to get them to do it. I wouldn't be making this thread if they were going to make some.
Old 05-27-2013, 08:13 PM   #8
Buzzed Trucks
Member#: 316128
2012 WRX Hatch
I started fitting some custom panels and even though things are going slow, it's making some progress. I'm only working on one side of the panel, but one I get this side dialed in, I will then move onto the vents.
Old 05-31-2013, 01:02 PM   #9
tnguye09
Member#: 278571
2011 WRX
any progress?
Old 05-31-2013, 02:58 PM   #10
Buzzed Trucks
Member#: 316128
2012 WRX Hatch
I'm leaning away from trying to custom mold them into my current ones. I juet don't think they will turn out that well.
So I'd like to draw them up on solidworks but I really don't know how to take dimensions of the current panels since there's so many curves. I have a buddy that has a Faro Arm so I will be able to reverse engineer the panel and get it into a 3d model in my computer. I will then be able to modify them exactly how I want them. I have a few connections with companies with 3d printers so I will the have them print me out the panels. The fitment will be absolutely perfect then.
Next step after that would be to custom make the brackets to mount the fogs, which will be very easy.
Hopefully I will have the solidworks drawings done by Sunday and I will give you guys an update there.
Old 05-31-2013, 03:49 PM   #11
tnguye09
Member#: 278571
2011 WRX
Excited to see the results. Please keep us updated!
Old 05-31-2013, 04:01 PM   #12
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Yeah I posted the exact same picture in their thread in September of last year and it's what got all the GR people riled up. HTA already said they will not do it since it is not a drop in replacement and requires cutting.
http://forums.nasioc.com/forums/show...&postcount=801
To OP, looks good, I just don't think I can cut into the bumper beam like that. Keep it up though, interested in the results.
JSchell1309 is offline   Reply With Quote
Old 07-18-2013, 09:49 AM   #13
yudangorgor
Member#: 151107
2011 WRX
sub'd
yudangorgor is offline   Reply With Quote
Old 07-18-2013, 10:21 AM   #14
Oaf02Z
Member#: 263219
Interested to see more
Oaf02Z is offline   Reply With Quote
Old 07-21-2013, 04:09 AM   #15
Wrbboost
Member#: 362505
Also interested for more and possible DIY?
Wrbboost is offline   Reply With Quote
Old 01-04-2014, 08:19 PM   #16
Wrbboost
Member#: 362505
anyone know what's goin on with this if the OP made them?
Old 01-04-2014, 08:39 PM   #17
Buzzed Trucks
Member#: 316128
2012 WRX Hatch
I have been super busy the past few months, mainly with my last semester at PSU for Mech Engineering. I will be making more progress on these hopefully soon since I have some new connections with some molding companies!
Old 01-04-2014, 08:55 PM   #18
Wrbboost
Member#: 362505
sounds good, I really want bigger fogs I like the OEM ones but I'd like something different
Old 01-04-2014, 09:56 PM   #19
Beau M
Member#: 345079
13 Wrx sedan
I've given this a lot of thought as well. I don't think the lights need to be inset so far back. I think the outside of the light could even stick out from the surface of the panel, like this:
Beau M is offline   Reply With Quote
Old 01-04-2014, 09:58 PM   #20
Wrbboost
Member#: 362505
can't wait for the finished product
Old 01-04-2014, 10:34 PM   #21
Soobiecabra
Member#: 259527
2016 STi
Pure Red
Large fogs would look nice up front but I would never cut my actual bumper. The plastic covers are no prob but the steel bumper is there for your safety. No thanks. If the lights could mount farther out to accommodate deeper sockets or even find some slim design fogs that would be way better IMO. Thumbs up for taking initiative and trying it yourself though.
Soobiecabra is offline   Reply With Quote
Old 01-04-2014, 11:22 PM   #22
garudatwo
Member#: 322385
Obtrusive light bars are the other option:
garudatwo is offline   Reply With Quote
Old 01-05-2014, 12:20 AM   #23
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
From the picture in post#1, and considering the option of fabricating a mold that allows the foglight to be mounted ahead of the bumper beam (pst #19), looks like it would be possible to consider a hybrid.
For example, get an even larger donor housing, say, a 7":
And plan to cut the upper half of the 7" housing. The 7" glass lens remains uncut, and sits on a mold ahead of the bumper beam. Everything else behind it will be cut as necessary to fit the available space.
Then, retrofit a good projector foglights like the Hella Micro DE halogen fogs, fusion fogs, or QX45 fogs.
satrya is offline   Reply With Quote
Old 01-31-2014, 02:00 AM   #24
Buzzed Trucks
Member#: 316128
2012 WRX Hatch
Finally back for another update. I have designed some fog light "adapters" if you want to call them that. You will need to cut an oval in your current fog light covers for this piece to fit it. Even with the curves of the cover, I managed to design it so the adapter will sit flush. This will allow you to either pop it in, or you can mold it into your cover. I will be having a friend make me a prototype on his 3d printer to see how the design turns out. Also, as you can see in the design, I made a lip on the adapter that will cover up your cuts. The current adapters are for 4" fogs, but I am hoping I can bump it up to 4.5" or 5", but I'm not sure if that will be able to happen.
Let me know if you guys have any suggestions or recommendations!
Old 01-31-2014, 02:06 AM   #25
WhatsASubie
Member#: 362544
2013 Wrx
satin white pearl
cant wait for the final product!
WhatsASubie is offline   Reply With Quote
