Welcome to the North American Subaru Impreza Owners Club Tuesday January 16, 2018
Old 07-27-2013, 11:41 PM   #1
boczo777
Member#: 305314
2010 STI
BLACK
Default heel and toe
i think everyone knows this technique but for me its easier to watch than do
once i have talked to a guy that races semi professional and he told me that the most important piece are pedals, he says he always raises throttle because those 2 must be even to properly and easily execute heel and toe breaking and downshifting
what are your views about it??
boczo777 is offline   Reply With Quote
Old 07-27-2013, 11:47 PM   #2
Jack
Add Lightness
Member#: 13699
After you've been doing it consistantly for a few years on the track, you don't even think about it anymore. Don't overthink it. The whole idea is to be able to threshold brake into a corner and get the revs somewhat matched so the tires aren't upset, messing up braking. That's really all it is.
Old 07-28-2013, 01:23 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
yeah...and i have seen and had to do it several different ways on different cars
sometimes ya have to use the toes of your foot on the throttle pedal and your heel on the brake.....one car i had...dont remember which one it was now, but ya hadda use your toe on the throttle linkage above the pedal to get it right
ive been doing it so long now that i dont even realize im doing it anymore
Old 07-28-2013, 01:36 AM   #4
viper2788
Member#: 358129
2007 WRX STi
black
I'm starting to get into the habit myself. For me the most important thing is foot placement. I press higher up on the brake pedal in order to comfortably access and blip the gas. Try working on just rev matching(without braking) in heel toe position, then try both. It takes practice to get the proper feel down
viper2788 is offline   Reply With Quote
Old 07-28-2013, 05:18 AM   #5
dartdude72
Member#: 310505
2005 Legacy GT
I've never done the heal toe with my actual heal and toe. I just always brake with the left side of my foot and blip the gas with the right side of my foot by rocking it over.
I always rev match in every day driving, and "heal toe" when I get spirited.
dartdude72 is offline   Reply With Quote
Old 07-28-2013, 05:30 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
that's kinna the point....there are many ways it is, has, and can be done
what you describe is pretty much how i do it in my wrx....ball of the foot on the brake and 'roll' the instep over onto the throttle pedal
and "HEEL'
Old 07-28-2013, 11:58 AM   #7
equiraptor
Member#: 300017
2012 WRX Limited
WR Blue
*nod* Also what Jack said.
I heel-toe with... my heel and my toe. I'm 5'5 and female, and as a result have smaller feet than most men. This means there's plenty of space, even in small cars, for me to twist my foot over. I'm also fairly flexible, so can twist my foot fairly far and stretch my calf pretty well. As a result, I've never needed to move or change a pedal to heel-toe without issue, and in few cars do I even need to think about it.
equiraptor is offline   Reply With Quote
Old 07-28-2013, 12:04 PM   #8
happychappy101
Member#: 264096
2011 WRX
Dark Gray Metallic
I rev match every single downshift, but honestly have been somewhat intimidated by heel-toe...hmm maybe I'll just made this my next driver mod!!
happychappy101 is offline   Reply With Quote
Old 07-28-2013, 12:11 PM   #9
Luc r
Member#: 332784
11 flexed wrx
my feet are too big to do heel toe. i have half my foot on the brake and half on the gas to rev match.
Luc r is offline   Reply With Quote
Old 07-28-2013, 12:29 PM   #10
some dude
Member#: 100300
06 WRX
CGM
What size ur shoe bro? ^
some dude is offline   Reply With Quote
Old 07-28-2013, 12:47 PM   #11
Back Road Runner
Member#: 60082
2004 Forester STI
Having done it in bigass boots, foot size isn't a problem. Heck, you'll run into the problem of overlapping the gas and brake pedal during normal driving before you can't heel-toe anymore.
Really learning is just about doing. You start and play with it on a regular basis. Over time you get better. That's it. The how is less important as that varies by car, shoe size, show type (heels, shape, etc.), and even how you sit in the car (how close or far you are in the seat). In the end all you need to do is apply some braking force while also being able to reach over with the same foot to apply a blip of gas.
Old 07-28-2013, 01:04 PM   #12
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
It really all depends on the car. In my spec miata the pedals have been adjusted so that they are even when I'm under heavy braking, making it easy to get to the throttle. But the Wrx is a little different because under heavy braking my throttle is actually higher then my brake pedal (I have a very soft pedal for some reason), so I usually blip the throttle before braking a little more then I need so by the time I get to the brake the revs are matched. I can go on and on about different cars I have driven and the different driving styles they require.
dburgoon is offline   Reply With Quote
Old 07-28-2013, 01:06 PM   #13
Luc r
Member#: 332784
11 flexed wrx
only 11. but theres not enough room for me to swing my heel over bc of the floor panel. idk, never got the hang of heel toe. the way i do it works good for me
Old 07-28-2013, 01:32 PM   #14
kabz
Member#: 351744
2016 STI
CWP
It's always shifting down to second, turning and still being on the brakes, where I need to blip it, but I still never have really mastered being able to blip the throttle to rev-match without screwing up my braking.
kabz is offline   Reply With Quote
Old 07-28-2013, 01:37 PM   #15
Toombs
Member#: 340935
2001 RS
2013 WRX STi
Here you go, try to emulate this guy.
In loafers..... legendary.
Toombs is offline   Reply With Quote
Old 07-28-2013, 01:41 PM   #16
Luc r
Member#: 332784
11 flexed wrx
he uses both methods in that video^^
Old 07-28-2013, 01:55 PM   #17
575rider
Member#: 112024
03 WRX 6sp wgn
'12HondaFit, C Bronson
I wear 13's and manage fine, just takes practice.
575rider is offline   Reply With Quote
Old 07-28-2013, 02:27 PM   #18
69subaru360
Member#: 159682
1995 WRX
2015 F150
I have this pedal set, it's not pep boys crap, they are functional and fit right. The little extension on the gas pedal lets you hit the throttle with your heel as you brake with your toe. You want to adjust the pedals so that when the brake is applied it's even with the gas at rest.
Old 07-28-2013, 02:41 PM   #19
Ronen91
Member#: 324810
2013 STi
and "HEEL'
Exactly how I do it as well. The first time I did it properly on my way to work I couldn't stop telling everyone about it.
Ronen91 is offline   Reply With Quote
Old 07-28-2013, 04:56 PM   #20
equiraptor
Member#: 300017
2012 WRX Limited
WR Blue
That's still "heel toe". The term for "using three pedals with two feet" is heel & toe, no matter what parts of the foot you use.
Old 07-28-2013, 05:02 PM   #21
PairOfImprezas
Member#: 360775
2008 WRX
Video Link: http://youtu.be/8By2AEsGAhU
& with white socks. One brave fellow.
PairOfImprezas is offline   Reply With Quote
Old 07-28-2013, 06:04 PM   #22
some dude
Member#: 100300
06 WRX
CGM
I've seen that senna video of heel toe. I loved it. I love him.
Old 07-28-2013, 10:03 PM   #23
wrxpatrol
Member#: 334545
It's a useful technique for advanced drivers on a track.
For beginners, I would advice that they focus on staying in the racing line with proper braking/accelerating/weight control first.
wrxpatrol is offline   Reply With Quote
Old 07-29-2013, 12:49 AM   #24
dj_quik
Member#: 358424
2011 STi
white
try wearing pumas...they were made for heel toe driving! just sayin...
dj_quik is offline   Reply With Quote
Old 07-29-2013, 03:30 AM   #25
TheB00T8930
Member#: 328014
2004 Impreza WRX
I have pumas. They're size 13, heel toe is very difficult!
TheB00T8930 is offline   Reply With Quote
